Old 03-09-2015, 10:26 AM   #15
boucher
Leaux Down Krewe
boucher's Avatar
Drives: 2014 SSM Limited
"Low" is a relative term.
Follow me on IG: @rougarou86
boucher is offline   Reply With Quote
Old 03-09-2015, 10:45 AM   #16
ChrisD
ChrisD's Avatar
Drives: GT86
Originally Posted by adamg View Post
since when has et35 been a low offset for these cars
unless your running 10"+
et35 isn't, but originally I was looking for et25 (I said in the original thread I was struggling to find anything LOWER than et35, not that I wanted et35) and I could hardly find any wheels with an offset that low so I assumed that was pretty low.
ChrisD is offline   Reply With Quote
Old 03-09-2015, 12:12 PM   #17
D_Thissen
D_Thissen's Avatar
If you want to keep the same size as stock, look at a set of rims that are 17x7 with an offset of +35. If you want slightly wider you could go 17x8 +35 and run a 225/45/17.
Old 03-09-2015, 01:43 PM   #18
Annahra
Annahra's Avatar
Drives: 2014 WRB BRZ LTD
The problem is this is really hard to find except in replicas. I've been looking at options for a couple of weeks.
Annahra is offline   Reply With Quote
Old 03-09-2015, 01:53 PM   #19
D_Thissen
D_Thissen's Avatar
17X7 is a bit hard to find. You can find more if you're willing to go to a 8 or 9 inch rim.
http://www.ft86speedfactory.com/whee...3/index-2.html
http://www.ft86speedfactory.com/wheels-40/17x9-114/
http://www.ft86club.com/forums/showthread.php?t=37136
http://www.ft86club.com/forums/showthread.php?t=65113
Old 03-09-2015, 11:08 PM   #20
CatDaddysBBQ
Drives: '13 FR-S
This is what I have. 17x7 and +35 team Dynamics Pro Race 1.0 - the little added track width fills out the wheel well better without really being a big enough difference to be a worry.
They're also only 16lb a wheel, so that's another perk.
CatDaddysBBQ is offline   Reply With Quote
The Following User Says Thank You to CatDaddysBBQ For This Useful Post:
ChrisD (03-15-2015)
Old 03-10-2015, 02:36 AM   #21
D_Thissen
D_Thissen's Avatar
Yup +35 offset works well. A bit of poke I think with out negative camber up front. I have 17x8 +35 for my summer's.
The Following User Says Thank You to D_Thissen For This Useful Post:
ChrisD (03-15-2015)
Old 03-14-2015, 11:40 PM   #22
Ashikabi
Ashikabi's Avatar
I heard spacers are fine for racing. Just my $.02
The Following 2 Users Say Thank You to Ashikabi For This Useful Post:
CatDaddysBBQ (03-16-2015), ChrisD (03-15-2015)
Old 03-15-2015, 02:01 PM   #23
ChrisD
ChrisD's Avatar
Drives: GT86
Thanks for the help guys - ended up ordering some OZ Ultraleggera wheels with a 35 offset and .5 of an inch wider than stock wheels (so 17x7.5, et35).
So my existing 215 width tyres should still fit fine and the extra width and lower offset should make it sit roughly flush Will post some pics in my build thread once they're on: http://www.ft86club.com/forums/showthread.php?p=2169702
Closest to OEM Wheels width and offset impossible Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 08-23-2014 03:24 PM
WTB (SoCal) 17" (width and offset can vary) wheels jonbonazza Wheels and Tires 0 02-28-2014 09:43 PM
FS:PRICE DROP UPDATE!! SOCAL: 2011 WRX WHEELS 17X8 +53 offset Turboblades Wheels and Tires 5 09-26-2013 05:49 PM
how will +35 offset wheels fit yetiFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 05-15-2013 06:33 PM
