#16 |
That Guy
Drives: 2013 asphalt FRS MT
| The Following User Says Thank You to Calum For This Useful Post: | twag4 (03-16-2015) |
#17 |
#18 |
The Thread Lurker
Drives: '14 BRZ, '17 GTI, MT09
A Nameless fanboy got all pissy when I posted the same thing. I had one and that thing leaked a lot worse than the stock. It says on their website no RTV is required, "Eliminating the use of RTV in this area". As I inspected the part more it looks like its inner diameter is too small to actually truly do anything. I remember as I tightened it up I didn't feel that the o-ring was really being pressed into anything. The only reason I tried it is the claim it did not require any RTV. Even with RTV at the same spots as the Raceseng part it still immediately leaked.
So I threw it out got the Raceseng part and and everything has been great since. You'll really notice the difference once you get the Raceseng part. The Racenseng part just requires two small spots of RTV. The reason the RTV is required is there are basically two parts RTV-ed and bolted together and then the cam plate is bolted to them. The surface between those two parts can leak a bit after the removal of the plate since the RTV between those parts might and likely will be disturbed after removal of the plate. |
#19 | |
Drives: 93 MR2 Turbo; 2014 BRZ
No cam plate should need RTV in my opinion, what would be the point of the cam plate then? |
| The Following User Says Thank You to eric6 For This Useful Post: | Turdinator (03-16-2015) |
#20 | |
That Guy
BTW if you're looking for another tester I volunteer as tribute. |
#21 |
Guys I said viton or like quality/composition o ring.. Doesn't HAVE to be viton. Shoot, that is the grandfather of specialty rubber seal material developed in the 50s if I'm not mistaken.. There's tons of good options
On a tangential note.. What's up with nameless being beautiful stuff but somewhat spotty QC? Their FP/OP combo.. This plate... |
#22 | ||
Señor Member
I have been selling orings for over 10 years now and there are a lot of misconceptions about viton being the wonder material for all situations.
1974 TA22 Celica
2013 86 GT |
| The Following User Says Thank You to Turdinator For This Useful Post: | Koa (03-17-2015) |
#23 | ||
That Guy
I was also hoping to see the o ring to see if it's dissolving due to incompatibility with the oil. |
| The Following 2 Users Say Thank You to Calum For This Useful Post: | Koa (03-17-2015), Turdinator (03-17-2015) |
#24 | |
hell, we could throw on some dupont magic like kalrez, or go to 3M for some fluorel or kel-f but raceseng chose a good supplier of automotive grade seals and that's the important thing here.. like another said above, one can only determine if the seal isn't appropriate for our oil if the o-ring starts to disintegrate or rub off in our hands edit: damnit read @Calum 's comment right after I posted, redundant bit at the end there ^.. really gotta learn to read new comments before replying ha
| The Following 2 Users Say Thank You to Koa For This Useful Post: | Calum (03-17-2015), Turdinator (03-17-2015) |
#25 |
Drives: In Perfect Control At All Times
Want to add that I'm having zero luck with my nameless plate as well. Leaked with no rtv and I have since r&r'ed twice with RTV but it is still leaking. Going back to stock.
| Nameless Muffled Axleback, any problems? | taylorsankey | Engine, Exhaust, Transmission | 20 | 04-07-2015 03:46 PM |
| Nameless Performance Cam Plate | 00NissanNinja | Engine, Exhaust, Transmission | 1 | 11-20-2014 09:19 PM |
| Transmission problems, oil leaks and detonation problems.. | turboviper | Issues | Warranty | Recalls / TSB | 4 | 06-18-2014 05:01 PM |
| Nameless releasing Sensor Plate for Innovate Motorsports BRZ/FRS/GT86 Twin Screw | xjohnx | Forced Induction | 24 | 07-20-2013 04:26 PM |
| [For Sale] Rho-plate Tow Hook Mounted License Plate rack | pizzahead20 | Canada Classifieds | 0 | 08-23-2012 01:06 AM |
