Old 07-23-2015, 07:12 PM   #15
phrosty
resetting ECU is the difference between re-learning from 0 LTFT vs +2 LTFT.
LTFT actually adjusts very quickly. I wouldn't worry about it, just don't go WOT right away.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
The Following User Says Thank You to phrosty For This Useful Post:
timmydatooth (07-23-2015)
Old 07-23-2015, 09:36 PM   #16
Poodles
Drives: 2015 Series.Blue
Originally Posted by timmydatooth View Post
Bringing this back. Im putting a cat back exhaust on my frs this weekend. Is the ecu reset really necessary? The answers ive seen have been all over the place. Will the ecu eventually learn by itself over time? I just dont feel like redoing all my settings on the radio lol
Cat back isn't going to do much, so no need to reset. ECU is constantly retuning anyway.
Also, if the FRS radio is anything like the BRZ, the settings are saved. Dash settings aren't though.
Old 07-24-2015, 01:11 AM   #17
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Higher flow intakes are a myth. Besides perhaps GS, in which case you don't need to rescale MAF. The PERRIN ones can royally screw your AFR without tuning. The ECU can't learn MAF scales.
ecu, ecu fuse, intake system, question, reset
Reset ECU...? Capstan Scion FR-S / Toyota 86 GT86 General Forum 11 08-29-2021 11:36 PM
Problems after ECU Reset ButtonMasher Issues | Warranty | Recalls / TSB 16 09-26-2016 01:37 PM
Anyone have the nav reset? Gunman Electronics | Audio | NAV | Infotainment 3 08-03-2013 09:26 PM
ECU reset after Break-In paros28 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 02-19-2013 06:41 PM
When do you reset the Avg MPG? WRXcellent BRZ First-Gen (2012+) — General Topics 50 01-16-2013 11:30 PM
