| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
| View Poll Results: How much have you spent on mods only? | |||
| < $1,000 |
30 | 20.41% |
| $1,000 - $2,000 |
27 | 18.37% |
| $3,000 - $4,000 |
26 | 17.69% |
| $4,000 - $5,000 |
9 | 6.12% |
| $5,000 - $10,000 |
23 | 15.65% |
| $10,000 - $15,000 |
18 | 12.24% |
| $15,000 - $20,000 |
6 | 4.08% |
| > $20,000 |
8 | 5.44% |
| Voters: 147. You may not vote on this poll | |||
#15 |
The Stig's African Cousin
Drives: 2014 wrb brz
I was about to ask how but then I realized you brought genuine sti parts
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386 Flickr: brandonblt567 |
#16 |
Drives: 2017 BRZ
Dunno, it's not exactly hard. I got the BBK and header used... but still passed the mark. I could have only come close without compromising and buying crap, to be sure, but that would still have avoided knock-offs too. Different wheels, different coilovers (especially if I'd have found the right ones used...)
#17 |
Drives: 2013 Raven FR-S
hmmmmm....
-OFT -borla uel -invidia N1 catback -wheels and tires (300 bucks on craigslist -shift knob -k&n filter So roughly 1800? i basically hit most of the cheap (but essential IMO) mods. next comes boost! spring time....., |
#18 |
Drives: 2005 Toyota Camry
#19 |
Haha yeah it all adds up. I'm pretty sure I've passed the 15k mark and that's only the BRZ. Don't even want to think about the amount when combined with my WRX
@dsomegax.cars
2013 Subaru BRZ Limited | WRB | STI tS Build Thread [SOLD] 2019 BMW M2 Competition | LBB | ///M Performance Build Thread 2020 Toyota GR Supra | Turbulence | TRD | Build Thread |
#20 |
Drives: 2015 Subaru BRZ
More than my fiance approves of less than half as much as I intend to.
Coilovers Spacers Turbo kit EBC Custom intake with AFE filter Motive front pipe P&L Overpipe Invidia N1 ti cat back Custom Dyno tune 7psi with 12 psi at WOT Crawford AOS switched to VTA STI PCV valve Whiteline shifter bushing Whiteline subframe bushings PLX gauges with ATI vent pod and 52mm adapter With wideband and fluid temp module Seibon carbon trunk Just ordered Motul fluids for trans and diff Torque brake fluid ACT heavy duty 6puck sprung clutch kit VIS AMS carbon hood en route Spencer Fab crash beam en route Oil cooler Ported wastegate. PTP lava turbo blanket DEI heat wrap Dei insulated radiant heat barrier on cold side IC piping Omni 3 bar MAP sensor Radiator hoses Soon to be corner balance and aligned when I get wheels and tires Long way to go and trying to do things correctly like having all carbon sanded and cleared and no more replica parts or compromises. |
#21 |
Drives: 2010 MS3
Jeez guys. Wow. haha
I tracked my car for the first time when the car turned 1000 miles, everything was stock. I did like 1:45.5 at SOW. After $2k worth of mods and seat time, I'm at 1:32.1. I'm pretty damn happy about it. The car looks and drives well beyond my initial expectation when I bought the car. |
#22 |
~$2k
In order: Motul RBF600 Carbotech XP10 Dunlop Direzza ZII SS (215-45-17) Camber Bolts Camber Plates 4 wheel custom alignment (been on a rack 3 times so far) And because JS + BRZ mentioned track times, best time is ~1:53 at LS, pretty consistent average of 1:55 without interuptions +/-2, that was my third day at the track, before camber bolts/plates were installed. Est. spent on track time and autox... $1.6k? |
| The Following User Says Thank You to strat61caster For This Useful Post: | JS + BRZ (08-28-2015) |
#23 |
Drives: '16 WRX, CBR1000RR
I think I had somewhere around $6-$7k.
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
#24 |
Drives: MY11 Maxima 350st, MY15 BRZ
Around 4k aud
Full rip out and replace audio / nav / reverse camera. BRZ floor mats BRZ boot mat STI drop in filter STI shift nob STI push start Toms' clear brake lights
MY15 CWP A/T BRZ | Leather heated seats | STI CAI filter, A/T leather shifter, strut brace, V-brace, draw stiffener, battery tie down, Radiator cap, Oil cap, push start button | TRD door stabilizer | YoSpeed STI console garnish | Pioneer AVIC-F70DAB + Rev-camera, TS-WX710A sub | JL speakers, Amp | TOMS' Clear Brake Lights | Cusco 4.556 FD | Driveshaft Shop aluminum shaft | Tein FlexZ, EDFC AP+GPS | Crawford BPB
#25 |
Drives: 2015 WRB BRZ
About $80 in gas.
#26 |
surprised that i've spent close to 15k converted to dollars, including 2 sets of rims and 2 sets of tires.. and im not boosted yet
2013 Toyota 86
Sterling Silver Metallic IG: @pcuerpo.images |
#27 |
Drives: Supercharged GT86
I don't think my calculator could figure it out...
- Sprintex (Innovate) 210 supercharger kit - Replaced by Sprintex (Innovate) 335 supercharger kit - Borla UEL manifold - Cobra overpipe - Berk high flow cat front pipe - Invidia Q300 catback with custom midpipe - Sti front lip - Bottom line side diffusers - Sti rear bumper caps - 18" Rays Gram Lights 57DC's in custom colour - 18" WedsSports TC-105N's - 18" Japan Racing JR-11's - HKS Hipermax GT IV coilovers - Summit rear camber arms - Summit rear toe arms - Adjustable drop links front and rear - Impreza 16mm rear anti-roll bar - Custom painted interior - Blitz gauge pod with 3 Prosport digital gauges - Sti engine mounts - Sti gearbox mount - HKS air intake - HKS panel filter - 362mm 6 pot AP racing front brakes - 08+ Impreza Brembo rear brakes And as I type this I'm currently installing: - HKS 2.1l stroker kit - HKS cams - Lightweight flywheel - Stronger, lightweight clutch - 500cc injectors - Walbro fuel pump - Setrab oil cooler - 3bar map sensor - Mtec shifter springs And probably some other bits I've missed... |
#28 |
haha I'm glad to see what some of you have spent so far gives me justification to spend another 4k on my car
