Old 03-24-2015, 06:20 PM   #15
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
The real issue is that these cars draw a lot of current even when sitting off.
I calculated that if the car is left for ~10 days without starting it, the battery will run down.
Add the camera and thats probably more like 5 days. (Just a WAG)
I leave my car untouched for weeks and never have trouble starting it. BRZ Limited. 7,000 miles in nearly 3 years, so you can tell how many times it sits for weeks without being started. Original battery. No issues.
Aftermarket stereo or camera or lighting etc can have a phantom draw.
ashtray is offline   Reply With Quote
Old 03-24-2015, 09:56 PM   #16
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
ntron1 is offline   Reply With Quote
Old 03-24-2015, 10:01 PM   #17
kenoshainflames
Drives: 2013 brz limited
Originally Posted by ntron1 View Post
You Sir are living in a fantasy world. Move North to the land of 0 Degrees F in the winter and you'll be singing a different tune. Subaru payed me $150.00 to replace mine with a real battery instead of calling roadside assistance every other day to jump start my car.
i live in wisconsin and have never had any problems leaving my car untouched in the 0 degree weather.
kenoshainflames is offline   Reply With Quote
Old 03-24-2015, 10:21 PM   #18
Poodles
Drives: 2015 Series.Blue
Yep, and people want to run smaller batteries and think the stocker is too big
Also, even though ntron1 is editing his posts, I'll educate him.
1) Cold doesn't hurt batteries, it just makes their output weaker. A higher CCA battery is a) more fragile internally and b) more prone to heat damage. Add in the effects of cold on trying to crank the engine and you'll think the battery is crap. The battery is designed for the best percentage of the world (as it's the same damn battery in every one of them as they're shipped with the battery installed) so if you're in a crazy cold environment, you should be adjusting accordingly (block heaters, etc).
2) Heat kills batteries and people assume that the cold kills them because batteries tend to put out more power when hot (to a limit) and the engine is far easier to turn over, so the damaged battery isn't discovered until the winter when it's output is lower.
I'd love to deal with weather that wasn't so damn hot that it kills batteries in a couple years. People think CCA is the be-all-end-all stat for a car battery when it's not...
Old 03-24-2015, 10:45 PM   #19
dnieves
Drives: FR-S 10 Series
The BRZ is worse than the FRS because of the keyless entry.
I have a miracle Panasonic battery too! I left my 10 Series in three snow storms for more than a month without starting it. When it finally thawed the keyless entry & badges worked normally and the car started on the first try.
dnieves is offline   Reply With Quote
Old 03-25-2015, 12:41 AM   #20
TheVoiceOfReason
TheVoiceOfReason's Avatar
Drives: BRZ Limited
My BRZ also sat for about 10 days a month ago, and would not crank when I got back to it. Battery charged back up and has been fine though.
TheVoiceOfReason is offline   Reply With Quote
Old 03-31-2015, 02:43 AM   #21
taiguy
Drives: 2013 Black BRZ Limited
Hey Poodles - I saw you comment on one of my posts in another battery thread.
Have you measured your parasitic current?
What's the longest you let your BRZ sit for without driving it?
I had a fresh battery replaced under warranty (last month) die after sitting for a month in my driveway.
taiguy is offline   Reply With Quote
Old 03-31-2015, 05:13 PM   #22
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
I just pulled my car out of storage with the battery hooked and it started after sitting 4 MONTHS! No problem.
What I did: it was stored in a 10 degree Celsius underground garage, I disabled the alarm, manually turned off my HVAC, and turned the lights to off from Auto, and I also turned the radio off to minimize any drain on the battery. Hope this sheds some light on this.
Gords_zenith is offline   Reply With Quote
Old 03-31-2015, 05:27 PM   #23
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
My car has sat undriven for that long before and ran just fine.
^GT5 Replay Photo Mode^
Old 03-31-2015, 08:59 PM   #24
alan.chalkley
Drives: 4wd zooks
My car with the stock battery is two years old and done only 9000 kms. I was overseas for 5 weeks and when i came back it started okay.
The stock battery is good with the warm weather in Sydney.
It only snowed here once in the last 56 years.
alan.chalkley is offline   Reply With Quote
Old 04-27-2015, 03:53 PM   #25
taiguy
Put a new battery in my BRZ on March 26th, was out of town for 3 weeks, and came back to find it at 2V. I also had a Noco Genius G3500 charger on it during this time. Not sure what happened.
Measured parasitic drain was 130mA at the dealership.
Old 04-30-2015, 10:08 PM   #26
Dorb
Drives: 16 LM STI/13 LM BRZ/04 AVALANCHE
My BRZ bought in Nov. 2012, has 4500 miles on it now and is parked in non heated garage once the snow falls and never had it not start and nothing on the battery. I usually start it and let run several times a month during the winter. Not sure it helps or not. Maybe just another lucky one.
Dorb is offline   Reply With Quote
Old 05-01-2015, 03:32 AM   #27
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Are you turning it the right way? LOL
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 05-10-2015, 12:40 PM   #28
Dave5454
Drives: BRZ Limited 6MT
My battery too ... left in my garage for about 10 - 11 days with low temps. - car would not crank on 11th. day. Got a battery tender and no more problems.
Dave5454 is offline   Reply With Quote
Dead battery technoid BRZ First-Gen (2012+) — General Topics 17 03-17-2016 05:17 PM
Dead battery Mikeez Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 33 08-07-2015 10:58 AM
Dead battery!?! Hoahao Issues | Warranty | Recalls / TSB 5 02-23-2015 05:06 PM
BRZ LTD battery drain issue, can't stop open door beep DoomsdayJesus Issues | Warranty | Recalls / TSB 9 02-06-2015 07:05 PM
Is there any know that how to open the truck when the battery is dead?????? wilson0326 Scion FR-S / Toyota 86 GT86 General Forum 31 07-06-2013 10:24 PM
