#15 |
Drives: 2015 FRS Asphalt
I have my first oil change scheduled for April. I asked if I had to bring it in even if it hasn't reached 7500 miles. They told me which ever comes first because my tires need to be rotated at first service. I trust my dealership because they did some warranty work on my other Scion car. They went out of their way to make sure the issue was taken care of. In fact I got my car back in a few hours. So far they haven't done anything shady to me just yet. I go to one of their service centers in my area.
#16 | ||||
Drives: 2014 BRZ Limited
Use the Subaru oil and filters. Quote:
OP might want to check that. For the BRZ, it was 7500 for 2013 and 2014, but I believe they changed it to 6000 for 2015. I'm not sure why. I had a TBN done on the Subaru 0W20 with my regular oil analysis, and Blackstone estimated it was good for at least 11,000 miles. I think Subaru just wants to sell more oil and filters. I don't know how Scion does it, but with Subaru, I usually get an automated follow-up email from the service manager, followed by a survey request from Subaru. In my case I didn't even have to give them a bad survey, because I responded to the service manager's email first, and they jumped to. The service rep actually told me their compensation is affected by those surveys. |
| The Following User Says Thank You to extrashaky For This Useful Post: | dentalprodigy (02-28-2015) |
#17 | |
Drives: 2014 Subaru BRZ Limited WRB AT
I'm thinking Subaru learned something with the first 2 years production of FA20s and had a technical (e.g. warranty) reason for shortening the interval. I'd rather change it early just to be sure...
Cosworth Drop-In Air Filter, Diode Dynamics DRL module, Perrin Tips |
#18 | |
Drives: '11 Cayman , '14 Camry, '11 Tacoma
#19 |
Drives: 2016 FR-S
#20 | ||
Meanwhile, on 7500 mile intervals, my engine is not seeing any abnormal wear at 32K miles. My 30K oil analysis didn't give any indication that the filter is failing. If actual testing shows that the oil is holding up and the filter is holding up, I can't think of any reason for Subaru to change the service interval other than to make more money for the dealer service departments. Quote:
If I had a 2015, I would do it every 6000 miles to maintain the warranty. But if Subaru says to change the oil every 6000 miles, doing it every 5000 miles is a waste of money unless you're really beating the shit out of your car. |
#21 |
Drives: 2016 FR-S
You'd think they would change it on the FR-S as well, but it's still 7,500 miles for the 2015.
#22 |
Drives: frs
#23 |
Benched 86lb
Drives: Ultramarine FR-S
#24 |
Drives: 2016 FR-S
#25 |
Benched 86lb
Pretty much.
#26 |
Drives: 2015 Firestorm Scion FR-S 6MT
I'm past the break-in period now (over 1,200 miles). I believe Scion Service Boost doesn’t cover oil change right after break-in (first scheduled maintenance is still at 7,500 miles), so I plan to do it on my own soon (with Castrol EDGE full synthetic 0W-20 and Royal Purple 10-2808 filter).
#27 | |
More info: http://www.consumer.ftc.gov/articles...ne-maintenance |
#28 |
+1 on OEM filter and crush washer, ~$8 or at most $9.
+1 on first oil change at 7,500 miles (6.5k if the manual was changed). The factory fill has some anti-wear ingredients, theory is that those can 'treat' the surfaces of interest in the engine for longer life. I'm also a proponent of following factory instructions on break in (under 4k rpm first 1k miles, no constant speed). There are literally thousands of people who will vehemently oppose this paragraph, do whatever gives you warm fuzzies. |
| The Following 2 Users Say Thank You to strat61caster For This Useful Post: | Tcoat (03-01-2015), TheVoiceOfReason (03-01-2015) |
| Oil Change Interval Change (Subaru recommended) | Flow | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 34 | 09-10-2014 07:27 PM |
| Oil change | stiboy808 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 17 | 05-27-2014 11:26 AM |
| When should i do an oil change? | Ayaz2589 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 112 | 03-15-2013 01:25 PM |
| When will you be doing your first oil change? | pr086 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 40 | 12-10-2012 04:48 PM |
| Took my car in for an oil change... | joshua | BRZ First-Gen (2012+) — General Topics | 25 | 08-04-2012 09:32 PM |
