#15 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
I have the same issue, my passenger door lamp is always on after doing an LED swap...and I remember accidentally shorting the two pins when removing the old bulb with a flat-head screw driver so I know when and why it occurred.
My car is a 2013 and I'm at 50k miles so I am out of warranty as far as I know. At a cost of ~$400 for a new unit, I am going to remove the bulb on both sides and live without both door lights. Actually, when I have some time I may re-wire them. The switch in the door jam can be used as a switch to turn the light on and off, eliminating the BIU. I'm pretty sure when the door opens, that door switch creates a ground. I wonder if there are any side affects associated with this issue, or if it is limited to only the light being on all the time. Last edited by B-R-Z; 07-01-2015 at 06:51 PM. |
#16 | ||
Drives: 2015 Series.Blue
Honestly, there's probably some safety specification for stuff like this that says it's required to be fused. Years down the road this could be a recall... http://www.fteightysix.com/appearanc.../#.VIAb_It0yUk Quote:
I've heard that it's possible to repair the module, but I don't know the details. It would require soldering, but I bet it's quite easy once the issue is found. |
#17 |
wow, it sucks that a simple LED can short out such an expensive unit lol. luckily I didn't run into this problem when I swapped in my LED's. dodged a bullet there
#18 |
I think it's a result of shorting from touching the +/- contacts when removing the old bulb. I don't see how a bulb change to led would do this.
If anyone has any info on how to repair the module please share. I'll make a DIY out of it. |
#19 |
Does anyone know exactly which module it is under the dash? Maybe it's just a blown diode or something simple.
| Door Unlock Issue | TONYpepperon1 | Issues | Warranty | Recalls / TSB | 20 | 01-05-2018 07:06 PM |
| Need help on door lighting | phanguy | Electronics | Audio | NAV | Infotainment | 18 | 10-30-2014 11:10 AM |
| Door lock issue | BRZ323 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 04-13-2014 10:07 PM |
| FS: Cool White LED Lighting (dome, door, and trunk lights) | fourvalleys | Interior Parts (Incl. Lighting) | 0 | 11-18-2013 06:55 PM |
| Door Rattle Issue | DriftEightSix | AUSTRALIA | 4 | 06-28-2012 01:11 AM |
