#15 |
Custom User Title
Drives: Asphalt FR-S MT
I wouldn't be so quick to say seconds, but yes the time is limited.
#16 |
Drives: BRZ + Ducati M796
Again it depends on the heat setting. Ive done this on two Supras, a lancer, 240sx, a 636 and my buddies r6. We used low heat for 5 minutes. Just enough to soften the glue but not melt it. So yea it depends on the setting. Put it on 500 for 20 minutes and it may just fall apart and my statement will have no weight.
#18 |
Regional Moderator
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
Update on this. Had my buddy. He baked it 3-5 different times. Still couldn't get it to close back up. Basically the headlight is screwed.
#19 | |
Time Traveller
Remove all of the old adhesive and replace it with an even amount of Butyl tape. 3M Window Weld is the product many use for headlights. [ame="http://www.amazon.com/3M-08621-Window-Weld-Ribbon-Sealer/dp/B00063Z4FM"]Amazon.com: 3M 08621 Window-Weld 5/16" x 15' Round Ribbon Sealer Roll: Automotive[/ame]
Do it like this and you should be good. http://www.hidplanet.com/forums/show...uild-Thread%29 |
#20 |
Curious if after all the "fix" work... if one of the methods work... if the darn thing will separate again -- due to the heat.
Nothing close to this happening on the other side?
2013 Asphalt / MT
Olympia, Washington |
#21 |
Inactive
Drives: .
You can try to re-seal them, but either way they will either crack or the lens finish will fade dramatically or the wiring will burn up, I have even seen entire projectors fall loose. they usually last a little over a year on most of their lightning applications and they do not hold up at all like OE lighting or products of reputable manufactures.
| *****Official Spec-D headlight groupbuy | 86SPEED | Groupbuys | 197 | 11-28-2015 01:48 AM |
| Spec D headlight HID Install instructions/wiring? | jibai | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 04-05-2015 03:38 PM |
| My Spec D headlight review | Gixxersixxerman | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 10-07-2014 07:31 PM |
| Spec-D Headlight Question | iStanley | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 05-10-2014 07:44 AM |
| WTB Stock headlight projectors from retrofit OR a broken headlight | official_george | Exterior Parts (Aero, Lighting, Etc.) | 3 | 12-02-2013 04:32 PM |
