Old 07-08-2015, 05:27 PM   #15
puma
crew chief
puma's Avatar
Drives: Race car FR-S
ok so let's try this again, here is the complete alignment setting after a call to the driver
Stock swaybars front and back, all 4 corners at 400lbs, rear is slightly higher than the front
front, 3,1 deg of camber, around 6 deg of caster and 2mm toe out on each side from front to back on a 17" Wheel
rear wheel is 2 deg camber and last time was 2mm toe in on each side, i beleive we were at 0 toe before and wasn't much better.
can't remember about shocks settings but i know they are soft since driver said the car didn't want to sit on the tire, seemed like the suspension was too stiff for the tires.
turns he has problem with are in third gear at low speed (hairpin) says he can't apply throttle early as car always understeer towards the exit
puma is offline   Reply With Quote
Old 07-08-2015, 06:01 PM   #16
Racecomp Engineering
The shock settings are important. Give Myles in the office here a call or send us a PM and we can help there. Reducing front rebound is my off hand recommendation but it would be good to know where you are starting from.
Putting your rear 500s on and leaving the fronts at 400 is an idea, but I wouldn't go there just yet. Also with those crappy tires I'm afraid it would be too stiff especially for an actual race (as opposed to a time attack or HPDE).
EDIT: From looking at the pictures in your other thread, I would definitely add some front negative camber and reduce front rebound.
- Andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
strat61caster (07-08-2015)
Old 07-08-2015, 06:04 PM   #17
puma
crew chief
puma's Avatar
well all those suggestions are giving me pointers, we are going to try a couple of those on our next practice, thanks everyone.
Old 07-08-2015, 06:06 PM   #18
swarb
Are those two other cars you can't keep up with on the same cheap tires? Tires are probably the most important thing.
Old 07-08-2015, 06:11 PM   #19
puma
crew chief
puma's Avatar
yes everyone in the serie is on the same tire
Old 07-08-2015, 06:26 PM   #20
Keep us posted.
- Andy
Old 07-08-2015, 06:35 PM   #21
solort
Drives: Series 10 FRS
I do think more toe out in the rear will help. 2mm is almost zero. I have run as much as 1/4 in total toe out in the rear of another car to get it to rotate. But stiffening the rear spring rates, rear shock rebound or stiffer rear bar also helps rotation (or soften front)
solort is offline   Reply With Quote
Old 07-08-2015, 07:46 PM   #22
strat61caster
strat61caster's Avatar
+1 on putting the 500# on the rear from an armchair quarterback, I seem to remember CSG (or maybe Racecomp) claiming that 20-25% stiffer rear spring is going to give a balanced dynamic which leads me to assume that an even spring rate Front/Rear would result in a softer rear (read: more planted rear) than front inducing some understeer, I'm drawing a blank on the specific post but here's what some quick googling came up with.
Here is CSG's Tein kit:
http://www.ft86club.com/forums/showthread.php?t=82796
And here's a discussion on the idea but it didn't seem to get very far:
http://www.ft86club.com/forums/showthread.php?t=56678
Rear toe out will definitely help rotation, looks like it's a track only car so definitely try it. Zero toe in the rear was rather darty and unstable feeling on the freeway to me so I've got some toe-in for DD purposes, I may be reducing it in the future...
ineedyourdiddly
CSG Mike (07-08-2015)
Old 07-08-2015, 08:09 PM   #23
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
My vote is driver training with this platform. I find understeering at corner entry into a hairpin is always my error, usually not enought trailbraking. Otherwise, what brake pads are you running front/rear?
Sleepless is offline   Reply With Quote
Old 07-08-2015, 08:17 PM   #24
puma
crew chief
puma's Avatar
we are currently running DTC60 but entry isn't the problem he says it is on exit that the car understeer, he has to wait too long to apply the throttle.
Old 07-08-2015, 08:35 PM   #25
wparsons
wparsons's Avatar
Is the corner slow enough he can drop to 2nd and use the extra torque to rotate the car on exit?
If not, I'd try a bit less rear camber or stiffer rear spring rates. In the other thread there's a shot of it lifting the inside front tire on exit, that can't be helping front grip.
flickr
Old 07-08-2015, 08:41 PM   #26
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Sorry if you've already addressed this, but how do your cross weights look? I didn't see any mention of them, or pictures of scales anywhere.
GSpeed is offline   Reply With Quote
Old 07-09-2015, 09:51 AM   #27
Jack Black
Drives: 2015 FR-S
Originally Posted by Racecomp Engineering View Post
BTW if the driver is coming from a fast FWD racecar that I assume is extremely loose on entry (as those platforms should be), then there may be some driver adjustment as he adapts to a different RWD platform. It sounds like your results are still very good so I wouldn't get too drastic with changes.
- Andy
This was my first thought as well. Probably needs to use more trailbraking, especially coming from a FWD, which is typically set up so that you don't use much trailbraking.
Jack Black is offline   Reply With Quote
Old 07-09-2015, 12:27 PM   #28
puma
crew chief
puma's Avatar
i thought i took a picture of it but it seems like it is before the supercharger install, i'll try to take one after the next race.
WTT: White delron BeatRush spin turn knob for red aluminum Cusco spin turn knob SLVRSRFR Canada Classifieds 3 11-13-2015 03:45 PM
Making turn signal your DRL with Flashback LED bulbs coachzizi Cosmetic Modification (Interior/Exterior/Lighting) 9 01-10-2014 09:54 PM
Voice Commands with new turn by turn in IOS6? jadewbj Electronics | Audio | NAV | Infotainment 0 09-21-2012 10:11 AM
