Old 03-22-2015, 01:55 PM   #15
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Sorry, my bad. I meant the second part about the "90% of the parts", but I now realize that you were also referring to an OEM style setup. That's good info though.
Old 03-22-2015, 02:06 PM   #16
Koa
FORESTER XT/FA20DIT OIL COOLER RETROFIT
Can run with Grimmspeed intake space tolerances and can be done for under $200.
Here's the real kicker- you can add a Setrab to the setup and have essentially the same oil cooler as people who spend $500-600 on them for around $150-200 less if you spend a little time thinking about it and gathering the right parts.
what now Ck?!
The Following User Says Thank You to Koa For This Useful Post:
ck-GT86 (03-23-2015)
Old 03-22-2015, 06:32 PM   #17
wparsons
wparsons's Avatar
what now Ck?!
How do you add an external cooler to the OEM FA20DIT cooler setup? Two sandwich plates?
flickr
Old 03-22-2015, 06:57 PM   #18
steve99
Yes 2 plates i saw done somewhere, however two many connectors and points of failure for me , personal opinion.
I like the look of the integrated radiator\oil cooler. Simple install , minimum hoses and connectors, oil cooler will act as heater in cold climate, no need for thermostatic plate as its coolant to oil like oem cooler, no extra oil radiator at front to get damaged, oil in end solid tank attached to radiator.
question would be can it cool oil enough, it should be better than oem cooler setup due larger heat exchanger area.
The Following 2 Users Say Thank You to steve99 For This Useful Post:
akyp (03-23-2015), wparsons (03-22-2015)
Old 03-22-2015, 08:07 PM   #19
wparsons
wparsons's Avatar
^^ 100% agreed on too many failure points. I'll have to give that Skunk2 one a better look, I really wanted a Robi Spec one, but I can't buy what someone doesn't want to sell.
flickr
Old 03-22-2015, 08:18 PM   #20
jvincent
jvincent's Avatar
If you want to blaze a new trail, you could use the OEM cooler block and run a dedicated coolant loop through it. In the event of a failure all you would lose is coolant and would essentially default to the stock cooling.
Of course now you'd need to have a secondary water pump, reservoir, and thermostat but it would be unique!
The Following User Says Thank You to jvincent For This Useful Post:
wparsons (03-23-2015)
Old 03-22-2015, 09:54 PM   #21
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
I have the Perrin cooler but if I did it again I'd go with JR. I believe the only difference between their NA vs FI kits is the mounting bracket. The JR has more cooling capacity than Perrin.
Sleepless is offline   Reply With Quote
The Following User Says Thank You to Sleepless For This Useful Post:
Old 03-22-2015, 10:03 PM   #22
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Another option we've discussed was OEM cooler, between the 2 radiator hoses, with an electronic temp switch controlling an in line electric water pump. You take it out of the engine coolant loop and take advantage of the under-utilized NA radiator but lose the heater ability. Someone in our club has this minus the switch and gets good results.
Old 03-23-2015, 01:09 AM   #23
steve99
I like simple
how about running an oil cooler radiator in series with the coolant line before the oem oil cooler. ie use the radiator to pre cool the coolant (not oil) before it get to the oem heat exchanger.
unlikely to need thermostat as coolant will be 95c input, and no pump or switch ect required
Old 03-23-2015, 01:20 AM   #24
Wayno
Wayno's Avatar
With all that extra volume, surface area, distance, and small openings might still need auxiliary pump
Old 03-23-2015, 01:32 AM   #25
steve99
yes could do
Old 03-23-2015, 01:36 AM   #26
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
what now Ck?!
Darn you, i never thought of doing that!! I feel uneasy now about my yet to be shipped jackson oil cooler. Ugh.
. ck
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
The Following User Says Thank You to ck-GT86 For This Useful Post:
Koa (03-23-2015)
Old 03-23-2015, 01:40 AM   #27
wootwoot
Drives: FRS
I have a mocal laminova core, Koyo radiator, and skunk2 sandwich plate. I really like it.
wootwoot is offline   Reply With Quote
Old 03-23-2015, 09:46 AM   #28
Koa
. ck
Ayo I'm not sure how well it can be done- I was thinking get custom hoses made/make myself with AN fittings for the setrab, and regular female (open) ends for the male connectors at the sandwich plate. @steve99 can't one just add the setrab to the loop, where the setrab is in-between the coolant tap and OEM sandwich?
Why run two?
Trying to find the toyota factory "option pack" High rise spoiler. HELP! Hotlava86 Cosmetic Modification (Interior/Exterior/Lighting) 52 05-04-2014 03:02 AM
"back-seat-remove" option. Z_Rocks Scion FR-S / Toyota 86 GT86 General Forum 53 06-25-2013 04:24 AM
No "Edit Signature" option switchlanez Site Announcements / Questions / Issues 4 05-03-2013 06:33 AM
Dealer "Simoniz Glass Coat" option Bfly Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 18 09-16-2012 12:53 AM
