Old 02-13-2015, 01:47 PM   #15
Xinshadow
Drives: 2013 Scion FR-S Ultramarine
Originally Posted by Boofneenee View Post
http://www.axle-exchange.com/inc/sdetail/365
I came across this on my Facebook account
TAX MONEY BACK - SPECIAL] - FREE SHIPPING - $389
DRIVE SHAFT - Aluminum light weight from Axle Exchange
BRZ/FRS Manual: http://www.axle-exchange.com/inc/sdetail/365
BRZ/FRS Automatic: http://www.axle-exchange.com/inc/sdetail/399
Apply code at the checkout: OVR2015 for special discount
Price: $389.75 US (including shipping within USA)
• 3" o.d. Alcoa 6061 aircraft aluminum
• Spicer HD u-joints.
• HD slip yoke and flange all straightened and hi speed balanced.
• These shafts run very true and are rated to 600hp+.
• NEW - Sound deadening insides
Few people have these installed on their cars and are very happy with it. The quality is unrivaled! The acceleration is immediate, the cars feels eager to just jump when push the throttle. The best bang for the buck…like all the other mods wink emoticon.
Subaru BRZ MT
The Axle Exchange in Fairfield NJ is your source for in house driveshaft fabrication, brake parts, clutch kits and flywheels, c-v axles, rack and pinions, pto shafts and more.
axle-exchange.com
I hardly see much talk these days about lightweight driveshafts but I understand they can really shed unsprung weight. Any thoughts on driveshafts all together or this particular product?
I understand the stock shaft is a two piece. Most after market are one piece to save weight. Anyone care to share their experience as to what negative consequences of going from 2 to 1 would have? I mean it must be 2 piece for a reason.
I've had the DSS aluminum unit on my car for about 14 months now. Without getting into any maths, does it make a difference is acceleration feel? Yes, but slight. However in terms of total weight reduction its pretty significant for not a lot of money, and I plan to go with a lightweight flywheel down the road so it made sense.
The biggest change you will see, and I'm surprised no one mentioned this yet, is that it makes heel-toe shifting SIGNIFICANTLY easier, saving some wear and tear on your gearbox over time.
That said you will notice an increase in NVH, with the rubbing noise some others have described, and you may also feel a pulse through the gas pedal when the diff kicks in that the stock shaft kept muted.
Interestingly after going through some winters with both units, the factory one was developing small surface rust spots in a few areas, whereas the aluminum one for obvious reasons still looks fresh as a daisy. I'd be more worried about a factory one becoming unbalanced and damaging the gearbox over time in harsher climates than I would be about the aluminum one doing any harm.
Overall I'd say its a pretty effective cheap mod, if you're willing to work on your driving technique enough to take advantage of it.
Current mods: OFT Stage 2 (w/93 oct), OFH, Perrin Resonated catback, DSS Aluminum Driveshaft, Perrin drop-in filter, Avo silicone inlet, Mishimoto catch can, Grimmspeed MCB, Perrin crank pulley, Nameless overpipe/downpipe combo, DBA slotted rotors, Ferrodo brake pads, goodrich SS brake lines, DOT5 synthetic brake fluid.
Xinshadow is offline   Reply With Quote
Old 02-13-2015, 01:51 PM   #16
FirestormFRS
Reducing the weight of engine driven parts is always going to benefit straight line acceleration. Will it always be noticeable? No.
I don't want the NVH and driveline wear that comes with longer driveshafts. You kids have at it though!
FirestormFRS is offline   Reply With Quote
Old 02-13-2015, 01:55 PM   #17
Koa
Try this.
If a cyclist were to do the following two experiments, what would the results be:
Test A - Remove 10 grams from the perimeter of the tire and compare that to removing 10 grams from the seat.
Test B - Remove 10 grams from the wheel HUB and compare that to removing 10 grams from the seat.
What do you think?
The analogy applies this way for our cars:
Remove weight from the perimeter of the flywheel vs same weight removed from the spare tire: Noticeable difference! (removing from flywheel made a significant difference to rotational inertia)
Remove weight from the driveshaft (or the engine pulley) vs same weight removed from the spare tire: NO Noticeable difference!
Stu continually making haters out by being one of the realest people here.. straight up let 'em have it
Old 02-13-2015, 03:01 PM   #18
Sypher
Sypher's Avatar
Drives: '13 Ultramarine FR-S M/T
Try this.
