Old 09-02-2015, 12:09 PM   #15
SkiRideDrive
SkiRideDrive's Avatar
Drives: 2015 FRS
One thing to try... make sure torque is not running when you start the car. That will cause it to throw codes. But I think those codes are communication issues... not the ones you mentioned above. Good luck.
2015 FRS Ultramarine.
SkiRideDrive is offline   Reply With Quote
Old 09-02-2015, 12:13 PM   #16
J-W
J-W's Avatar
Drives: '13 Subaru BRZ Limited
I normally only plug in the adapter when I intend to check things out and I have the car on and around operating temperature. The past few days have been the exception due to frustrations of trying to wrap my head around the problem.
J-W is offline   Reply With Quote
Old 09-02-2015, 03:07 PM   #17
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Originally Posted by J-W View Post
Brand new Sunday. Removed the entire intake and reassembled to ensure everything was right. Besides, if it's before the MAF sensor, wouldn't it still register the volume?
You may have a vacuum leak if there was anything that came loose or wasn't re-installed correctly.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 09-02-2015, 03:12 PM   #18
J-W
J-W's Avatar
I've triple checked everything leading into the intake manifold at this point. I've spent quite a few years as a mechanic, so can we get off the "something installed incorrectly" theme? I'm not meaning to sound unappreciative of the advice, but I've stated a few times that I've ruled it out.
Old 09-02-2015, 03:18 PM   #19
Apoc
Apoc's Avatar
You shouldn't ask for advice from non-mechanics and figure it yourself.
“The World is Flat”
[||•]=(86)=[•||]
Old 09-02-2015, 03:27 PM   #20
J-W
J-W's Avatar
First: There happen to be other very skilled and knowledgeable mechanics on here that may or may not have something to add.
Second: In my OP, I didn't state that I was looking for advice and was merely doing this as a public record for others that may have similar issues.
Third: Any helpful advice is appreciated, though I'm confident I'll get it sorted some way.
That all being said, I'm assuming you didn't read a majority of the thread and I'm sorry if you did and just didn't pick up on what's already been discussed.
Old 09-02-2015, 03:41 PM   #21
Apoc
Apoc's Avatar
I did read the entire thread. You never mentioned that you removed the intake entirely until a couple posts ago. Problems usually stem from the last thing was changed. P0171 usually pops up with a vacuum leak or exhaust leak. Sometimes putting ego aside on these forums helps.
“The World is Flat”
[||•]=(86)=[•||]
The Following User Says Thank You to Apoc For This Useful Post:
Dallen (09-02-2015)
Old 09-02-2015, 03:51 PM   #22
J-W
J-W's Avatar
Had it been that code alone, I would be more inclined to agree with that statement. As was stated earlier, car is nearly bone stock. Aside from oil, peeking at the air filter and rotating the tires, nothing has been changed in the past six months.
Old 09-02-2015, 04:35 PM   #23
Euro7R
Drives: 2013 Subaru BRZ
Long shot, maybe unplug the battery to let the car "reset" itself. Weird things with this car and brand new too.
Euro7R is offline   Reply With Quote
Old 09-02-2015, 04:59 PM   #24
J-W
J-W's Avatar
Had it disconnected while I took apart the intake checking things.
Old 09-02-2015, 05:36 PM   #25
J-W
J-W's Avatar
Took some freeze frames at idle, I'll post them when I get home. Can't seem to post them properly from my phone.
[IMG][/IMG][IMG][/IMG][IMG][/IMG]
Old 09-02-2015, 08:03 PM   #26
steve99
That's what I have and what I've been using to pull codes. Not really sure where sensors should be reading at what point, but at idle, it seems like engine load is ridiculously high.
At idle engine load should be arround 0.3
afr generally arround 14.7 once warmed up at idle
ltft will vary a bit depending on intake air temps fuel ethhanol percent ect but should be less than 10% usually arround +\-5% in most cases ,if long termm fuel trim is high like 15 to 20% usually an indication something is wrong
short term fuel trim will vary widly with throttle application this is normal
commanded afr and afr should follow each other under load
see logging link below
Old 09-02-2015, 09:01 PM   #27
CARBONGT86
CARBONGT86's Avatar
Drives: 13 carbon accents Blk
had the same issue at 29k
Took it too dealer and they flashed the ecu with the latest revision.
CARBONGT86 is offline   Reply With Quote
Old 09-02-2015, 09:19 PM   #28
J-W
J-W's Avatar
How long ago was that, may I ask? Any issues at all since?
And So It Begins nivek111070 Electronics | Audio | NAV | Infotainment 22 04-22-2015 09:08 AM
And the fun begins! FR-S Matt Scion FR-S / Toyota 86 GT86 General Forum 4 12-25-2012 09:37 PM
iBRZ: it begins. iBRZ Member's Car Journals 17 12-18-2012 11:21 PM
FR-S search begins mkiisupra Southern California 6 11-22-2012 01:40 AM
The Wait Begins Tanuki Scion FR-S / Toyota 86 GT86 General Forum 21 09-06-2012 05:50 PM
