Old 06-11-2012, 08:50 AM   #15
yuli8466
Drives: MX5
Originally Posted by arghx7 View Post
Post data on the timing and AFR. We need to address this with specifics rather than just with generalities and secondhand information. We don't know anything about the fuel trims or knock learning.
Dyno with AFR,
Posted by @feedbag
yuli8466 is offline   Reply With Quote
Old 06-11-2012, 12:31 PM   #16
Turbowned
Turbowned's Avatar
Looks like we got more ammo for the MT vs AT debate LOL
Old 06-11-2012, 01:08 PM   #17
arghx7
Drives: car
Ok, that's a start. But just because there's an offset between the AFR curves doesn't mean the two vehicles are actually tuned richer. There's a lot you can figure out without having cracked the ECU. You just need to know where to look.
What we need now is to get a general scan tool and log at the very least:
1) Commanded lambda
2) ignition timing
3) short term fuel trim
4) long term fuel trim
5) engine rpm
6) wide range oxygen sensor equivalence ratio
7) diesel fuel rail pressure (this is PID is also used on GDI engines)
8) fuel system status (usually shows when the vehicle enters open loop/enrichment period)
There's a bunch of other stuff that might be available over the data bus. Use the attached latest parameter list from 2011. Compare the tailpipe data with the commanded equivalence ratio.
arghx7 is offline   Reply With Quote
Old 06-11-2012, 05:29 PM   #18
Jordo!
Enjoy it, destroy it.
Jordo!'s Avatar
Drives: Datsun Racing Hen
Just talked to a buddy of mine who thought that which set of load cells it's reading off of may differ depending on the gear it's in -- which gear was each in for the dyno?
So... at minimum, that may not be the best gear for the AT to see max power on a dyno. Definitely want to see output with same AFR and ignition advance.
Jordo! is offline   Reply With Quote
Old 06-28-2012, 11:36 AM   #19
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
Any new information on this?
blackfireball5 is offline   Reply With Quote
Old 05-10-2014, 01:59 AM   #20
Boxer486
Drives: small
Old thread but thought I'd bump this and say the OP dyno on the AT is inaccurate.
Just pulled two successive dynos and on a stock AT for my baseline peak HP is at 6542 rpm and torques at 3144 rpm. The curves look pretty much like the MT. Both runs pretty much lay right over each other except for a minor 2-4 tq/hp bump between 3-4k on the second run since the oil was warmed up. Torque rolls off at around 6400 rpm and Horse at just over 6800 rpm.
I did my last runs in 3rd gear. When we did the first run it was in 4th and the car struggled to get up to 7k and hovered.
Boxer486 is offline   Reply With Quote
Old 05-10-2014, 06:50 AM   #21
Fortis
Fortis's Avatar
Drives: 2014 FR-S AT Asphalt
Originally Posted by Boxer486 View Post
Just pulled two successive dynos and on a stock AT for my baseline peak HP is at 6542 rpm and torques at 3144 rpm. The curves look pretty much like the MT. Both runs pretty much lay right over each other except for a minor 2-4 tq/hp bump between 3-4k on the second run since the oil was warmed up. Torque rolls off at around 6400 rpm and Horse at just over 6800.
What were your peak HP and TQ numbers? What kind of dyno?
Fortis is offline   Reply With Quote
Old 05-11-2014, 03:32 AM   #22
Boxer486
Drives: small
Mustang dyno after Weather Correction Factor (WCF):
128.4 @ 6542
112.7 @ 3144
I'd post pics but autofocus on my cameraphone stopped working after my drink flew out of the cupholder on Ortega Hwy. Actually, it took the cupholder with it....
I plan on going back to test a TRD intake and might be able to do a screen cap of an overlay.
Old 05-11-2014, 02:15 PM   #23
blackfireball5
Holy old thread! lol.
HKS Supercharged 86 on dyno.. Brian S Forced Induction 14 01-22-2013 12:13 PM
6MT BRZ, 6AT FR-S Dyno Comparison feedbag BRZ First-Gen (2012+) — General Topics 30 06-12-2012 12:48 PM
BRZ on the dyno Symbiont BRZ Photos, Videos, Wallpapers, Gallery Forum 1 05-22-2012 01:17 PM
engine dyno! carbonBLUE Engine, Exhaust, Transmission 21 04-25-2012 08:29 PM
