Old 04-06-2015, 10:34 PM   #15
BRZnut
Drives: BRZ DGM Limited
It is not just from the AC. Mine does it during hard stops with the AC off
The Following User Says Thank You to BRZnut For This Useful Post:
sato (04-10-2015)
Old 04-07-2015, 06:06 PM   #16
Tbird232ci
Drives: 2013 FRS
The A/C compressor also runs when you have the defroster on.
Tbird232ci is offline   Reply With Quote
Old 04-09-2015, 03:52 PM   #17
Shady195
Drives: '13 10 Series FRS #1203
Originally Posted by brianhj View Post
What the fuck is the point of the a/c compressor cycling on and off literally every 5 seconds? Is there a good reason for it?
A/C Compressor runs whenever your blower is on to help remove moisture from the air.
Shady195 is offline   Reply With Quote
Old 04-10-2015, 12:11 AM   #18
stevesnj
stevesnj's Avatar
Check for a vacuum hose thats off or loose clamp on the the air intake hose.
My 2016 Build thread
Old 04-10-2015, 12:31 AM   #19
sato
sato's Avatar
Drives: Dodge Patitas
Keep us posted... mine does it too, with A/C on or off.
Old 04-11-2015, 01:03 PM   #20
spatcha88
Drives: 2013 Scion FRS Whiteout
I'm going to check around tomorrow morning for anything loose. This idle shake has been a major pain my ass for the past month or 2. I will keep you guys posted if I find a fix. Also:
I never use my a/c
I "supposedly" have the latest flash
spatcha88 is offline   Reply With Quote
Old 04-11-2015, 11:14 PM   #21
spatcha88
Quick Update... I added some STP fuel injector cleaner from autozone that you drop into your fuel tank. Its idling and driving like a god damn fiddle?!?!? What gives?
Old 04-12-2015, 05:09 PM   #22
spatcha88
any ideas anybody?
Old 04-12-2015, 10:19 PM   #23
themajesticone
themajesticone's Avatar
Drives: '13 UM86
So you are 100% stock. No tune, nothing done at all?
Resolution: go get a tune by Bill @ Delicious.
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport
themajesticone is offline   Reply With Quote
Old 04-12-2015, 10:27 PM   #24
CatDaddysBBQ
Drives: '13 FR-S
Originally Posted by ninedice View Post
Mine does this as well. Dealer reflashed and it still does it. Annoying.
Mine did the occasional dip and it didn't really bother me. But last Thursday it just started DYING everytime I stopped. Like, 20 times in 4 miles. Luckily I was only a few miles from the dealership, so I drove it right in. They just swapped for a new ecu with the updated tune instead of reflashimg. I suppose they got to bill toyota for more of a warranty claim, and I didn't mind the possible overkill treatment since it didn't cost me anything. Warranty is up in two more months of driving anyway, so I'm good to get a brand new ecu.
CatDaddysBBQ is offline   Reply With Quote
The Following User Says Thank You to CatDaddysBBQ For This Useful Post:
Tcoat (04-13-2015)
Old 04-13-2015, 01:05 PM   #25
spatcha88
Yessiree. All I have after market is my exhaust but the issue has been there long before. And my frs is out of warranty and already has the ecu flash. I might need someone to help me tune it. Where is delicious tuning?
Old 04-13-2015, 01:28 PM   #26
Shady195
Sounds like a vacuum leak.
Old 04-13-2015, 01:32 PM   #27
stugray
Drives: 2013 GBS BRZ Limited
Spend $140 on a tactrix and flash a tune yourself, or spring the extra $$ for an OFT.
Old 04-13-2015, 02:55 PM   #28
spatcha88
Here's the weird part. Last week I did a full ecu restart disconnecting the battery overnight. The car felt like new the next morning. After a day the problem came back. Saturday morning I dropped some STp fuel injector solution and worked beautifully for the whole day. The problem came back once again after driving to work this morning. Could that still be a vacuum leak?
Do you ever feel like an asshole for coming to a complete stop? Ozzman Off-Topic Lounge [WARNING: NO POLITICS] 53 01-20-2014 01:35 AM
Difficult to shift into first when coming to a stop ZackZ Scion FR-S / Toyota 86 GT86 General Forum 21 08-31-2013 01:05 PM
Shifter clicking when coming to a stop larryt1026 Issues | Warranty | Recalls / TSB 1 07-15-2013 08:34 PM
Strange sound coming from my car on idle bcmakesiteasy Engine, Exhaust, Transmission 2 10-05-2012 07:16 PM
Single knock when coming to a stop oops86 Issues | Warranty | Recalls / TSB 14 08-05-2012 02:17 AM
