Old 08-02-2015, 08:02 PM   #15
azn6r
Drives: 2005 STi, 2015 FR-S
Nicely done!! If you don't mind me asking, what plastic are you printing with? I have access to a Dimensions FDM printer but limited to ABS and I'm weary of it supporting the weight of a 6.5" especially over bumps with aftermarket suspension. How are yours holding up?
azn6r is offline   Reply With Quote
Old 08-02-2015, 11:19 PM   #16
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
If you can let me know the depth and how much clearance up front also that would be great. I could mount an mdf ring on top of the adapter for more depth if needed if there is enough clearance up front. Mine wouldn't have a tweeter on it either and would need something to support 5-6 pounds.
JoeBoxer is offline   Reply With Quote
Old 08-03-2015, 01:06 PM   #17
P@ul
Apostle
P@ul's Avatar
Drives: Fast Microwave
This is freakin cool, open source speaker mount upgrade! Thanks for sharing!
P@ul is offline   Reply With Quote
Old 08-03-2015, 08:52 PM   #18
TurboBRZ
TurboBRZ's Avatar
Drives: 2013 BRZ Limited
Originally Posted by Hen3ry View Post
Wow that looks great!
Did you also have to modify the panel that covers the speaker?
The panels have not been modified in any way. The new speakers sit in precisely the same locations as the factory ones in terms of distance from the panel.
The BlueBaru Turbo Rebuild: http://www.ft86club.com/forums/showthread.php?t=90382
I Rebuild BRZ's for Breakfast.
TurboBRZ is offline   Reply With Quote
Old 08-03-2015, 08:54 PM   #19
TurboBRZ
TurboBRZ's Avatar
Originally Posted by JoeBoxer View Post
I wonder about putting some free air 6.5" subs there, might be able to get some decent bass out of there if you deadened and sealed the area to make a nice enclosure out of it. I may give this a shot if you can let me know how deep of speaker you can fit there that would be great.
You can fit a really deep speaker in there, but if I went with some 8" subs I would also get the bracket built by a local sheet metal fabricator to withstand the weight. Behind the speaker is the rear quarter panel which is pretty darn wide and has a lot of space
Old 08-03-2015, 08:57 PM   #20
TurboBRZ
TurboBRZ's Avatar
Originally Posted by SilverFRS View Post
How does it sound? Do the rear speakers get full range signal?
The speakers sound awesome. I am printing off some mounting plates for my new front speakers so I can complete the system. Full sound as the coaxes are a woofer and tweet I believe.
Old 08-03-2015, 08:59 PM   #21
TurboBRZ
TurboBRZ's Avatar
I use ABS and put a 100% fill layer every 6-10 depending on the part with dense infill. This mount is 7mm thick off the top of my head and so far has held up just fine, although I haven't driven it a whole lot just yet. I got my base tune today.
Old 08-04-2015, 12:43 PM   #22
Hen3ry
Drives: 2014 FRS Monogram Edition
So you have a 6.5" speaker covered by a panel and firing out through a 3.5" speaker grill? How does it sound?
Hen3ry is offline   Reply With Quote
Old 08-04-2015, 02:24 PM   #23
TurboBRZ
TurboBRZ's Avatar
It sounds great. The position of the speaker allows the tweeter to be right near the center of the grill, which puts the woofer right behind it. So I still get full sound out of those grills and it's so much nicer with incredible clarity compared to the stock speakers they replaced.
Old 08-08-2015, 12:11 PM   #24
TurboBRZ
TurboBRZ's Avatar
Here is the front speaker adapter I made (another member on the forum gave me the inspiration) so I can replace the factory 6.5" with some Focal 6.5". It takes 20 hours to print a single side in 2 pieces!
Old 08-08-2015, 09:47 PM   #25
TurboBRZ
TurboBRZ's Avatar
Old 08-09-2015, 03:23 AM   #26
c4lvinnn
Drives: Toyobaruion
I'd buy a pair of 5 1/4" rear adapters if you want to make and cut some. I haven't put in my rear speakers yet because of the lack of adapter lol
c4lvinnn is offline   Reply With Quote
Old 08-09-2015, 04:51 PM   #27
ahaghshenas
ahaghshenas's Avatar
Drives: Subaru BRZ
Could you please share the model!!!
ahaghshenas is offline   Reply With Quote
Old 08-10-2015, 09:45 AM   #28
TurboBRZ
TurboBRZ's Avatar
I can make them, but I would need to know the diamater of the basket on the back of your speaker (the innermost measurement of the ring) - this way I can ensure they fit properly when you get them.
3D Printed Double Din Adapters cmspooner Electronics | Audio | NAV | Infotainment 22 09-11-2019 10:22 AM
3D Printed Speaker Adapters Shankenstein Electronics | Audio | NAV | Infotainment 57 09-21-2017 07:55 PM
6.5in Speaker Adapters for Door - Really Necessary? geruta Electronics | Audio | NAV | Infotainment 2 04-26-2015 05:13 PM
Subaru Audio door speaker adapters JoeBoxer Audio/Visual, Electronics, Infotainment, NAV 0 12-16-2012 11:13 PM
FS: 3/4" PVC Speaker Spacers/Adapters for the BRZ/FR-S phenryiv1 Audio/Visual, Electronics, Infotainment, NAV 1 08-22-2012 05:03 PM
