Old 06-15-2015, 02:51 PM   #15
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
In before people start asking for a GB to make it "affordable"
Old 06-15-2015, 02:58 PM   #16
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
In before the in before posts.
On a serious note, has this been tested? Are there at least any theoretical numbers?
Old 06-15-2015, 02:59 PM   #17
STV3
Señor Member
STV3's Avatar
Originally Posted by brianhj View Post
Forgive my ignorance, can these handle more torque?
Yes
STV3 is offline   Reply With Quote
Old 06-15-2015, 03:01 PM   #18
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
how much? subscribed as well
Old 06-15-2015, 03:03 PM   #19
STV3
Señor Member
STV3's Avatar
My Guess would be 5-6k range
Old 06-15-2015, 03:06 PM   #20
zc06_kisstherain
Drives: SWP BRZ
Holy Moly!
Old 06-15-2015, 03:20 PM   #21
Chad_W
Drives: 2013 BRZ DGM
I thought straight cut and synchromesh were exclusive, how does that work?
Chad_W is offline   Reply With Quote
Old 06-15-2015, 05:11 PM   #22
RockySDS
Almost ******
Drives: 2014 Subaru BRZ
They're straight-cut gears with syncros. So it's not technically a dogbox as it still has the synchros but has the strength of the straight cut.
RockySDS is offline   Reply With Quote
The Following 3 Users Say Thank You to RockySDS For This Useful Post:
CxG (10-30-2015), Koa (06-17-2015), why? (09-05-2015)
Old 06-15-2015, 05:54 PM   #23
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
Well that was quick! When are you installing it?
crazyfrenchbiker is offline   Reply With Quote
Old 06-15-2015, 07:31 PM   #24
jdp530
Drives: 2014 BRZ
We all want a sequential trans.
jdp530 is offline   Reply With Quote
Old 06-15-2015, 07:55 PM   #25
burdickjp
Drives: 2013 ultramarine Scion FR-S
Originally Posted by Porcupint View Post
I went to the thread. It talks about the symptoms, but doesn't say what actually broke in the transmission. For all we know, it could have been a shift collar, which this gear set wouldn't fix.
burdickjp is offline   Reply With Quote
The Following User Says Thank You to burdickjp For This Useful Post:
NyC Zn6 (06-16-2015)
Old 06-15-2015, 08:21 PM   #26
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
Gear cuts are straight or helical
Engagement is synchomesh or dog
A quick primer on these things.
http://www.superstreetonline.com/how...sh-vs-dog-box/
Now on to the music! The PARs aren't super loud, but he does have a an open wastegate drowning them out.
[ame="https://www.youtube.com/watch?v=rpzzHuaPLnc"]2011 WRX - PAR Straight Cut Gears - Cusco and Kartboy Mounts - Video 2 - YouTube[/ame]
So, about this gearbox, second AND fourth break? Cripes, man. I am so relieved I never had any intention of cranking up the power more than 25%. New cars are so fragile with the manufacturer building them "just" strong enough to try and save costs. Step one is re-engineer a hand grenade transmission? I already have a hand grenade oil pump on the GT-R, I don't need another EOD mission on my daily driver.
Can't wait to see your results. If you don't post video, though, the kitten gets it. Think of the kitten!
Old 06-16-2015, 10:23 AM   #27
lamawithonel
Drives: 2014 Subaru BRZ Ltd.
It depends...
All else being equal, straight-cut teeth are "weaker" than helical teeth. In a helical gear (diagonal-cut) the teeth gradually come together at the sides, rotating through and gradually lifting at the opposite side. With straight-cut gears the teeth smack into each other all at once. This creates the characteristic whine, but also a lot of shock stress on the teeth. Helical gears also distribute the forces through more material. All else is probably not equal here, though. I'm guessing the alloy and manufacturing process for these are far better than the stock gears.
There's also a trade-off with helical gears as they transmit forces axially (red arrows), putting stress on the bearings and transmission case. Lower angled gears reduce these forces, and straight-cut gears nearly eliminate them. With our boxes, though, AFAIK this hasn't been been an issue. But if the teeth can hold, it's one less thing to worry about down the line.
Anyway, I'm interested to see how these perform. Keep us updated.
*question everything*learn something*answer nothing*
lamawithonel is offline   Reply With Quote
The Following 5 Users Say Thank You to lamawithonel For This Useful Post:
brianhj (06-16-2015), CxG (10-30-2015), jcw99 (03-04-2016), RockySDS (06-17-2015), SVLTE (06-16-2015)
Old 06-17-2015, 01:14 PM   #28
Streetthrowback
Drives: 2015 brz
subbed
Streetthrowback is offline   Reply With Quote
P&L Headers Arrived today! mrjester FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 07-12-2013 06:21 PM
Package Arrived Today zerodark Engine, Exhaust, Transmission 7 04-24-2013 02:32 PM
New England Subaru Allocations arrived at port today ngabdala New England 22 08-15-2012 11:58 PM
My Firestorm arrived today, but the radio didn't Nitro Scion FR-S / Toyota 86 GT86 General Forum 24 06-06-2012 12:45 PM
My SWP BRZ arrived today! (Connecticut) speedracer38 BRZ First-Gen (2012+) — General Topics 19 06-02-2012 10:28 PM
