#15 |
Because compromise ®
Drives: Red Herring
Given my memory I have no idea but then again I've never had much interest in Mishimoto products. If the dynos were posted by Mishimoto call me a sceptic.
#16 |
Drives: 2014 GT86
Found it, if it's of interest. Seems both on mishimoto & oem and both with oem filter & highflow one best resonator left+soundtube delete, close to it were both left or just resonator delete, and worst - both deleted. Gains/losses were slight enough to possibly fall within dyno error (and to care much for) though, but as trend was somewhat same for oem tube/mishimoto one and with oem airfilter & aftermarket one, it might be true aswell.
| The Following User Says Thank You to churchx For This Useful Post: | Captain Snooze (02-27-2018) |
#17 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
#18 |
Drives: 2017 ISM PP BRZ
It's a poor (as in zero) return on investment, but whatever floats yer Brrrrz...
Raceseng Circuit Sphere 100 shifter arm, Radium catch can and master cylinder brace, Perrin oil cooler, Vorshlag front camber plates, ACE A350 header & overpipe, Berk catted front pipe, CSGxMXP exhaust, Delicious NA Stage II tune & Flex Fuel
#19 | |
| The Following User Says Thank You to JSube For This Useful Post: | churchx (02-28-2018) |
#20 | |
Drives: 2017 BRZ |Yellow series/Limited|
Now... To explain the science. Air is not very dense so changes to the size and shape of its container can result in changes in pressure on moving air (pressure waves). The intake resonator also helps to reduce turbulence in the intake so you need it. This will in turn cause changes in pressure in the cylinder robbing you of power because their might be less volume of air in the mixture. These constant changes will also ruin your gas mileage. 2 days and I see a huge improvement in gas mileage even using e85. By the way... The same principle can be applied to the exhaust. That is why people use heat wraps and thermal coating. It keeps the heat trapped in the header so the gases can evacuate more quickly creating negative pressure (pressure waves), and thus removing more exhaust to ensure a more efficient combustion on the next cycle. |
| Intake Tube - Is the resonator necessary? Perrin, Mishimoto, et al.... | Chad_W | Engine, Exhaust, Transmission | 25 | 07-21-2015 12:37 PM |
| FS: Perrin 3in Catback Exhaust, Perrin 3in Front Pipe, Perrin Overpipe SOLD | johnb831 | Engine, Exhaust, Bolt-Ons | 13 | 05-21-2015 06:27 PM |
| Mishimoto Radiator & Blue Mishimoto Hose Kit | tlinspired830 | Engine, Exhaust, Bolt-Ons | 6 | 03-24-2014 11:34 PM |
| Mishimoto Radiator & Mishimoto Radiator Hose Kit | tlinspired830 | Engine, Exhaust, Bolt-Ons | 5 | 01-08-2014 09:44 AM |
| Hello from Mishimoto! | Mishimoto | Announcements, Contests, Giveaways | 12 | 07-05-2012 07:18 PM |
