CANADA Canada
Old 06-20-2012, 04:11 PM   #15
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
IF I decide to get aftermarket/race wheels, then the stock 17s will be the winter wheels. I checked some tire prices and the cost isn't much more for 205s over the 16s.
I wish we could have gotten the factory 16s then buy new summers.
Khyron686 is offline   Reply With Quote
Old 06-20-2012, 05:01 PM   #16
s2kdrew
Drives: 2013 hot lava FRS
but the thicker the sidewall of the tire, the better traction you will gain on the snow. Thats why we are considering downsize it to 16".
2013 FRS
2000 S2000
2004 RSX-S
2002 RSX
s2kdrew is offline   Reply With Quote
Old 06-21-2012, 12:46 AM   #17
Khyron686
Never heard that one before. Generally skinnier (width) tires work better as they bite in instead of turning into skis/snowboards. And you generally can get skinnier tires on smaller rims. But a 205 on a 16 and a 205 on a 17 will have the same grip regardless of the sidewall depth (unless you let a bunch of air out or something which you might do on a sand dune).
Old 06-21-2012, 05:32 PM   #18
CoryUyede
NisSubuGuru?
CoryUyede's Avatar
Drives: 2011 Subaru WRX
I've owned Blizzak, icebears, Yoko W drives, Dunlop winter sport and Pirelli Sottozeros.
Blizzaks are overrated, and wear WAY too fast.
Dunlop Winter sport 3D's are awesome. The W.drives and Pirelli's are almost as good but you can save a little $$ with those choices.
Falken also has a NEW Eurowinter tire out..Crazy agressive pricing, my brother liked em alot. I'd rather spend less on a japanese tire then get price gouged by a korean mfg.
The Hankooks were a letdown.
Also, for winter tires, consider stepping down to a 205/45/17 or something. something narrower than stock would be ideal.
Past to Present
CoryUyede is offline   Reply With Quote
Old 06-21-2012, 05:40 PM   #19
ubersoph
Blizzaks for extremes and Ice Racing.
Continentals for the rest
ubersoph is offline   Reply With Quote
Old 06-21-2012, 06:33 PM   #20
Future
Future's Avatar
Drives: BRZ!
which one are made in the usa?
Many will likely say the FR-S/BRZ needs more power and while more wouldn’t hurt, those folks (the same ones who have probably never driven on a track) are missing the point.
Future is offline   Reply With Quote
Old 06-21-2012, 06:40 PM   #21
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
blizzaks are not overrated
they are improperly used
for heavy snow and ice conditions they are a really good tire
not if you're in the city where you only ever really drive on "snow" 1 day out of the year. Asphalt and mild temperatures destroy them rather quickly, yes.
It's a purpose built tire and most don't use it accordingly.
Old 06-21-2012, 07:29 PM   #22
pastuch
pastuch's Avatar
Best I've ever had are X-Ice 2s. Terrific durability, performance, noise and handling balance. Great in deep snow. The new X-Ice 3 is out this winter and I'll probably get them.
I also had General Altimax and they were a let down. very very noisy
pastuch is offline   Reply With Quote
Old 06-21-2012, 07:39 PM   #23
Future
Future's Avatar
Drives: BRZ!
Best one i've had were General Altimax...
Old 06-21-2012, 09:46 PM   #24
sickmint79
Drives: bmw
i'm going to try and burn up the stockers and then get winters for them. i'll check the tirerack tests for value/performance and probably go from there. alternatively i may find some nokians, which unfortunately TR doesn't include nor test - but have popularly been the choice of ice racers so i speculate may be the best. i did have nokian rsi tires on my sti and they were great - paid a pretty penny too though!
might troll around craig's list too, depending on the condition of the oem tires by then. expecting to by a summer set of lighter wheels and stickier tires by spring.
sickmint79 is offline   Reply With Quote
Old 06-24-2012, 10:01 AM   #25
zootramp
Drives: Asphalt 2013 Scion FR-S Auto
Rims for 205 55R 16s
I have a set of nearly new P205 55R 16 snows that I used on my IS300 that also had 215 45 R17s as summer tires.
They are pretty well identical in diameter so they will fit well.
I will need new 5x100 rims and my question is what will fit on my FRS.
I think the base JDM Subaru uses 205 55R 16s.
Does any one know the rim specs (offset, etc) for 205 55R 16s?
I would like to get something that looks good instead of plain steel rims.
Any suggestions would be greatly appreciated
zootramp is offline   Reply With Quote
Old 06-24-2012, 10:19 AM   #26
#87
I usually post drunk
#87's Avatar
I think these are the best value out there but I'm not sure I want to get them with the BRZ. They are SOFT, if you like to corner enthusiastically these tires are definitely not for you.
#87 is offline   Reply With Quote
Old 06-24-2012, 10:54 AM   #27
pastuch
pastuch's Avatar
So noisy too...
Old 06-25-2012, 02:03 PM   #28
Klinn
Klinn's Avatar
Drives: '20 Pure Red BRZ, '20 Torch Red C8
Originally Posted by zootramp View Post
I have a set of nearly new P205 55R 16 snows that I used on my IS300 that also had 215 45 R17s as summer tires. They are pretty well identical in diameter so they will fit well.
I will need new 5x100 rims and my question is what will fit on my FRS. Does any one know the rim specs (offset, etc) for 205 55R 16s?
I would like to get something that looks good instead of plain steel rims. Any suggestions would be greatly appreciated
I believe you should be looking for about the same offset as stock (48) but could go for a narrower rim (cheaper). Certainly 6.5" will work and given the 55 aspect ratio, 6" wide rims should be fine too. The tire manufacturer's web site may list the recommended rim width range.
If you find some interesting rims while browsing, you can plug their specs into this site -- http://www.rimsntires.com/specs.jsp -- to compare the results to the FR-S stock wheel & tire package.
Alternatively, see if you can sell the old snows and use the money to get 17" ones for your stock wheels, then put the money you were planning to spend on "something that looks good" towards a spiffy set of summer wheels. We car buffs can rationalize anything.
Klinn is offline   Reply With Quote
Winter Tires and 17" Rims?? stalon320 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 06-03-2012 09:33 AM
Winter tires and wheels, what is your plan? RaceR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 06-01-2012 11:52 PM
How do dealerships deal with sales and test-drives of this car for winter? (tires.) rogerdalien Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 06-01-2012 01:07 AM
Stock tires winter feldy Scion FR-S / Toyota 86 GT86 General Forum 33 05-29-2012 11:38 AM
Winter Sucks OldSkoolToys Off-Topic Lounge [WARNING: NO POLITICS] 16 02-19-2010 01:02 PM
