Old 06-17-2012, 09:36 AM   #15
encity5
encity5's Avatar
Originally Posted by ruskymx View Post
The wiring harness is needed so you don't have to chop your factory harness up and makes it so much easier to wire everything up correctly. The mounting kit is needed to fill the gaps along the sides of the radio because most aftermarket radios won't be as wide as the original. The antenna adapter is needed so you can hook up the radio antenna to the 940BT. Without out this, it's like trying to fit a square peg into a round hole
Ruskymx
Ruskymx
amazing, thanks for the clear explanation, that really helps and makes sense now!
So is the installation of one of these units essentially, wire the wiring harness to the wires that the headunit comes with, then just plug that into the factory harness? install the unit itself and route the wires and such and done?
encity5 is offline   Reply With Quote
Old 06-17-2012, 10:14 AM   #16
ruskymx
ruskymx's Avatar
Drives: 13 HotLava FRS, 93 4Runner, 97 Taco
Yes, that's about it unless you want to use the factory USB port. Then you need to follow the steps in the link that I have in the first post.
Ruskymx
ruskymx is offline   Reply With Quote
Old 06-20-2012, 03:44 PM   #17
xxthrillxx
Perfectly Balanced...
xxthrillxx's Avatar
Drives: '13 FRS & '13 BRZ
Originally Posted by keithbribac View Post
I just did this mod 2 days ago. Usb and aux works good with my pioneer 8400. I would like to know how to use the factory mic as well
going to try this soon... just purchased a sony xav601bt... hopefully i can make all my factory shenanigans work
xxthrillxx is offline   Reply With Quote
Old 06-21-2012, 10:35 AM   #18
encity5
encity5's Avatar
Originally Posted by xxthrillxx View Post
check this out:
http://www.tacomaworld.com/forum/aud...head-unit.html
You know that link is the same link in the first post (the reason for the thread)
Old 06-21-2012, 12:56 PM   #19
xxthrillxx
xxthrillxx's Avatar
Yeah my bad, i had a different link, but managed to copy the same one
ill find the other one again...
Old 06-26-2012, 01:13 PM   #20
kndonlee
I've been trying to do this, but it seems like it should be possible to use that 3rd radio harness to splice into/aftermarket connector to wire up the USB & AUX. It seems that that 3rd harness is a newer harness.
Also, somewhere I read about the microphone above the light being usable, but it's a 4 wire setup which is supposed to be for an amplified mic. Any resources on converting an amplifed mic setup to a non-amplified 2-wire mic?
kndonlee is offline   Reply With Quote
Old 06-26-2012, 02:21 PM   #21
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
I'm interested in doing this as well!
kmbkk is offline   Reply With Quote
Old 06-26-2012, 03:57 PM   #22
kndonlee
It seems like that 3rd harness would have the key to being able to wire up the built-in USB/AUX/Mic ports without taking apart the dash or replacing the ports. Anyone have any idea on what kind of adapter is needed for that 3rd harness?
The bestbuy audio guy taking a look at that third harness seemed to think it was a new harness type he had not seen before.
Old 07-01-2012, 12:44 PM   #23
kndonlee
http://www.scionlife.com/forums/showthread.php?t=207173
I used this guide. Everything works. Aux does not play video, only through usb. I used gorilla glue to glue the usb plug in place.
In order to play video through the aux, the 3.5mm jack would need to be changed from a 2 ring to 3 ring (3 pole to 4 pole) jack.
I'm thinking getting this cable and replacing the jack inside the dash would do the trick for getting video to work out of the built-in aux jack.
http://www.ebay.com/itm/4-Pole-2M-6-...#ht_500wt_1208
Old 07-19-2012, 01:31 AM   #24
chipz91
chipz91's Avatar
Drives: Toyota Corolla, Asphalt (MT) FR-S
Did you have to do any cutting or modification to connect your stereo? Or is it just just but a connecter harness?
chipz91 is offline   Reply With Quote
Old 07-19-2012, 04:57 AM   #25
keithbribac
Drives: Gray
No cutting into the factory harness.
keithbribac is offline   Reply With Quote
Old 07-23-2012, 09:21 AM   #26
KRAZYK
Self Entitled
KRAZYK's Avatar
Drives: 13' Red FR-S, 12' Toyota Tundra
You will need Metra 70-1761 wiring harness ($5.39 w free S&H), Metra 95-8202 mounting kit ($10.75 w/ free S&H), and Scosche LSAAB Antenna adapter ($9.55 w/ Free S&H).
I didn't buy the 940BT yet, but eBay and Amazon have it cheapest. If you have an Amazon Rewards credit card, I think you can get an additional 3% in points to use towards future purchases. If you open a new account, they'll give you $30 instant gift card. eBay will give you 2% back in eBay Bucks. Since I don't want another credit card, I'm probably going to buy it from eBay. I have $11+ in eBay Bucks now and this would give me another $12. I'll be able to buy something in July for about $23 off.
If someone wants to buy from Amazon, I have a link on my blog (link in sig)
Ruskymx
This is what I was looking for.. Thank you for posting the part numbers.
I will be doing a Kenwood 7140 install pretty soon. Along with new speakers and a sub.. Ill try to get enough pics and do a full write up.
KRAZYK is offline   Reply With Quote
Old 08-01-2012, 03:49 PM   #27
Synack
Boosted
Synack's Avatar
Drives: Sideways
I'm a little confused, according to Crutchfield, the App Radio 2 does not have AUX input.
Old 08-03-2012, 02:31 PM   #28
Neekowahhhh
Enthusiast
Neekowahhhh's Avatar
Drives: Crystal Black BRZ Limited
How are you liking that APP Radio 2? I saw the reviews on that and most weren't that good. people were complaining that it is really slow and sometimes freezes. what's your experience with it been? Im deciding between that and the AVH-p8400 or p4400
Neekowahhhh is offline   Reply With Quote
Auto Factory Aftermarket exhaust ESBjiujitsu Engine, Exhaust, Transmission 113 01-17-2014 05:45 PM
More Scions in Richmond Port. Marloon CANADA 203 06-07-2012 01:43 PM
More shots from the Port of Portland DarrenDriven FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 10 05-11-2012 01:04 PM
Look what I spotted at the port of LB today Trojan_SC Southern California 4 05-09-2012 02:40 PM
Southeast Cars are In Port! Dadhawk Scion FR-S / Toyota 86 GT86 General Forum 3 04-27-2012 11:39 AM
