Southern California SoCal
Old 01-05-2015, 04:06 PM   #15
Originally Posted by 2much View Post
I have not had a front plate on my last 3 cars, since I started driving in 2002. I've been pulled over a few times for various things, parking tickets, etc., and I've never had a cop mention anything about the lack of a front plate.
Seems to be pretty common in Cali.
My last car I needed to change the bolts to put a frame on for my front plate. Left it off as the hardware store was only a few blocks away. Sure enough got pulled over for no plate just before the parking lot. Showed him the parts and he laughed and let me off with a warning.
Old 01-05-2015, 04:09 PM   #16
2much
I wanna go fast
Drives: 2013 FR-S 6MT
well everyone's nice in Canada so they gotta get you for whatever they can find I guess!
2much is offline   Reply With Quote
Old 01-05-2015, 04:28 PM   #17
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
I 3M taped mine. no problems so far after 20k miles...
mokinbird87 is offline   Reply With Quote
Old 01-05-2015, 05:41 PM   #18
willypongtb
P MAI86
Drives: subaru brz limited
I used 3m double side tape no problem been over 2 years
willypongtb is offline   Reply With Quote
Old 02-25-2015, 09:55 PM   #19
brianhj
Drives: 2017 Camaro 1SS
Get a thin piece of aluminium (thin but not too thin so it doesn't bend) cut smaller than the license plate. Cut a hole in each corner. Zip tie this to grill. Put layering of some material behind the bottom to make the plate perpendicular to ground if need be. If the plate is thick enough you could drill two holes in each corner and drill a recessed channel between them deep enough for a zip tie (1/16th of an inch or so). Now you have a metal surface that is flat, even with zip ties holding it in place, with which to cover in double sided mounting tape to stick your license plate on. After it's on you can't see zip ties.
Seems like a lot of work but it would look clean a.f.
PS you could also use a piece of 1/8 inch ABS plastic. It's tough and sturdy and easier to cut.
brianhj is offline   Reply With Quote
DIY: Center Mounting the Front License Plate WITHOUT DRILLING Neurytic DIY (Do-It-Yourself) Guides 28 05-14-2018 05:37 PM
Problem hooking up IPOD Shuffle philstar Electronics | Audio | NAV | Infotainment 1 03-17-2013 07:23 PM
Hooking up an Amplifier to bespoke questions. 6-Shift Electronics | Audio | NAV | Infotainment 6 01-26-2013 09:52 AM
Front bumper drilling/plates mooshoepork AUSTRALIA 5 11-18-2012 06:02 PM
BRZ Front Plates pinoyplaya BRZ First-Gen (2012+) — General Topics 20 08-30-2012 11:48 AM
