Old 01-14-2015, 02:59 PM   #15
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
Looks like it IS adjustable.
If these were available in amber, I'd be all over it. Amber works better for fogs IMO. Otherwise, you're just getting wide pattern driving lights.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 01-14-2015, 03:04 PM   #16
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Yeah, so they are adjustable, which means we should be able to get them aimed properly. Nice. If they were available in amber I would buy the sh*t out of them, lol. Still might get them, because they are nice, but I was really hoping to find some yellow fogs. Hmmm...
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Chad86 (03-20-2015)
Old 01-14-2015, 04:00 PM   #17
aznatama
aznatama's Avatar
@Diode Dynamics
Amber please! Even better if they matched the super bright amber side marker LEDs!
'14 BRZ LTD MT DGM
Old 02-17-2015, 02:10 PM   #18
iLaw
iLaw's Avatar
Drives: 2015 BRZ, Aozora Edition
Well I didn't want to wait around for output pics from @Diode Dynamics. Its been over a month now and nothing on their website or on the thread, despite them being for sale.
I bit the bullet and bought the Morimoto ones. They should arrive in a few days. I'll post some info on install and output as soon as I get them installed. Might be a while, as its pretty cold outside, around -15C... and still -5C in my underground garage. If the outside temperature warms to around freezing, I'll do the install.
Looking forward to seeing the results!
iLaw
2020 Subaru Crosstrek Sport
2015 Subaru BRZ Aozora Edition (Sold)
iLaw is offline   Reply With Quote
Old 02-17-2015, 02:31 PM   #19
aznatama
aznatama's Avatar
Morimoto and Esuse look like exactly the same light, just different branding. Both use luxeon LEDs, both look the same from the rear too... o.O
'14 BRZ LTD MT DGM
Old 02-17-2015, 03:13 PM   #20
Diode Dynamics
Diode Dynamics's Avatar
They are the same indeed
However, you do have to be careful because there are companies selling counterfeit versions of the Esuse fog light housings
Ours use genuine Phillips Luxeon LEDs, hence the name "Luxeon LED Fog Lamps"
Nick C.
John C.
Diode Dynamics
Old 02-25-2015, 01:35 AM   #21
iLaw
iLaw's Avatar
Alright... So I finally got around to installing my Morimoto XB LED Fogs. I am impressed.
First of all the stock fog output is almost invisible to the Morimotos...
As you can see from the picture above, the stock output dimly lights up the floor on the bottom left corner, where as the Morimotos throw the light further on the road and is MUCH brighter.
This is what the beam pattern of the fogs looks like (don't be disoriented, its shining on the ceiling)
After they are installed, here is how the output changes with respect to the driver...
This is with HIDs ONLY (Fogs turned off)
This is with HIDs and Morimoto fogs on together
The beam pattern is perfect. In the above photo, the fog light beam ends a little bit beyond the red car.
As for the colour, they are a tiny bit bluer/purpler than the stock HIDs. They perfectly match the boomerangs. From a distance, everything matches due to the prism effect of the HIDs.
iLaw
Old 03-20-2015, 01:55 PM   #22
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
I've been trying to find a solution for yellow LED fogs to get something similar to the HID look. I was looking at Diode Dynamics XML2 yellow fog, but it seems they are no longer producing them. I have now found PIAA offers a yellow LED fog with higher output than the DD XML2
I think now I will have to decide whether I go with these or just add the Laminx yellow film. Not really into the film as I like to have a clean look when the lights are off.
I had the PIAA ION yellow fogs on my old car, which were top notch. The new LED ones have a higher output. I would like the yellow color with true fog functionality and not just for looks.
I really like the Luxeon LED fogs, but it's unfortunate there are no yellow options.
http://www.ft86speedfactory.com/lami...ellow-725.html
http://www.piaa.com/LEDbulb
Chad86 is offline   Reply With Quote
Old 03-20-2015, 02:05 PM   #23
Diode Dynamics
We are still putting yellow XML2's into production. It has taken a bit longer than expected, but we take our time to make sure things are done correctly.
They are expected to arrive in late April
You could wrap the Luxeon housings in yellow? Unfortunately Phillips doesn't make a yellow Luxeon T LED, otherwise we would have them available
Nick C.
John C.
Diode Dynamics
The Following User Says Thank You to Diode Dynamics For This Useful Post:
Chad86 (03-20-2015)
Old 03-28-2015, 01:14 AM   #24
Blue-Sensei
Blue-Sensei's Avatar
Drives: '14 WRB BRZ LTD Turbo
They are expected to arrive in late April...
Nick C.
Seems like the XML2s just keep getting pushed back T_T
Blue-Sensei is offline   Reply With Quote
Old 03-28-2015, 08:48 PM   #25
Poodles
There is a 3000K Luxeon T, but 3000K on an LED is more a warm white and not an intense yellow or amber.
Old 03-28-2015, 09:19 PM   #26
Chad86
Chad86's Avatar
Drives: Toyota GT86
Cool
I found a review for the PIAA yellow LED fogs http://maxima.org/forums/7th-generat...piaa-leds.html
Looks like I will be going with these. The color and output looks amazing. From comparison to the DD XML2 1420 lumens, these have a higher output at 1800 lumens.
The picture on the left is the DD XML2 vs the right (and below) PIAA Performance LED fog.
Old 04-11-2015, 05:21 AM   #27
SoCalArgento
Drives: 2014 Argento FRS
LED Fog Lights
Anyone have any input on these Morimoto LED Bulbs?
http://www.theretrofitsource.com/mor...l#.VSjnFIZHanN
They are rated at 3000lm which seems really bright for fogs, and idk how scattered light output would be since no lens.
I was looking into DD XLM2 bulbs as well but these have higher output for cheaper. I have Morimoto HID's and they are amazing so far.
Any helps is greatly appreciated 👍
SoCalArgento is offline   Reply With Quote
Old 04-11-2015, 10:44 AM   #28
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
Just a note, some people are confusing lumens for brightness. "3000 lumens is bright for fogs" is sort of a silly statement.
lumens is a measure of total light output
candela is a measure of brightness
3000 lumens, considering how wide these project, is not necessarily 'too bright' for fogs.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Valenti Tail Lights - Running Lights not working at all Antstronaut Cosmetic Modification (Interior/Exterior/Lighting) 12 08-10-2017 07:11 AM
Valenti / Lexon / Tom Tail lights, Winjet Headlights, Front Bumper lights and Mirrors Speed Element Exterior Parts - Lighting 224 12-06-2016 02:07 PM
NEW EXCLUSIVE Valenti Tail lights, Winjet Headlights, Front Bumper lights and Mirrors Speed Element Northern California 34 01-14-2015 05:32 PM
**PHASTEK** HID Headlights, Reverse Lights, Fog Lights (FR-S / BRZ) PhastekSport Exterior Parts - Lighting 18 07-09-2014 07:42 PM
Selling my new GT86 Head lights and Tail lights diddyv AUSTRALIA 2 06-04-2014 05:36 AM
