Old 02-05-2015, 04:05 PM   #15
RobertPaulson
Hisnamewasrobertpaulson
RobertPaulson's Avatar
Drives: 2017 Golf R
Originally Posted by 2016 Camaro SS View Post
When did you put on the lock washers? Before or after you tightened the v-bands?
I did it after the v-bands to make sure they were tight on the hanger to reduce movement.
This is your life and it's ending one minute at a time.
RobertPaulson is offline   Reply With Quote
The Following User Says Thank You to RobertPaulson For This Useful Post:
2016 Camaro SS (02-05-2015)
Old 02-19-2015, 09:50 AM   #16
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
Still having an issue with this. I even had someone shoulder butting the left tip as I tightened the system. After a heat cycle, it shifted back and the left tip is still sticking out a little bit. I have twisted the S Pipe, which it only twists a small amount up and down. I've tried tightening it at the muffler first, then to the mid pipe, and vice versa. Doesn't seem to matter. I have a JDL UEL, JDL OP, and JDL catted FP, made with a flat flange to mate with the Perrin midpipe. I had 0 issues with fitment or anything on the front half.
I'm just trying to understand what is pushing the left tip out so much when tightening it. Am I just aligning the S-Pipe poorly before tightening? I can get it all perfect when the V-Bands are loose. Both tips look great. Once I get to the point where the V-Band starts getting tight, that's when the movement occurs. I'll probably play with it again this weekend if the weather is nice. I'll try to get pictures if it helps, but I think it will be hard to tell by looking at pictures what's wrong, but I'm willing to try anything at this point. I love the exhaust... I'm just OCD about the tip alignment, lol.
2016 Camaro SS is offline   Reply With Quote
Old 02-21-2015, 08:01 AM   #17
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
Following. I have the same issue. Exhaust has been on for a week. Every time I walk up I stare at it.
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 02-21-2015, 04:14 PM   #18
2016 Camaro SS
Drives: Fast
Still working on this today... Been several hours, left tip is still sticking out a little bit more than the right no matter what I do.
Old 02-21-2015, 04:20 PM   #19
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
mine is slightly off as well, dont think theres much you can do as it seems quite common.
Old 02-21-2015, 08:11 PM   #20
tracerit
Drives: '13 SSM BRZ Limited 6MT
Wow, didn't know other people have this issue as well. It bugged me quite a bit early on but I've grown used to it. THought I had it down but after a drive it would settle back to being uneven. Don't midn it much now as I plastidipped the tips so it's not that entirely noticeable. Also the nut on my V-clamp stripped the bolt where the S-pipe connects to the muffler so I'm pretty much out of luck anyways.
tracerit is offline   Reply With Quote
Old 02-22-2015, 02:34 AM   #21
2016 Camaro SS
Drives: Fast
Well, I just about got it. Here is what I did.
Completely remove both v-band clamps, don't just loosen them. I twisted the S-Pipe clockwise and lined it up with the muffler as I pushed the muffler towards the front of the car. Tightened that v-band on the muffler. Next, I aligned it left and right with the 5th muffler hanger closest to the midpipe left and right. I put on the v-band for the midpipe section now, and lined up the pipe best I could. I had to push the muffler towards the front of the car a little bit to line the pipe up well so it wouldn't move much when I tightened it.
After a few tries of this, I ended up with my passenger side tip out a hair further than the driver side. It takes A LOT of patience and tinkering with the pipes to get it to line up. If anything, my passenger side tip is just a hair further than my driver's side. Nothing anyone would ever notice but me.
Old 02-22-2015, 03:22 PM   #22
iSnack0nEmoKidz
Fried Rice Fanatic
iSnack0nEmoKidz's Avatar
Drives: Subaru BRZ 2013
i notice it :p
2013 WRB Subaru BRZ
2004 Onyx IS300
2003 Onyx IS300
iSnack0nEmoKidz is offline   Reply With Quote
Old 02-23-2015, 09:54 AM   #23
2016 Camaro SS
Drives: Fast
Originally Posted by iSnack0nEmoKidz View Post
i notice it :p
Jerk, lol.
So now after looking at it more, the passenger side sticking out about a half an inch further than the driver's side. The problem traded sides, lol. Driving on it some to see if it shifts. Otherwise, I'll mess with the connection at the mid pipe to adjust it some more.
Old 03-26-2015, 04:09 PM   #24
2016 Camaro SS
Drives: Fast
FINAL UPDATE:
I got the tips to align! My OCD has paid off.
I started from the midpipe connection to the S-Pipe. The only direction I did not try to make the pipe go was up or down. I constantly was fiddling with it to go left and right. When I'm talking about up/down I'm talking about the piece that connects to the muffler. I set it higher this time so I had to push the muffler more into the pipe and held it in place with my knee. As I tightened it, I finished and looked and voala, tips are perfectly aligned on both sides.
Royal pain the ass, and took me 3 extra v-band clamps since I stripped a few. Still even after the extra time and money spent, I really love this exhaust. Perfect tone to match my JDL front half of the exhaust.
The Following User Says Thank You to 2016 Camaro SS For This Useful Post:
Bramick (03-29-2015)
Old 03-29-2015, 10:47 PM   #25
Bramick
Bramick's Avatar
I need to try this
Old 04-12-2015, 10:50 AM   #26
Tyrant
Drives: 2014 BRZ Satin White Pearl Limited
I'm having the same trouble with mine, too. Did you turn the s pipe clockwise while at the back of the car facing towards the front?
Tyrant is offline   Reply With Quote
Old 04-12-2015, 03:39 PM   #27
2016 Camaro SS
Drives: Fast
Yes, but I was the other way around most of the time. It took many many attempts to finally get it.
The Following 2 Users Say Thank You to 2016 Camaro SS For This Useful Post:
Bramick (04-13-2015), Tyrant (04-13-2015)
Old 04-13-2015, 08:07 PM   #28
Tyrant
thanks! i've already destroyed a set of vband clamps. possible from over tightening them.
3" Perrin Resonated Cat-back w/ 3" Nameless Catted Downpipe Kevstra Engine, Exhaust, Transmission 28 05-20-2016 09:38 PM
TRADE perrin 2.5" non resonated catback for resonated otterpop Southeast 0 01-22-2015 11:14 PM
Looking to trade resonated 3" Perrin CB for resonated 2.5 Perrin CB Sacramento Area Brinks Northern California 4 07-22-2014 11:58 PM
Looking to trade resonated 3" Perrin CB for resonated 2.5 Perrin CB Sacramento Area Brinks Engine, Exhaust, Bolt-Ons 6 07-22-2014 11:58 PM
[NY] WTT - My non-resonated Perrin 2.5" Midpipe for your resonated one Foobar Engine, Exhaust, Bolt-Ons 3 07-21-2013 09:18 PM
