Old 04-14-2015, 03:31 PM   #15
8R6
8R6's Avatar
Drives: FRS
Originally Posted by vividracing View Post
I haven't changed anything to the suspension other than the lowering springs. Everything else is stock. Perhaps where the shocks attach to the engine bay frame is broken?
-RyanG
that's the top hat. try raising the car with the tire off the ground and see if there's any movement on the spring/strut body while the car is being raised.
8R6 is offline   Reply With Quote
Old 04-14-2015, 03:32 PM   #16
vroom4
Doubtful. More likely its just a loose bolt. Id go through the suspension and tighten everything.
vroom4 is offline   Reply With Quote
Old 04-14-2015, 04:08 PM   #17
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
THIS - They wont move while the car is on the ground, but raise the car and check and that should at least let you know if that's the issue.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 04-14-2015, 04:37 PM   #18
vividracing
vividracing's Avatar
I'll check it out and let you all know!
vividracing is offline   Reply With Quote
Old 04-14-2015, 04:54 PM   #19
Koa
I'd also suggest you check the 3 bolts/nuts on your struts where they connect to the body, inside the engine bay. When you changed out your springs and re-installed your struts, did you Loctite the 3 nuts that secure the top of the strut in the engine bay.
When your car is sitting still the strut will appear fine but hit a bump and literally your strut will be popping/slamming into the strut tower mount/body.
This may or may not be the problem.
But if the nuts are loose, secure them with blue Loctite.
Another side note I believe the nuts that secure the strut to the body/tower should be only tightened to around 20ft/lbs. I happen to know for a fact thatif you decide to tighten them a little tighter to say 30ft/lbs, you will shearer the bolt on the top plate of your strut.
I hope this helps.
that's not a fact but you are correct- they require very low ftlb
anecdotal =/= fact just friendly fyi
Old 04-14-2015, 04:56 PM   #20
Celadrielas
Celadrielas's Avatar
Drives: 2013 Asphalt Fr-S
Originally Posted by 7thgear View Post
neither of these reasons are even remotely responsible for audible popping noises.
Excuse the hell out of me. since you offered so much, I'll rebuttle with a reply I was given from a toyota master mechanic.
"Ok, Commonly bushing, grommets, and gaskets are the cause though if you're using a fluid shock and not gas, over full / under full (Loss of fluid or improper rebuild) may cause a squeeking, creaking, or popping noise as well. If you did the suspension yourself and had to adjust the "bump guard" cutting it too short *WILL* make this noise though is it usually described as a clunking. In addition, poor alignment of sways, end links, and such depending on various year model and makes could cause such issues. It's be to attempt to isolate the sound best you can and from there check to see if you're suffering from any fluid loss from struts, packing / oil / grease loss from things such as CV boots, and check the sway bar to see if you see any impact points. Hope it helps."
Old 04-14-2015, 05:04 PM   #21
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Ahh Semantics. Well, what I can say for sure is (in a friendly tone) is that when I reinstalled mine, with my torque wrench set to 30ft/lbs. The damn bolt sheared. It sucked and I had to wait for the parts.
So yes, I would check your service manual or reliable source. But I personally would not approach 30ft/lbs.
I know that Ohlin specifically mentions 18ft/lbs for their Road and Track coilovers.
That's it though, that's all my knowledge. I hope you find the problem.
Daily: Audi TT RS
Old 04-14-2015, 05:35 PM   #22
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
a spring compressing or a piece of rubber compressing will not make a "popping" noise, which is more likely a binding somewhere, an over or under tightened bolt or interference.
a spring will only force a pop if it was seated incorrectly, the spring itself is not going to pop
a bumpstop is certainly not going to be making any noises
I don't know what your master mechanic is trying to say, but his answer is rather broad. Why is he talking about rebuilt shocks?
Old 04-14-2015, 06:41 PM   #23
AreteAuto
Racing Enthusiast
AreteAuto's Avatar
Drives: Bone stock 2019 BRZ manual
I got my car back from a shop once, heard a funny noise from the front. I took off my front left wheel and found out one of the bolts to the strut was VERY loose. I sat back in disbelief for about a minute...then proceeded to check every bolt on the car that they had contact with. I found another one that was stripped and loose. Scared the hell out of me.
Yeah, so definitely do your rounds of investigation before driving a whole lot...
“$20 per diddle? I can diddle myself for free and do a fine job”
AreteAuto is offline   Reply With Quote
Old 04-14-2015, 07:45 PM   #24
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I didn't know a Toyota master mechanic was an expert in fluid dynamics and a shock engineer on the side.
Old 04-14-2015, 09:03 PM   #25
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
My clunk ended up being that I was missing a caliper slide bolt and the other was loose. Check those out.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 04-15-2015, 12:23 AM   #26
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Totally OT, but whenever I scroll through suspension sub thread, popping was not the first thing that I thought this thread said lol.
Improper spring perch, some nuts might not be torqued properly (this however presents itself as a clunk rather than a pop). The first thing that comes to mind when I hear the sound of a pop is a binding of some sort.
Old 04-15-2015, 02:21 AM   #27
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
If it is a popping noise, something is loose.
If it is a pinging noise, your spring is moving around.
-alex
Old 04-15-2015, 02:29 PM   #28
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Also I had a popping noise and it ended up being a failed rear axle nut. It was still torqued to spec, but when it was punched it just warped too much and it allowed some movement. Raise the car up, losen enverthing, put the vehicle on its full weight, then tighten everything to spec. If you torque without weight on the suspension you will get a binding pop from bushings, etc.
[ame="https://www.youtube.com/watch?v=PpjrnQQC8ac"]BRZ Axle Nut click - YouTube[/ame]
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
DIY - Fix your Rear Deck "popping/clicking/tapping/ticking" noise. Mikepage DIY (Do-It-Yourself) Guides 54 10-21-2020 02:34 PM
Rear Deck "popping/clicking/tapping/ticking" noise. Sigh-on-Rice Issues | Warranty | Recalls / TSB 637 04-28-2020 04:55 AM
car making weird noises after 19" tires installed riironman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 11-17-2013 10:28 PM
"thunks" when going over bumps Shipwreck Issues | Warranty | Recalls / TSB 6 06-26-2013 03:28 AM