What do you think?
i believe you are wrong. see references below
http://www.stangnet.com/mustang-foru...weight.789990/
http://www.hpwizard.com/rotational-inertia.html
Mod List:
FT86SF Catted header / Nameless combo pipe with cat and res/ FT86SF V1 CBE / GrimmSpeed Intake / OFT STG 1 GS Tune / Fortune Auto 500's
Sypher is offline   Reply With Quote
Old 02-13-2015, 04:25 PM   #19
stugray
Drives: 2013 GBS BRZ Limited
Originally Posted by Sypher View Post
Notice in the first post the OP talks about "equations" but does he show any? - No. so that makes it hearsay.
Sorry, but I will not accept - "You are wrong go read some stuff that proves it"
Cant you answer the "what do you think?" as it applies to the question?
Point out where I am wrong and then explain where I can find an explanation where I am wrong.
Physics is on my side (something I excel at).
I am not saying that reducing rotational mass does nothing, just that reducing the mass of certain items is below the threshold of detection of our "butt dynos".
EDIT - OK I read the second link.
THANK YOU for making my point for me.
In the example for driveshaft & half shafts, the author and the calculator explain that the "mass ratio" (equivalent vehicle mass compared to rotational mass) is.... wait for it..... wait for it....
1.01 = which in my book is approximately ONE.
So as I said - removing 1 pound from the driveshaft is the SAME as removing one pound from anywhere else on the car.
Old 02-13-2015, 05:41 PM   #20
Poodles
Drives: 2015 Series.Blue
And everyone ignores the elephant in the room, driveshaft critical speed.
Look it up, the math is easy.
Old 02-13-2015, 07:23 PM   #21
D K
Stig's dark passenger
I have the axle exch alum ne because it was faster than the drive shaft shop.
No other reason.
Im pretty sure they are both almost identical.
I personally stay away from carbon stuff because they are more fragile, etc..
If you have an exhaust leak, you are much more likely to damage a carbon one than an alum one.
For a race car, I will take reliability over outright performance.
To a point, of course
D
D K is offline   Reply With Quote
Old 02-13-2015, 07:40 PM   #22
Sypher
Sypher's Avatar
if you read the whole paragraph he states that the 1:1 ratio is for axles and half shafts. yet for drive shafts use the ratio of the differential. I believe that if you put in the correct dimensions for the drive shaft it gains quite a bit.... when i use the calculator the stock drive shaft should be roughly 30lbs of equivalent mass. I'm no physics major so i could be wrong.
Mod List:
Old 02-13-2015, 08:28 PM   #23
Captain Insano
That might be the lowest price yet I have seen for a DS.
Old 02-14-2015, 12:52 AM   #24
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
The biggest difference with the 1 piece driveshaft is the way the car reacts to throttle input. Once you drive one with a 1 piece, you will realize that you can no longer feel the delay when the center joint is loaded/unloaded. There is an immediacy to throttle inputs that is absent in the OEM 2 piece.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
Old 02-14-2015, 02:19 AM   #25
Wyattkb
Drives: 2014 Whiteout FRS
So no input on whether the one piece drive shafts causes any premature wear on any parts?
Wyattkb is offline   Reply With Quote
Old 02-14-2015, 03:23 AM   #26
Poodles
The center joint has nothing to do with this... The driveshaft more likely has a bonded section in one of the shaft pieces. Eliminating that would achieve the same feel.
I'm waiting for someone to make a light weight 2-piece...
Old 02-14-2015, 08:20 AM   #27
Hawk77FT
Drives: GTS 86
Seen the dss one before: wrong position of the counter weights, bad weldings . Looks cheap Chinese made!
Removing weight off the driveshaft will reduce the rotational mass= engine will get to high rpm quicker. Same as the crankshaft pulley. Look up the Grimmspeed research on lightweight weight pulley!
Hawk77FT is offline   Reply With Quote
Old 02-14-2015, 09:56 AM   #28
Xinshadow
It seems unlikely. People have been running (and various trim levels of cars come with as stock) one piece CF or aluminum shafts for years with no issues. I think your ability to row the box smoothly up and down at speed is going to be a far more significant factor in driveline longevity than the shaft itself.
The only reason steel was used in the first place is its cheap and does a good job dampening nvh in a car that already has a pretty thin interior sound wise.
Lightweight aluminum drive shaft installed. stockysnail Northwest 18 02-04-2020 11:18 PM
Driveshaft Shop Aluminum Drive Shaft. FT-86 SpeedFactory Engine, Exhaust, Transmission 40 10-15-2015 09:11 PM
Invidia N1 interference with Driveshaft Shop aluminum shaft. xkalelx Engine, Exhaust, Transmission 6 03-03-2015 09:43 AM
Scion FR-S / Subaru BRZ Drive Shaft Shop Carbon Fiber Drive Shafts In Stock Anthony@RWHP Transmission and Driveline 4 12-25-2013 08:09 PM
