#15 |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
i have 6/7 on my AST 4150's. in love with that suspension, your 9/10 must be pretty stiff on the street!
#16 |
Because compromise ®
Drives: Red Herring
I have 6k/6k atm with the Eibach sways. The Eibachs are towards the stiffest sway options available. I am hoping that the removal of the sways plus the higher spring rates won't be that big a jump in over all stiffness. Remains to be seen/felt.
#17 |
Drives: 2014 brz
I run 8/8 on my MCS coilivers and think it's a good compromise for everyday driving. I can definitely feel the increased spring rates on bumpier roads. Driving impression with them on the track was awesome. The increase of control and confidence felt like I had upgraded tires. I really don't feel the need to increase roll resistance (sway bars) when on RS3s tires. I feel there would be no benefit due to their sidewall stiffness, but PSSs are a different story. An adjustable sway bar to would help me out to better tune oversteer/ understeer
#18 |
Junior
Drives: a car
Did you have these shock dyno'ed @Captain Snooze? and/or can find one? I've looked for one but I cant seem to find it.
I feel like we need atleast one rep from each of the big names on here that would help so much
#19 | |
Drives: Red Herring
1/ I don't think a dyno sheet will tell me what they would be like to drive on. That is, the numbers don't convey the experience. 2/ I wouldn't know how to relate the information given on a dyno sheet to real world application. 3/ Given that each damper is made to order any dyno posted is only applicable for that car on those spring rates. 4/ I didn't think of it :| I have just emailed the distributor asking for dyno sheets and will post his reply.
Last edited by Captain Snooze; 01-10-2015 at 05:58 AM. Reason: emailed distributor |
#20 |
Junior
Drives: a car
Hey atleast we can kinda cyber buttdyno it ourselves with your "custom setup" that you got goin on if we get a dyno sheet
#21 |
the tuna, no crust.
i have a lot of bushings done but no sway bars...can't decide if i want them though, you're swaying me not to haha.
#22 | |
Drives: Red Herring
On the plus side ways are a relatively inexpensive for noticeable gains. On the minus side not only do I feel cross talk at the front but I get this weird slow speed waggle at the rear on quick medium radius bends. I am hypothesing (I can't stress that enough) that it is the rear sway loading and unloading side to side. Maybe it is a positive feed back of the rear spring rate and the sway bar rate. I do not know. I haven't read of this else where. These negative points are not significant on public roads. I do not get this waggle at the track. Given the range of sway rates available and the possible spring combinations available I am thinking choosing the "right" sway bar is a bit of a gamble. (I have seen some math that is just plain scary http://www.optimumg.com/docs/Springs...Tech_Tip_2.pdf ) Useless statement coming up. If you track your car sways might be advantageous and if you didn't like them you could always sell them only taking a small loss.
#23 |
Best coils under a grand threads go for pages and this might be lucky to get to page two. Says a little bit about the community I think.
Drive upgrades. Don't buy them.
#24 |
the tuna, no crust.
the thing is though, at track my car feels excellent, at auto x is where i really really feel that a front bar would help me out a lot.
but then i drive it on the street and i don't care anymore something in me just wants to keep interring though, but i should really leave it alone, its hell of a car already. |
#25 |
#26 |
Drives: 2017 BRZ
I suspect those spring rates won't get you what you want without a swaybar - however, I like your approach.
Very interested in how this works out for you since I'll probably start at 9k/10k but will keep the stock sways (not AST's, mind.)I'll be tuning for AutoX though, so will still likely end up in a different place. I was originally going to start at 10k all around but have been convinced to try a little less forward bias to start (assuming my math was right in the first place.) I assume the rear end waggle is with the nannies off? The first few times I ran into the influence of the nannies it was more than a little waggle, very disconcerting. I was coming from a (lightly tuned, all strut no spring so horrible ride) FWD (ACR) though. Maybe somewhere between the thorsen and traction control? I can imagine a way no rear sway has potential to help that if you've got the droop travel, but not sure if it actually works that way. Don't remember if you've a clutch-type diff or the stock unit.The math is a lot less scary once you plug in the known values. Even better if you can find a spreadsheet or similar that hides it all from you... enter the variables and see how it works out. I haven't found anything like that, am almost tempted to see about putting something together - I suspect others would have done so already if it were that easy. |
#27 | |
Drives: Whiteout Scion FR-S
Whiteline Rear Subframe Bushing Inserts That is until recently, as now my rear shocks are completely gone. (This is the reason I am reading lots of posts about my suspension options – the fronts are almost as bad too.) Whiteline also has a newer kit that may also work well: Whiteline Rear Subframe Bushings Same idea, just a more comprehensive solution. Both of these should be readily available in Australia .Also, I have found that the car GREATLY benefits from this front brace: Carbing Front Crossmember Brace If this is too difficult to source locally, there are a few other companies that make somewhat similar products if you cannot find someone that sells this one. I had to go with this vendor's site to show the product on this one as I could not find a Carbing company site that showed the product.
#28 |
Drives: Red Herring
Mmmm... I can't quote you Black Tire
![]() I had the rear sub-frame bushes replaced a while back (full bushes,not the inserts). I have thought about the front subframe brace but I hadn't read of any benefit so I hadn't pursued it. I had alloy steering rack mounts installed but I couldn't tell any difference. I have considered these as well but once again have not read of any reviews. http://www.gtspec.com/product/gtspec...r-s-gt86-ft-86 I might have to put that front brace on the shopping list but the law of diminishing returns and diminishing wallet have prevented me so far.
| Hood Dampers | AlexK | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 01-20-2015 05:08 PM |
| 2013 AT Ultramarine FRS ODO 5200 SJ/Oakland | peachsnow | Cars for Sale/Trade | 1 | 11-20-2014 06:38 PM |
| For Those With MCA Dampers | Captain Snooze | AUSTRALIA | 0 | 08-14-2013 05:13 AM |
| QA1 dampers? | Captain Snooze | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 01-06-2013 10:00 PM |
| Which Dampers to get? | djliquidsteele | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 26 | 08-27-2012 02:13 PM |
