Old 07-18-2015, 08:55 PM   #15
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Originally Posted by mikeTee View Post
Just got in my BRZ to do a couple quick tests - the flashing green key basically is saying that it sees your keyfob in the car. Was the braking system damaged in any way? Maybe it's not detecting the brake as being pushed down or something.
Couldn't be this since without the brake you can't take it out of park. I'm really interested to find out what's causing this.
Old 07-18-2015, 09:22 PM   #16
im_topher
im gonna go check and see if my steering wheel is ever locking.. could be something around that.
im_topher is offline   Reply With Quote
Old 07-18-2015, 09:59 PM   #17
im_topher
Heres a diagnostic video. Steering wheel locks, car notices the brake is being pressed down. Strangest thing is probably the beeping when i turn it off.
[ame="https://www.youtube.com/watch?v=WonZHYzVfXo"]brz no start diagnosis - YouTube[/ame]
Old 07-18-2015, 10:13 PM   #18
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Pushed start.. didnt start
Does your dome light turn on ?
Beeping is normal that's because the door is open.
Old 07-18-2015, 10:24 PM   #19
im_topher
brb ill find out, also i tried pulling the ecu fuse for a few minutes and putting it back in, that didnt help anything.. i have some time tonight, is it worth going through and checking all the fuses?
Old 07-18-2015, 10:28 PM   #20
im_topher
No dome light at any point. Seems quite strange. And no stereo power.. any ideas on what might cause that?
Old 07-18-2015, 10:31 PM   #21
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
It's one fuse. I know exactly which one it is because I've replaced it on mine. Let me go out to my car and get you a picture. Does the car have a radar or anything ?
Old 07-18-2015, 10:50 PM   #22
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Check this fuse.
Old 07-18-2015, 10:51 PM   #23
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Check this fuse.
The middle one should be a 20amp
Old 07-18-2015, 11:09 PM   #24
Ultramaroon
not playing cards
Ultramaroon's Avatar
On the edge of my seat over here. I SO want this to work out.
Old 07-18-2015, 11:28 PM   #25
im_topher
OK, i pulled that fuse out and it was blown. I grabbed the 20 in the spare section, that one was blown too. I pulled the other 20 from here:
And put it in there, the second i seated it i heard a little pop, and i checked it, and it was dead.
I looked at the positive connection to the battery and the left side looks a little fucked, are those fuses in there? And is that one on the left/bottom blown?
Also that fuse is for the dome light, do you think fixing the dome light is going to help my problem?
Old 07-19-2015, 12:28 AM   #26
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
You have a bad ground somewhere. I'd have to have the car here to help out anymore sorry. Try changing that pswd jdm bolt to a standard bolt. I can take pictures of that too if needed. Remove your dome light and check the wires.
Old 07-19-2015, 12:34 AM   #27
Ultramaroon
not playing cards
Not a bad ground, a short circuit to ground.
Old 07-19-2015, 01:06 AM   #28
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Yeah I bet it's from an improper install of a radar detector or a cord coming loose during the crash. Maybe even the previous owner ripping shit out without caring. Unplug your battery then start searching for the short so you don't blow a bunch of fuses. Replace the ones blown and check all the other ones. Normally when you blow that specific fuse under the hood you'll blow these 2 as well. Well I did. Check these wires to start. There's also a connection behind the headliner where the arrow points check those.
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 06:06 PM
No maf no start? Silverdub Engine, Exhaust, Transmission 14 03-30-2013 11:21 AM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
Car Won't Start schtebie Issues | Warranty | Recalls / TSB 25 10-15-2012 04:06 PM
