#15 |
Drives: FR-S Whiteout
1/13 FRS
1. Taillight seal 2. Leaking valve chain cover gasket 3. Crickets (pump replaced 2x) 4. ECU reflash (addressed the issue with OFT before TSB was released) 5. more camber on the RHS by about .5* front and rear 6. Squeaky windows (didn't realise that was a warrany-able issue)
Intent > Content
cowardice is the mother of cruelty. |
#16 |
Waited 5 years for this
Drives: '18 MX-5 Club
Picked up in June 2012.
1) Rear deck popping noise. 2) Famous fuel pump cricket. 3) Deformed window seal. 4) Squeaking noise inside of the bell housing when depressing clutch pedal. 5) Tail light condensation. |
#17 |
Sarcastic SOB
Same here.
#18 |
Track Junkie
Drives: Argento Scion FR-S
Bought mine in May 2012 also. Replaced taillights once.. been tracking since 40 miles on the odometer. I was supercharged for 11k miles and about to go Turbo. I have 43k miles on my car.
#19 |
12/12 build date, I bought it 11/1/14 with 14,5 on the clock. Since I got it I've had the window seals replaced, the tail lights replaced and the fuel pump replaced too. I think they reflashed it when the did the pump. Now I don't have the wind noise from the twisted moldings but they squeak. The tails are holding their own and NO MORE CRICKETS
I didn't ask for the pump to be done, I had brought it in for the squeaky, crunchy clutch pedal but they "couldn't replicate the issue" so they found the open tsb and did the work for me
#20 |
Drives: 2019 BMW ///M4
Mine was 6 or 7/13 build date. Picked it off the lot with 17 miles... on Dec 1 2013.
7k - Rear Deck Started Popping - Fixed by myself with WD40 11.5k - Rocker Arm, engine rebuilt 12k - 10 Series knob deformed -- Switched to stock knob and trying to get warranty replacement (Stop Sale Currently) 13k - Driver Seatbelt Squeak - Fixed by myself with WD40 Those were the only problems with the car...the major one being 11.5k. Car currently sits at 18k miles.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
#21 |
Manufactured Date 03/2012 VIN xxx0272, picked up 05/12. 66,000+ miles.
I have one taillight with intermittent condensation (driver's side) that started at around 59,000 miles. Pretty sure I just need to pull off the gasket and clean it, just haven't taken the time yet. It typically dries out in a couple of days. Also had the fuel pump replaced, but not because of crickets. I did it at 59,000 miles before the warranty ran out just to zero out the fuel pump. Other than that, no issues. I would buy another low serial number one tomorrow if I had the need to replace this one.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". Last edited by Dadhawk; 08-03-2015 at 02:19 PM. |
#22 |
Apostle
Drives: JesusMobile
2013 FRS, 49k Miles. OFT Tune at 36k Miles.
Build Date: 2/2013 - ECU ZA1JA01C Warranty Work 1) Driver Side Window Seal - The seal at the top of the door started to catch and drag on the window, which leaked air. This took a while to get replaced; I think the dealer forgot to order the small side window seal so there was a delay. 2) Driver Side Vanity Mirror - Super random! The hinge corner cracked one day; quick replacement by the dealer. 3) Steering Wheel peeling - This took forever to get fixed, I think a month? Dealer wanted regional / corporate approval or some crap, I guess debating if it was wear and tear or defective. They ended up replacing the wheel with a revised part with a material change, less pleathory more hard plasticky. I don't like it, and missed my Miata's Nardi, so I bought a TRD wheel. Typical Issues I have the crickets. My window seals squeak when wet, and has this funny streak pattern on the driver's side. The driver's side window switch rattles when the bass hits. I have replaced one windshield. I have a Safelite one now, seems okay. Atypical Stuff Tail lights have been fine. Coil packs are fine, and no DI seal issues so far. I think I will have them checked out as a precaution before my warranty ends. Cheap insurance versus a new engine. Looking back, I guess whoever assembled the driver's side of my car was hung over. |
#23 |
Drives: 2020 BRZ tS #54
First batch 32k miles rod knock. Dealer/toyota said "we want 10K$ this is not a factory defect due to lack of lubricant " no CEL no codes happen to others also on here..
| The Following User Says Thank You to marky For This Useful Post: | strat61caster (08-10-2015) |
#24 |
Hockey Playing Scientist
Drives: 2013 BRZ Limited 6MT (WRB)
I have a late 2013 production (May 2013), and I've had only minor issues.
-Reflashed ECU for idling issues -Rear view mirror base stripped and rattled (replaced and no rattles) -Crickets (replaced once in August 2014--better but not gone) No tail light condensation. |
#25 | |
Drives: Firestorm 2013 FR-S
How often had you changed the oil?
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
#26 |
Drives: DGM BRZ Limited
Mine is a 4/13 production. 13k miles. I have a strange suspension pop/clunk intermittently when pulling into my driveway. I have crickets. I have a new dashboard from the center lifting up over the vents, and the new one is doing the same. I have tail light condensation very intermittently. I've only noticed it 1-2 times. Seems like only when I wash the car. There are plenty of rattles. I have had the shifter replaced because of rattles. I had the rear view mirror assembly replaced because of a rattle. Both doors rattle pretty bad, so I keep the radio on. The driver's window squeaks really bad when wet and rolling up/down.
Overall, the car has shown to have a pretty decent size list of problems. Honestly though, it makes me like the car more for the imperfections. When the car was new off the lot it really felt like it had little personality... no real soul. But now as these little quirks reveal themselves the car seems to take on a personality. Strange how my brain works, I know. |
| The Following User Says Thank You to Coheed For This Useful Post: | Hoahao (08-09-2015) |
#27 | |
not playing cards
I'm surprised more people haven't reported the issue.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | 3essess (08-15-2015) |
#28 | |
Drives: 2018 BMW M2
4/13 build date, 14k miles. Rattles everywhere. Maybe someone had a bad month at the factory? ![]() Rattles rear seat latch trunk passenger side seatbelt panel driver seatbelt squeak front dash near windshield some control unit under dash steering wheel or windshield stalk navi rattling against the dash panel I tried to fix most of these but this still come back occasionally depending on the temperature or road conditions. Other than rattles, I also have crickets like everyone else, rubber dash on center a/c vent coming up and windows squeak when wet. I'm surprised that I don't have taillight condensation after parking outside through 2 New England winters.
| WORK Emotion XD9 - 18x10.0 +38mm 5x100 *** Last Batch *** | RavSpec | Wheels and Tires | 16 | 09-22-2015 02:06 AM |
| WORK Emotion XD9 - 18x10.0 +38mm 5x100 *** Last Batch *** | RavSpec | Exterior Parts - The Rest | 4 | 04-22-2015 11:01 AM |
| First batch of Buddy Club Lights. | Evasive Motorsports | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 11-14-2013 08:10 PM |
| [GTA]Next batch of BRZs? | 8987846 | CANADA | 65 | 09-09-2012 06:53 PM |
| Titan Performance second batch of pulleys | Amalgamo | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 07-30-2012 10:57 PM |
