Old 10-23-2015, 12:43 AM   #15
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
I think it's the end links, lots of people have had that problem (I'm currently having the same problem and have been checking EVERYWHERE) from what I can tell it is slowly getting worse, tried tightening the end links today since a friend of mine said that fixed the problem on his… didn't help: I'm going to bring it in to Subaru (if they'll look at it for free even though it isn't under warranty) and hopefully they can give me a definitive confirmation of my suspicion…
EDIT: By the way @slyphen since it's been over a month… did you find out what was causing YOUR problem?
Keenercarguy is offline   Reply With Quote
Old 10-23-2015, 01:16 AM   #16
swarb
^I second the possibility of sway bar end links. Mine have come loose on two occasions.
The Following User Says Thank You to swarb For This Useful Post:
fatalelement (10-23-2015)
Old 10-23-2015, 01:18 AM   #17
slyphen
Drives: Man
Send a message via AIM to slyphen Send a message via Yahoo to slyphen
@Keenercarguy the dealer haven't got a clue. they swapped the entire strut and thought it was the strut collar, i still get the sound. i'm bringing it back to the dealer later next week. they told me they gonna get a subaru engineer to come down and check it out.
slyphen is offline   Reply With Quote
Old 10-23-2015, 03:04 AM   #18
Keenercarguy
Mountain Runner
@slyphen seriously consider asking them to replace the end links, a lot of people described the same problem that we're having and fixed them with the end links. Plus, definitely cheaper than a new strut.
Also super jealous of where you live by the way... I love basically every single part of Washington that I've seen so far.
The Following User Says Thank You to Keenercarguy For This Useful Post:
slyphen (10-23-2015)
Old 10-23-2015, 08:44 AM   #19
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
if you look into the archives of this forum you can find people talking about a weird clunk kind of noise when you reverse out of a sloped pavement onto a flat one .. did you have 1 wheel on the flat and one on the sloped pavement?
Old 10-23-2015, 12:08 PM   #20
kch
Senior Misanthrope
kch's Avatar
I'm experiencing the same issue, but it doesn't have to be on a sloped driveway. It happens any time I turn sharply while moving slowly, and the sound seems to come from the front driver's side area.
I'm going to check the end links this weekend. I've also read elsewhere that it could be a ball joint.
In for updates from @slyphen
The Following User Says Thank You to kch For This Useful Post:
Old 10-23-2015, 06:00 PM   #21
slyphen
Drives: Man
now that you said it, for most of it yah, my parking spot is a very slight slope upward, you can't really tell if you are just looking at it or standing on it. And thats where it happens everyday 99% of the time. but at the same time, it also pops on flat pavements occasionally.
Old 10-23-2015, 06:37 PM   #22
fatalelement
fatalelement's Avatar
Drives: 2015 FR-S (Halo)
My car had this, turned out end link was a bit loose. By a bit loose I mean I had to go at it with a torque wrench but spec is very tight. Enough stress can make the bolt shift in the socket, which is obviously larger than the bolt. Metal on metal.
Check those endlinks and see if it helps. Have you changed your sway bar (s)?
Sent from my SAMSUNG-SM-G925A using Tapatalk
fatalelement is offline   Reply With Quote
Old 10-24-2015, 05:09 PM   #23
Keenercarguy
Mountain Runner
So I had a professional suspension tech and porsche GT racecar driver look at mine at an autocross today and the second he heard the description he was about 95% sure what it was (I already torqued my endlinks down to a little past spec and there's no way that they are loose by the way). The sound, according to him, was coming from the sway bar bushings on the front sway bar. We turned the wheels and heard the pop and he inspected them; he's positive that's the problem and you can even see that the bushings aren't 100% snug anymore. I've ordered a Perrin 19mm front sway bar and white line adjustable endlinks. I'm going to change the sway bar first and if, somehow, that's not the solution then I will change the endlinks. I'll post my results when I find out late next week.
The Following 3 Users Say Thank You to Keenercarguy For This Useful Post:
Bonburner (10-24-2015), chaoskaze (10-24-2015), fatalelement (10-26-2015)
Old 11-02-2015, 11:26 PM   #24
Keenercarguy
Mountain Runner
My popping is fixed!
