Old 03-28-2015, 01:33 PM   #15
xwd
Gazoo/Tommi Makinen Racing did an AWD EJ207 swap last year and was using a standard Subaru gearbox and front axles. Not sure how forward they had to place components to make it all work.
+1 on just buying a Celica GT4 instead.
The Following User Says Thank You to xwd For This Useful Post:
cdrazic93 (03-28-2015)
Old 03-28-2015, 09:55 PM   #16
Budo
Spartarus,
By all means keep up with your continuous stream of wildly speculative material; this kind of inquiry is good.
Cheers,
Budo
Budo is offline   Reply With Quote
Old 03-29-2015, 07:05 AM   #17
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
If Bad Obsession Motorsport can put an ST205 powertrain in a Mk.1 Mini, then you can fit it in an FRS.
- The Ancient BRZ Sacrament
by Zaku
Old 03-29-2015, 12:42 PM   #18
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Are you subliminally encouraging the destruction of an all trac!?
The Following 3 Users Say Thank You to cdrazic93 For This Useful Post:
Dipstik-sportech (03-29-2015), Guff (03-29-2015), Koa (03-29-2015)
Old 03-29-2015, 01:15 PM   #19
Cueman
Cueman's Avatar
Drives: In Perfect Control At All Times
Originally Posted by Spartarus View Post
EDIT: 3sgte and transmission weigh 421 lbs. Stock motor and trans weigh 480 lbs. That pulls 59 lbs off the front end of the car. Not bad.
I don't believe this... even if the 3SGTE is a long block with no manifolds or turbo.
Cueman is offline   Reply With Quote
Old 03-29-2015, 01:52 PM   #20
robr
Drives: 2013 FRS, with boost by ATS Racing
Me neither. Our UPS shipping weight of a 3S long block is 450lbs. Granted, that's shipping weight, so it includes the pallet as well. Definitely does not include the transmission.
robr is offline   Reply With Quote
The Following User Says Thank You to robr For This Useful Post:
Cueman (03-29-2015)
Old 03-30-2015, 08:43 AM   #21
JozhGoober
Drives: 2020 718 GT4, 2013 FR-S (Turbo)
Having had to lift the damn thing up, I know the E153 transmission alone from the MR2 is like 120+ lbs, let alone the E154F with the transfer case. That's a beefy transmission.
JozhGoober is offline   Reply With Quote
Old 03-30-2015, 09:00 AM   #22
Dipstik-sportech
Dipstik-sportech's Avatar
Yeah I've installed a gt4 engine and trans and an fa20, there is NO way that the 3s is lighter. It's a cast iron block and that trans is a tank compared to ours.
Old 03-30-2015, 10:55 AM   #23
robr
Yup. I had to do a clutch job myself the day after I broke a rib on my shifter kart. E153s are heavy enough as is to install yourself. I digress
Old 04-01-2015, 09:41 AM   #24
robr
I stand corrected. Our UPS shipping weight for a 3S long block is 390lbs. Plus 40 lbs for the pallet, so 430lbs is what we declare to UPS for one. Close to the 450 I thought. Still doesn't include trans.
Old 04-13-2015, 03:40 PM   #25
drfta86
Drives: 2014 Scion FR-S
What about a BEAMS 3sge from an Altezza?
drfta86 is offline   Reply With Quote
The Following User Says Thank You to drfta86 For This Useful Post:
CxG (09-19-2018)
