Old 09-19-2017, 01:11 AM   #15
arthur93
Drives: Toyota 86 GTS
Does anyone know if this will work with the raceseng reverse lock out? On Raceseng's website, it states that it won't work with any short shift kits. My understanding is the TRD is not a short shift kit (doesn't alter the height), but it alters the throw.
Can anyone confirm this?
arthur93 is offline   Reply With Quote
Old 09-19-2017, 10:29 AM   #16
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
If you're referring to the TRD US kit which simply shortens the linkage, then yes, the Raceseng reverse lockout will work. If it's the JDM proper short shifter, I'm not sure.
MS, CSCS, TSAC-F, CPT
Old 09-19-2017, 11:37 AM   #17
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Originally Posted by Createddeleted View Post
Because it's not designed well. IMHO. It's an extension piece to the shifter lever and it puts the linkage lower changing the angle to the fulcrum point. In my case, it seemed like a 40% reduction in throw but at cost; the shifter took an increased amount of effort to go into gear and it made the gear engagement nothcy (in a bad way). The trans eventually will adapt to some of this notchiness by wearing in. Secondly, you must watch out for the casting of the lower shift linkage as the head can walk the bolt out leaving you with a wobbly shifter. I had an FRS that this was diagnosed on that needed clearancing of the shift linkage to install properly.
All and all, you must remember the TRD quick shift is advertised at 35-40% reduction. The full JDM STI shifter is, iirc, 20% reduction and the TRD 25%-30%. And while the USDM quick shifter is an adapter, the JDM options are an entire shifter assembly.
I did not like the feel and didn't believe the part was well engineered.
This 100%. Bad product.
Old 09-19-2017, 11:40 PM   #18
Ultramaroon
not playing cards
Ultramaroon's Avatar
Total POS.
In b 4 "excellent product was not installed properly."
FS: TRD Quick Shift Kit & Perrin Goodies superfly320 Transmission and Driveline 7 07-12-2015 03:14 PM
WTB: TRD USA quick shift kit Hawk77FT Want-To-Buy Requests 1 06-18-2014 01:57 AM
WTB TRD Quick Shift Kit SpectreRT Want-To-Buy Requests 0 04-22-2014 04:54 PM
FR-S TRD Quick Shift Kit mit_peid Engine, Exhaust, Transmission 7 02-05-2014 08:53 PM
Quick Release or Quick Lock Steering Wheel and Theft defense too? 1086 Cosmetic Modification (Interior/Exterior/Lighting) 4 01-24-2014 04:50 PM
