Old 05-03-2015, 08:10 PM   #15
housecat
Computer Scientist
housecat's Avatar
Drives: 2014 BRZ Limited
Originally Posted by extrashaky View Post
That's not the only assumption you're making. You are also assuming that the error doesn't change with the driver or the type of driving. It could be that these things are exactly accurate for certain drivers and way off for others.
There is also a geographical element. People in different parts of the country are using different fuels. For example, it could be that the computer was calibrated using fuels available in California during the summer months, and during all other times of the year and in different locations the additive package throws off the calculation. You also have the problem that some people live in relatively flat places (like me), while others live in mountainous areas. Altitude will also make a difference, since 91 octane at 5000 feet behaves like 93 octane at sea level.
To do this right, you'd have to control for as many of these variables as possible. Or control for the big ones and then try to explain the outliers.
Ok, disregard my previous reply. I see where we disagree now. I am assuming that the error doesn't change from driver to driver, type of driving to another, fuel type to fuel type, or location to location, and you think this is a bad assumption. However, I think that this is a fair assumption. No one here has falsified this assumption; so far everyone has reported that their dash reads too high for mpg. I'm not saying there doesn't exist a person who's dash reads perfect or actually underestimates, but I don't know of one yet. It would help if I could find some information about how the BRZ calculates its mpg. Fuel type and driving conditions might not make a difference, maybe the computer just polls how much fuel is currently being consumed and how fast the vehicle is moving.
It will take a bigger experiment to figure out why the dash is reading higher than expected. Maybe the source of error is that the mpg measurements are made discretely and not often enough, resulting in an overestimated approximation. Sort of like approximating the area under a curve numerically and not using a small enough dx (change in x). The experiment I am performing now is to conclude with evidence that the dash reads higher than expected.
Keep calm and drive safe
housecat is offline   Reply With Quote
Old 05-04-2015, 10:11 PM   #16
superleggera
superleggera's Avatar
Drives: BRZ / MX5 / S4
that is pretty similar as to my results. Out of 42 fillups, my brz is reading on average 1.73 mpg higher than actual. the highest was 3.1 higher, lowest was 0.68 higher.
superleggera is offline   Reply With Quote
Old 05-21-2015, 03:54 PM   #17
ArgentoAtl
ArgentoAtl's Avatar
Drives: Argento manual
Thumbs up 5% optimistic
I have been recording my fuel usage since I got my 2013 FRS and have not reset my avg mpg indicator yet, afaik. For about 70 fill ups I have averaged 5% lower real mileage than the average mpg readout on the car, with about 2/3 of my driving on highways.
Thanks for suggesting this comparison, OP.
Brian in Atlanta
ArgentoAtl is offline   Reply With Quote
Old 02-11-2016, 07:26 PM   #18
housecat
Computer Scientist
housecat's Avatar
I've uploaded a lot more mpg data here https://docs.google.com/spreadsheets...P78/edit#gid=0
I started taking notes about what kind of driving I was doing, where I refilled with fuel, what kind of fuel I filled with.
The avg OEM mpg is the average mpg I got on petrol, stock tires, stock everything except air filter. The avg e85 stg2 mpg is the average mpg I got on e85, stock tires, stock everything except air filter, OFH and OFT stg2 tune. The avg stg2 mpg is the same thing but on a 91oct tune.
Old 02-11-2016, 07:49 PM   #19
swarb
Too many variables.
Transmission.
Type of driving.
Air pressure in tires.
Driver.
Location.
Fuel matters.
Here is my fuelly http://www.fuelly.com/driver/swarbrz
I gave up after a few tanks of e85 as the website uses current fill up to calculate costs, and previous fuel to calculate mpg, which throws some metrics off.
I was right around 28mpg 90% highway at 80mph on 91octane manual transmission.
The Following User Says Thank You to swarb For This Useful Post:
YXEBears (02-12-2016)
Old 02-12-2016, 01:18 AM   #20
boxerfan
BRZ MPG Data Analysis
Am guessing the car computer excludes stationary idling fuel consumption; therefore the average will read better overall.
boxerfan is offline   Reply With Quote
Old 02-12-2016, 07:57 AM   #21
WillTL
Drives: Subaru BRZ
Hi all, UK owner here and from my experience, I can confirm that the dash always shows a higher figure than the actual mpg. This isn't just the BRZ that does this, but pretty much all cars. If you have a sat nav that shows your actual speed, you will see that you are also driving slower than the car reports.
As an example, a display from the car of 70mph is actually only 66mph.
As for fueling, a UK gallon is slightly bigger than a US gallon (something like 1 UK gallon = 1.2 US gallons) so my mpg figure is going to show slightly higher than what you can achieve in your cars.
