#15 |
Drives: SWP BRZ
#16 | |
Drives: 2013 FR-S Whiteout MT
It isnt similar in volume at all.. When I ran full catless it was ungodly loud. Threw on a catted front pipe and its fine. But thats just from experience. Maybe its different with other setups? O_o
When in doubt, throttle out!
#17 |
Drives: 2014 BRZ Limited
Would the berk catless front pipe alone be able to add major drone and noise? I added it and holy smokes the drone and awful sound. I'm hoping its a lose bolt and exhaust leak
#18 |
Typically catless does do that. What is the rest of your exhaust setup? Any future exhaust plans/changes
#19 |
#20 |
stock exhaust only the front pipe was changed
#21 |
So how much louder is an aftermarket catted front pipe over stock catted front pipe?
#22 |
Noob
Drives: FR-S Mammogram
If you just want a straight pipe, no cats, no resonators, it's cheaper to just go to a quality muffler shop that's local to you and have them fab the part.
#23 |
interested in this too actually.. stock has another resonator on it i think?
#24 | |
Drives: White 2014 BRZ
#25 |
Bump.
Looking for an answer to this: So how much louder is an aftermarket catted front pipe over stock catted front pipe? |
#26 |
Buy one and find out. I don't think anyone has measured that. It's likely not a whole lot louder if it still has a cat.
#27 | |
This is what I figured all along but it seems like most who posted above said to get a cat because it's the same loudness as a uncatted front pipe. So ultimately, now I'm confused as to what is what. So far I've heard catted and catless sound the same in terms of loudness. And I've also heard that aftermarket catted sounds equally as loud as stock By this logic, an uncatted front pipe is equally loud as a stock pipe which it's obviously not. So what's really right then?
#28 |
An uncatted pipe will be louder than a catted and an aftermarket catted pipe will be louder than the factory one. Reason being that there is less restriction. This is not considering resonated pipes .Overall however the cat back has the biggest impact on sound though
| FS: Motiv Concepts Test Pipe (catless front pipe) $175 shipped | s30series | Engine, Exhaust, Bolt-Ons | 2 | 12-03-2014 02:40 PM |
| invida catless over pipe and front pipe bnb | kingkai23 | NY / NJ / CT / PA | 0 | 03-14-2014 06:32 AM |
| PTUNING Weekly Special: Invidia Catless Front-pipe / Test pipe $229 INSTALLED! | Patrick@Ptuning | Engine, Exhaust, Bolt-Ons | 3 | 10-01-2013 03:16 PM |
| What is the difference between a Front pipe, a down pipe and an over pipe? | liajet24 | Engine, Exhaust, Transmission | 5 | 09-19-2013 10:03 PM |
| Track pipe + catless front pipe | diss7 | Engine, Exhaust, Transmission | 21 | 10-09-2012 01:10 AM |
