Old 06-28-2015, 11:49 AM   #15
JackieMoon86
86 Noob
JackieMoon86's Avatar
Drives: 2015 Scion FR-S
Kraftwerks Supercharger.
| GReddy Supreme SP Exhaust | K&N Drop in filter | Eibach Pro-kit Springs | B2autodesigns 20&25MM Spacers | OEM style rear diffuser | CS Style Front Lip & Side Skirts | HT Autos Style Rear Spats | Valenti Tail Lights |
JackieMoon86 is offline   Reply With Quote
Old 06-28-2015, 09:41 PM   #16
Joakim3
Joakim3's Avatar
Drives: 04' Saab 9-5 Aero
- Rims/Tires ~2k
- ST coilovers ~1k
- Header ~1k
that or save up a little and go the FI route
_____________________
You know what they say... pick two: cheap, fast, reliable.
Joakim3 is offline   Reply With Quote
Old 06-28-2015, 10:35 PM   #17
covance
Drives: 2015 BRZ series.blue
This thread is fantastic. Learned a lot from Googling adventures off most of the responses here
covance is offline   Reply With Quote
Old 06-29-2015, 02:13 AM   #18
humfrz
Originally Posted by Roto'sFRS View Post
What would you do with a $4K budget and a stock FRS?
Jeramie
CONGRATULATIONS, Roto'sFRS on your purchase and ....... to .... The Forum.
Well, since you ask, I'd round up a co-pilot and head for Jasper NP in Alberta .... then follow the Rockies down until you run out of time or money.
humfrz
LucidMomentum (07-06-2015), strat61caster (06-29-2015)
Old 06-29-2015, 03:13 AM   #19
iag48st
Drives: 10Series 0945
4.88 is my next mod for my AT. Kodyo does Weir have EVERY single piece needed to have a shop install it?
iag48st is offline   Reply With Quote
Old 06-29-2015, 08:19 AM   #20
kodyo
Drives: Scion FR-S
Yes and no. I believe a shop will need to buy new shims to shim the diff/ring gear left to right. These shims are more specialized and I doubt he sell them, I got mine from Toyota. All other shims and parts he sells, including seals, bearings, gears, and spacer. If you're reusing your stock pumpkin, I'd reuse the bearings but still have a shop replace the three rubber seals. I'd recommend getting a solid spacer as well instead of the crush spacer. This also has to be shimmed, but will make your diff mor robust (this spacer sets preload between the two pinion bearings).
kodyo is offline   Reply With Quote
The Following 2 Users Say Thank You to kodyo For This Useful Post:
drewbot (06-29-2015), iag48st (06-29-2015)
Old 06-29-2015, 08:22 AM   #21
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
I did a 4.56 myself its perfect for the car na but ill be selling it to go turbo this yr
IG-Joey_Soul
The Following 2 Users Say Thank You to Grip Ronin For This Useful Post:
iag48st (06-29-2015), kodyo (06-29-2015)
Old 06-29-2015, 10:50 AM   #22
NOHOME
Drives: RAVEN
I am selling another one of my toys and thinking about dumping the proceeds into the FRS. I'll probably end up with around $4K. I bought the FRS two weeks ago and it is bone stock. I would like to tighten up the handling even more than it is so some wider wheels are in order. I would like to address the torque dip too. I would like to keep any exhaust upgrades in the mellow end of the sound spectrum. Best ways to stiffen up the chassis? Suspension?
Jeramie
Put it in the bank towards my next new car. My favorite car accessory is a tittle in my name; not the banks.
Failing that, I would use the money to drive the FRS to the airport and get on a plane to someplace nice.
NOHOME is offline   Reply With Quote
The Following User Says Thank You to NOHOME For This Useful Post:
strat61caster (07-05-2015)
Old 06-29-2015, 10:53 AM   #23
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
I'd save the $4,000 and just enjoy the car as is for a while. You've had it for two weeks man!.
Plus that's a nice amount of extra money to have lying around in your pockets seeing as you just bought a car.
MokSpeed is offline   Reply With Quote
The Following 3 Users Say Thank You to MokSpeed For This Useful Post:
soulreapersteve (06-29-2015), stevemp5 (07-09-2015), strat61caster (06-29-2015)
Old 06-29-2015, 12:04 PM   #24
Bergen23
Drives: '15 Halo FR-S
I'd probably buy a bike. Not going to bother with anything other than what I already have done to my car anymore since making the decision to get another motorcycle
Bergen23 is offline   Reply With Quote
Old 06-29-2015, 12:29 PM   #25
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
If I had 4k extra to spend, I'll use it to pay off my car....
The Twins make me smile
The Following User Says Thank You to soulreapersteve For This Useful Post:
Old 06-29-2015, 12:38 PM   #26
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
$4k to spend...
Is the car paid off?
Cash or credit?
What are your priorities in life?
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
Old 06-29-2015, 12:44 PM   #27
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
spend a little of that $$$ then invest bulk of $$$ in stocks.
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 06-29-2015, 05:32 PM   #28
DimSumHero
DimSumHero's Avatar
Drives: 2015 Scion FR-S Halo
Obviously I would get hookers and blow
DimSumHero is offline   Reply With Quote
The Following User Says Thank You to DimSumHero For This Useful Post:
Aozora.BRZ (07-05-2015)
Open Flash Question denellum Software Tuning 7 03-10-2015 12:05 AM
open source software question GeeTee86 AFRICA 15 02-15-2015 06:52 PM
If you had $10K to spend jbdrs Scion FR-S / Toyota 86 GT86 General Forum 57 12-10-2013 01:01 PM
Open Flash Tablet Question davidchoi Software Tuning 7 10-29-2013 01:58 PM
An open question to all the carbon part makers of the world djliquidsteele Cosmetic Modification (Interior/Exterior/Lighting) 6 03-29-2013 02:23 PM