The BRZ manufacturer's figures show that an extra urban figure of 44.1mpg is achievable and in most cases, you can never achieve what the manufacturer's figures show because the test is carried out in perfect conditions (e.g. exactly one gallon of fuel, no extra passengers or weight). In a recent 440 miles journey which I completed on one tank of fuel, the car reported a 47.3mpg return, but the actual was only 45.4 meaning that the car's figures are 4.2% out.
This is slightly disappointing, but I was very pleased I was able to beat the manufacturer's figures.
WillTL is offline   Reply With Quote
Old 02-12-2016, 09:06 AM   #22
I've been tracking mine in my Owner's Journal Post 1 since I purchased the car (6AT) in 05/2012.
Results so far:
77,057 miles. 198 Fuel Stops.
Average Mileage Overall (Calculated): 32.72MPG
Average Mileage Overall (Computer): 33.80MPG
Average Fuel Cost $0.10 per mile.
Best Average: 36.6MPG (All Highway)
Worst Average: 27.6MPG (About 50% stop and go city)
Most of my travels is commuting which sees an average speed of around 45MPH.
With the original Primacy tires I averaged 32.65MPG (around 62,000 miles). Surprisingly, once I switched to Bridgestone Ecopia all-season tires (@15,000 miles) I've average 33.40MPG.
I've also "saved" $5,184 and 1,655 gallons of fuel over my previous daily driver that averaged around 18MPG even when adjusting for the difference in regular vs premium fuel.
Tcoat (02-12-2016)
Old 02-12-2016, 09:24 AM   #23
Mim
Mim's Avatar
Drives: MY11 Maxima 350st, MY15 BRZ
I only live 11km from work and used to let the car warm right up when I first started driving it a year back. My fuel economy back then was pretty terrible vs now when I simply wait for the rpms to settle down to around the 700rpm mark then drive off.
Pretty sure the lengthy idling during warm up was / is being calculated by the onboard average fuel consumption metrics.
MY15 CWP A/T BRZ | Leather heated seats | STI CAI filter, A/T leather shifter, strut brace, V-brace, draw stiffener, battery tie down, Radiator cap, Oil cap, push start button | TRD door stabilizer | YoSpeed STI console garnish | Pioneer AVIC-F70DAB + Rev-camera, TS-WX710A sub | JL speakers, Amp | TOMS' Clear Brake Lights | Cusco 4.556 FD | Driveshaft Shop aluminum shaft | Tein FlexZ, EDFC AP+GPS | Crawford BPB
Mim is offline   Reply With Quote
Old 02-12-2016, 09:37 AM   #24
Same here.
Last winter was cold and snowy so mine sat long enough for the defroster to melt some ice. I averaged (by computer) 7.3 liters per 100 kilometers (32 mpg). This year it has bee almost ice and snow free so I jump in let it drop from high idle and drive off and have averaged 6.8 L/100Kms (34 mpg) . My driving is very regular and my average MPG does not waver one little bit so the only difference between the two is how long the car sat idling last winter.
The 6.8 figure is also my summer average when the car never idled past high and has not moved from that number since last April.
Dadhawk (02-12-2016), Mim (02-12-2016)
Old 02-12-2016, 10:44 AM   #25
..Pretty sure the lengthy idling during warm up was / is being calculated by the onboard average fuel consumption metrics.
Idling would definitely impact your mileage, but that would be the case regardless of whether the computer is doing it or you do it manually.
Tcoat (02-12-2016)
Old 02-12-2016, 10:51 AM   #26
Imagine the mileage if you filled up, drove one mile and then let it run until empty! Wouldn't matter if the computer calculated it or you did, it would be atrocious.
Old 02-12-2016, 11:20 AM   #27
Assuming you filled the tank to exact capacity (13 GAL), then drive exactly one mile, it would be 0.076923...MPG
Practically though, you would most likely be marginally worse than that because fuel capacity does not normally take into account the fuel filler so you would burn slightly more that 13GAL. Also, I'm not sure if capacity is listed in USABLE fuel or overall capacity when talking cars.
Tcoat (02-12-2016)
Old 02-12-2016, 11:27 AM   #28
I was too lazy to do the math so at this point you are 100% more ambitious than I.
analysis, brz, data, miles per gallon, mpg
Oil Analysis - 1st oil change R L Newb Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 375 11-19-2021 10:24 AM
CFD analysis of BRZ/FRS rear diffuser Wonderbar Cosmetic Modification (Interior/Exterior/Lighting) 78 12-15-2014 06:53 PM
MatLab log analysis ztan Software Tuning 12 12-02-2014 08:19 PM
Used Oil Analysis Results Captain Snooze Engine, Exhaust, Transmission 2 11-21-2013 01:59 PM