Originally Posted by slyphen View Post
edit: it does sound a little like spring or a bushing poping.
edit 2: it doesn't only happen while i back out of my drive way, although i'm 99% sure its gonna happen there every time.
So the suspension tech was absolutely right in my case. I got a new front sway bar entirely (a perrin adjustable one) since this was an excuse for an upgrade. Upon replacing the sway bar the popping was gone entirely. Inspection of the bushings on the OEM sway bar showed clear signs of wear and they were the problem. I also purchased whiteline front end links just in case, didn't even need to install them, so now I can get my money back for those.
In conclusion, the popping is gone!
Turn your wheel to one side and get your head down close to the sway bar with a flashlight, you'll be able to see the bushings just fine. The bushing should be fully snug around the bar (there should be a clear 90* angle between the bar and bushing). Check the edge of the bushing (where it is wrapped around the bar) for rounded edges. The left and right bushings on my bar both had rounded edges from pressure and wear, and that was causing the popping. If anyone wants pictures of a good bushing versus a bad one for reference then I can fish out the old bar from wherever it ended up and take photos of the new 08-14 WRX rear sway bar that I'm about to install for pictures of proper fitment.
Good luck!
Edit: I also auto crossed the week before installing the bar and again right after installing the new front bar on a very similar course, at the same location. You are just fine to drive on the worn bushings, they are not the end of the world and you can take your time fixing them. For a BRZ stiffening the front up will add a little more understeer, I have an autocross focused alignment to negate some of it myself and it was still noticeable with the added stiffness of the Perrin (25% or 72% stiffer than stock, I am using the 25% stiffer setting) bar, I am remedying this with a moderately stiff (46% stiffer than stock) OEM 08-14 WRX sway bar in the back. For an FR-S the slightly stiffer front bar would actually make the car a tad more neutral though, so consider upgrading when you attempt a fix!
slyphen (11-03-2015)
Old 12-07-2015, 05:52 PM   #25
slyphen
Drives: Man
update on this poping issue. My dealer called in a subie engineer to assess the problem. and to my expectation, it was the spring rotating in reverse and digging into the top mount. this only happens in reverse while i'm turning because it make the spring rotate in the opposite direction, when comparing to turning while i'm moving forward.
the dealer put some kind of rubber gasket between the spring and the top mount where the spring make contact and the noise was gone.
Subaru dealer has agreed to give me an entire new spring and strut assembly, if the gasket did its job fixing the issue. I just want to make sure all problems are solved before going after market. I do have a set of Fortune Auto 500 coming in.
Old 12-21-2015, 04:17 PM   #26
D_Thissen
D_Thissen's Avatar
Going to bring this thread back. I have a 2013 FRS lowered on RCE Yellows (about 9000km on them and 19000km on stock struts) and has whiteline camber bolts up front. I have a clunking in the front end (driver side) that occurs when turning the wheel at slow speeds.
I have had a dealership check it out, and while they could replicate it, the could not find what was wrong. I also had a shop that specializes in Subaru's look at it, and couldn't find the source. They took the strut out and checked the top hat and re-torqued everything. What are the odds that its the front sway bar bushing?
Old 12-21-2015, 10:40 PM   #27
slyphen
Drives: Man
the dealer has replaced my struct and spring. issue has been fixed
Old 12-22-2015, 05:44 PM   #28
ScoobySubie14
Drives: 2013 Subaru brz limited
Ive encountered a similar sound and thought the same thing till i put the car on a lift and found the calipers to be loose. just food for thought.
ScoobySubie14 is offline   Reply With Quote
What's this clunk sound coming from 2nd gear after letting go of the clutch ? awhatzable Scion FR-S / Toyota 86 GT86 General Forum 17 04-30-2015 02:14 AM
When I was backing up.... Mikem53 Scion FR-S / Toyota 86 GT86 General Forum 5 04-24-2014 11:47 PM
Clunk sound after starting car and releasing clutch subiestyle Issues | Warranty | Recalls / TSB 1 03-14-2014 02:30 AM
Clunk sound with disengaging clutch up driveway BRRRZZZ Issues | Warranty | Recalls / TSB 4 04-22-2013 08:54 AM
Clunk sound from rear suspension. j-tan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 02-05-2013 12:39 PM
