Old 06-01-2015, 04:26 PM   #15
cnk
Drives: '13 DGM BRZ Limited
What you need to do is flash the car. Then follow these steps:
1. Start engine and don't touch the gas. Let it idle for 5-10m so that it can learn and settle into a stable idle.
2. Shut engine off.
3. Turn car to On, but don't start engine.
4. Depress the gas pedal all the way and fully release. Do this about 10-20 times.
5. Turn off
6. Start car as usual.
The pedal trick helps the ECU learn the full range of pedal travel faster.
cnk is offline   Reply With Quote
Old 06-01-2015, 07:54 PM   #16
steve99
Originally Posted by Vroomin86 View Post
Thank you very much, I downloaded the template you linked and was able to upgrade it to the OFM how you explained.
Thanks Steve I appreciate the tip. Cable was securely plugged in.
Thank you, is it the same one that @Bader linked?
Have a read of the Flashing-Reset-learning link below and the oft tips link
Golden rules
Never start car during read or write process
Key on means full on not just accessory but do not start or have engine running
Never flash car with a weak, suspect or flat battery
docnot intterupt process
do not mess with anting in car lights switches radio ect during flash or read
ecu needs stable voltage during flash or read
Windows 8 OFT troubles Maboy_nelson Software Tuning 10 05-07-2015 07:22 AM
Helmet troubles... Sonolin Tracking / Autocross / HPDE / Drifting 1 10-11-2013 08:10 PM
Lug nut troubles Krait1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 07-14-2013 01:46 AM
Dealer Troubles shawnperolis Scion FR-S / Toyota 86 GT86 General Forum 39 02-23-2013 03:42 AM
iPod troubles mvhull Electronics | Audio | NAV | Infotainment 20 11-29-2012 08:01 AM
