Old 02-04-2015, 10:17 PM   #15
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Originally Posted by drambo136 View Post
awesome thank you
one more question. does the kit mount up to the over pipe or front pipe? and stock size or 3in?
They make it either 3" which is standard or to match stock exhaust at no cost.. I'm running it with a tomei over pipe which is slightly under 2.5" Fits perfectly. The only thing they change is the dowpipe flange, the downpipe itself is still 3".
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 02-13-2015, 12:44 AM   #16
jflogerzi
jflogerzi's Avatar
@yomny Is that the stock radiator and a shroud with slim fans or aftermarket
The Following User Says Thank You to jflogerzi For This Useful Post:
sroby (02-05-2019)
Old 02-13-2015, 12:38 PM   #17
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Im glad it was a breeze for you. You did an extraordinary job for a home DIY install. Very clean and organized sir
JDLAutoDesign is offline   Reply With Quote
The Following 2 Users Say Thank You to JDLAutoDesign For This Useful Post:
sroby (02-05-2019), yomny (02-13-2015)
Old 02-13-2015, 01:02 PM   #18
Koa
hats off to you @yomny. Beautiful kit and well done on the shadetree install
The Following User Says Thank You to Koa For This Useful Post:
yomny (02-13-2015)
Old 02-13-2015, 01:03 PM   #19
yomny
yomny's Avatar
These are the fans that come with the JDL kit and the optional fan shroud.. its amazingly well done as it sets the coolant reservoir in ints correct position and its made to fit OEM radiator and aftermarket, it just drops in.
The Following User Says Thank You to yomny For This Useful Post:
jflogerzi (02-13-2015)
Old 02-13-2015, 01:07 PM   #20
yomny
yomny's Avatar
Hell of an easy kit to install, anyone that could turn a wrench and could pay a little attention to detail should try it. Thanks for putting together such an DIYer kit.
Old 02-13-2015, 01:12 PM   #21
yomny
yomny's Avatar
Ready to install my boost gauge and wideband this weekend along with boost controller for a bit more air down the pipes. The clutch is slipping already slightly at higher loads so need to take it easy while the piggy bank fills up again.
Old 02-13-2015, 01:57 PM   #22
maxjedi
The Cloudmaker
maxjedi's Avatar
Drives: GT86, G37S
Looks great. I highly suggest wrapping the MAF harness with some heat shielding material, or it will melt.
... my build thread: maxjedi's turbo "daily drifter" GT86 ...
maxjedi is offline   Reply With Quote
Old 02-13-2015, 05:37 PM   #23
yomny
yomny's Avatar
Thanks, i've been eyeing that but it doesn't seem to get hot much, not sure if its because of the coating on the hot parts.
Old 02-13-2015, 09:04 PM   #24
JDLAutoDesign
Drives: 13 FRS
That coating helps a lot. If anything you can always put some fire sleeve over it
The Following User Says Thank You to JDLAutoDesign For This Useful Post:
yomny (02-13-2015)
Old 02-15-2015, 11:35 PM   #25
jflogerzi
jflogerzi's Avatar
@yomny your thread has swayed me to go with jdl base kit. How soon do you hit full boost @ what rpm. You have an open dump correct?
2013 Series 10 FRS #553
drambo136 (02-16-2015)
Old 02-16-2015, 09:31 AM   #26
yomny
yomny's Avatar
I couldn't recommend it enough... honestly speaking.. i'm what you call annoyingly detailed and OCD, you could ask ronnie from JDL.. i called them 20 mil times and asked them twice that many questions, these guys are great and the kit.. is up to may standards.. The car starts building boost by 3k and has full by 4k.. i have data logs to show it just not sure how to upload those here. I'm running open dump and personally i suggest going with the recirculating if you're concerned with noises. The thing that bothers me which isn't related to the kit is that wastegate spring starts to open at around 2psi when the spring pressure is 7psi in my case, so you get this annoying sound pretty much any time you have boost. Perhaps once i get a boost controller it'll stay shut till the actual 7psi. Look my name "yomny" up on youtube and you'll see a few short vids i uploaded this weekend for tuning ARF and other things, it'll allow you to hear what the open dump sounds like. Till today, its been a few weeks of full boost glory, pretty much everytime i get and no overheating, leaking or issues what so ever. If you do get it and have any questions with the install ask away.
PS- Its also hard to guess who's the right guy to tune your car and this is assuming you dont have anyone locally. I just finished the final little tweaks on my tune using my wideband AFR and couldn't be happier. The tune is so refined, the idle, transition.. its way better than the OEM tune. I was tuned NA stock, then NA with full catless header and exhaust and i could say overall performance can't be beat now boosted. Its smooth, seemless, powefull when needed and again seamless. You cant tell you're boosted unless you start to build boost, theres little to no transient lag, the power is right there when you needed and this is my city daily driver, so i'm usually in what used to be the torque dip area which right now is the boost area 34k. If you're in need of a tuner i could defenitely point you in the right direction.. i dont want to mention as not sound like i'm advertising but this guy has been working with me Mon-Sunday.. including valentines day and couldn't think more highly of him. him and JDL are meant for each other lol.
Old 02-16-2015, 11:55 AM   #27
jflogerzi
jflogerzi's Avatar
Thanks for the detailed post. I all ready have a tuner in mind. This is the same guy that tuned my buddies jdl kit.
yomny (02-16-2015)
Old 02-16-2015, 02:59 PM   #28
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Looks like enough room for a 6266
RS*R Sports-i coilovers - install & review ultra Suspension | Chassis | Brakes -- Sponsored by 949 Racing 50 07-27-2022 06:29 PM
Powerhouse Amuse Single Exit Exhaust + R1000 FP Review BrianJC Engine, Exhaust, Transmission 26 06-06-2016 10:09 PM
My OEM Audio Plus 400 Install and Review Yruyur Electronics | Audio | NAV | Infotainment 156 03-01-2016 05:53 PM
TRD Sharkfin Install and review Tye300 Cosmetic Modification (Interior/Exterior/Lighting) 27 07-19-2014 07:21 PM
REVIEW: Berk Technology Single Exit Track Pipe w/ Tip NYC BRZ Engine, Exhaust, Transmission 11 12-29-2012 08:22 PM
