Old 01-12-2015, 01:00 PM   #15
extrashaky
Drives: 2014 BRZ Limited
Originally Posted by Tenament05 View Post
I should add that I've tried that as well.. same result.
Maybe it's flexing too far the other way when it's off the ground. Did you try jacking it up, then having a friend let it down very, very slowly while you try to work the bar off the bolts? (Assuming you have a good jack that you can bleed down like that.) Maybe you can find the magic spot where it's flexed just the right amount to release it.
Or maybe you could try putting it up on jack stands, then jacking one wheel to compress the suspension on one side enough to get the thing off.
If that doesn't work, maybe you can get a windshield wiper puller on the bolts and just crank each side up a little at a time to work it off.
Old 01-12-2015, 01:44 PM   #16
menikmati
Drives: 2015 BRZ, 2005 STI, 2024 Type R
AEM stuck tower bar?
All joking aside, hope you can get the bar off and get your money back.
menikmati is offline   Reply With Quote
Old 01-12-2015, 01:53 PM   #17
Stuck strut tower bar.
Now say that fast 10 times
Old 01-12-2015, 02:16 PM   #18
westendRIOT
Drives:
The bolt holes in the pics look way to pristine to have been used/damaged in an accident so my guess is just crappy workmanship from the start.
Agreed; I have the same bar and the centermost firewall bolt hole on the passenger side was misaligned just like OP's pics. Driver's side was ok. I wound up widening the hole with a drill and file and everything fit ok.
Welds looked better on mine. They're not perfect but definitely less lumpy bumpy than OP.
All in all, the triangle bar is a beast and I'm still pretty happy with it. Feels like you could hang the car off it if the strut tower bolts didn't give out.
westendRIOT is offline   Reply With Quote
The Following 2 Users Say Thank You to westendRIOT For This Useful Post:
Tcoat (01-12-2015), Tenament05 (01-12-2015)
Old 01-12-2015, 02:50 PM   #19
Tenament05
Drives: fast
Originally Posted by mav1178 View Post
I'm assuming you've contacted AEM to start, right?
Used or not, they should be made aware of these things. A braced and triangulated 1-piece strut bar like this should not have that much deflection or be that far off.
-alex
Thanks Alex, I fired off an email to their CS department. We'll see what they have to say
Definitely going to be doing all sorts of trickery tonight shaky and crew. Will let ya'll know what the results are
Tenament05 is offline   Reply With Quote
Old 01-12-2015, 03:15 PM   #20
Burrcold
Drives: Subaru BRZ Limited
If all else fails, just grind that b!tch off!
Old 01-12-2015, 03:52 PM   #21
verdecarib
Drives: 2014 Subaru BRZ Limited AT
I had the same issue with the AEM Strut Tower Bar, only the fitment was worse. Never got far enough on the install for it to get stuck 'cuz it wouldn't go on at all. Put it back in the box and sent it back for a refund. Got the Grimmspeed version instead. Exact fitment and quality product. Hence, I won't buy anything AEM makes in the future...
verdecarib is offline   Reply With Quote
The Following 2 Users Say Thank You to verdecarib For This Useful Post:
Demandred7 (01-13-2015), Tcoat (01-12-2015)
Old 01-12-2015, 10:16 PM   #22
Tenament05
Drives: fast
rather uneventfully, I got the bar unstuck after a warm engine bay on the 1 1/1 hr commute home softened things up.
Still rather displeased and am going to get a refund. IDK what I was thinking buying a strut tower bar anyway... I'm just looking for anything to update apparently.
OP is updated. Thanks for all the help guys
The Following 2 Users Say Thank You to Tenament05 For This Useful Post:
extrashaky (01-13-2015), Tcoat (01-13-2015)
Old 01-13-2015, 01:02 AM   #23
Demandred7
Demandred7's Avatar
Drives: 2018 Camry XSE V6
Love my GrimmSpeed STB - effortlessly installed. Instantly noticeable improvement in feel and handling.
Demandred7 is offline   Reply With Quote
Strut Tower Bar VS Strut Tower Brace norcalpb BRZ First-Gen (2012+) — General Topics 8 10-23-2014 10:31 PM
Do I need a Strut Tower Bar? muffinz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 10-11-2014 01:53 PM
"Strut" Your Stuff With A BeatRush Strut Tower Brace // DSG PERFORMANCE Jason@DSG Groupbuys 14 12-31-2013 09:06 AM
Swift Strut Tower Bar tonystewart Brakes, Suspension, Chassis 4 09-18-2013 02:34 PM
FS: Tanabe Strut Tower Bar whataboutbob Brakes, Suspension, Chassis 1 11-20-2012 12:53 PM
