Old 08-17-2015, 11:39 PM   #15
Ultramaroon
not playing cards
Ultramaroon's Avatar
2nd Pro-Tip: Hang bags of water from your doorframe in the summer so you can keep your doors open without bugs getting in.
Yeah, what's up with that? I've never understood how that could possibly work.
Old 08-17-2015, 11:52 PM   #16
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
Originally Posted by DJCarbine View Post
Whats wrong with the AC? Lots of times it can be a simple electrical problem. Now if the compressor is shot or someone stole your heat exchanger then yeah....
Is your old system R22 or 410a? You can still get dry charged R22 units for residential install if needed so you don't have to replace the evaporator
Trane and Carrier are both good, as stated earlier make sure it is appropriately sized. Are you hiring a contractor/AC install company? Just have them make you a few quotes comparing the different brands.
We tried looking for other possible problems with the AC but couldn't find anything. Then we had someone check it out for us and told us that a wire was burnt or something and that we needed a new whole unit. The weather is getting cooler so it's not as humid inside the house as it was last weekend.
Kelbyat07 is offline   Reply With Quote
Old 08-17-2015, 11:54 PM   #17
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
I think it will work to some extent. I feel like you'll still end up with bugs inside the house though. But I might give this method a try for when I need to use the back door often when I'm grilling or whatever.
Old 08-18-2015, 12:05 AM   #18
DJCarbine
Thupercharged
DJCarbine's Avatar
If its the compressor wires, it does happen... if its not too bad you can get kits made exactly for this with better connectors to reduce the amount of resistance a bad connection causes which can burn up wires.
[ame="http://www.amazon.com/Term-LOK-TLC310-Compressor-Terminal-Repair/dp/B004UW0GGC"]Amazon.com : Term-LOK TLC310 3 Wire Compressor Terminal Repair Kits 10 Gauge : Vehicle Amplifier Battery Wiring And Terminals : Electronics[/ame]
It sounds like the terminals were too far gone if the guy said you needed a whole new unit, if the terminals got really bad they can actually break the seal around the terminals and all the magic ice juice leaks out
2013 FRS
Vortech V3 11psi
Old 08-18-2015, 01:32 AM   #19
Ultramaroon
not playing cards
I killed the compressor in my heat pump 5 years ago. My own stupidity. The unit is at least 20 years old. The guy tried to sell me on a new unit but I called BS. Made him replace the compressor and watched him like a hawk. He had to go back to the shop to get the tools to fully evacuate the system before adding the refrigerant. 600 bucks later and it was working like new. Soon after, I found the floating ground in the control system that intermittently caused the blower to fail. It's keeping me cool as I type.
There are only a couple moving parts and ANYTHING can be fixed as long as due diligence is followed.
Old 08-18-2015, 01:58 AM   #20
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Refutation!!
Ultramaroon (08-18-2015)
Old 08-18-2015, 02:10 AM   #21
Ultramaroon
not playing cards
Refutation!!
All depends on the goal at hand.
Old 08-18-2015, 02:26 AM   #22
Captain Snooze
Drives: Red Herring
I can't wait to see the pics of you scoring with that.
Old 08-18-2015, 02:58 AM   #23
Ultramaroon
not playing cards
Old 08-18-2015, 08:58 AM   #24
babydriver
Hit the road and I'm gone
babydriver's Avatar
GOOOOOOOAAAAAL!!!!!!
Slip, slidin' away.
The Following User Says Thank You to babydriver For This Useful Post:
Tcoat (08-18-2015)
Old 08-18-2015, 09:50 AM   #25
Captain Snooze
Drives: Red Herring
Woooooo! I'm in!!!
Old 08-18-2015, 11:17 PM   #26
Ultramaroon
not playing cards
Woooooo! I'm in!!!
http://www.ft86club.com/forums/showt...82#post2360782
F/S HKS F-Con iS unit wbradley Engine, Exhaust, Bolt-Ons 6 07-30-2015 04:29 PM
About the New Radio Unit/Navi Unit for FR-S yangtaotai Scion FR-S / Toyota 86 GT86 General Forum 21 07-09-2013 01:27 PM
Selling Bespoke Unit and XM unit ravenfrs Audio/Visual, Electronics, Infotainment, NAV 2 11-05-2012 08:25 PM
nav unit in brz jmaryt BRZ First-Gen (2012+) — General Topics 32 10-15-2012 10:40 PM
What are available unit for our frs/brz? imravenit Electronics | Audio | NAV | Infotainment 0 07-31-2012 03:05 AM
