Old 12-30-2014, 02:31 PM   #15
strat61caster
strat61caster's Avatar
Still not convinced OP isn't looking at the "Trac Off" light that only appears when you press the "Trac Off" button for use in snow/mud <30 mph (and does disappear), as long as the slip light is illuminated (and not the green VSC) you're good to go imo. (blahblahblah abs fuse not fully off)
http://www.ft86club.com/forums/showthread.php?t=8212
OP, pictures will be helpful, of the dash/lights illuminated and then shortly after when they turn off. The situation seems strange and if truly a problem a dealer ECU reflash is likely the solution. Of course, we're all assuming you haven't monkeyed with the software which would put you at the mercy of your tuner or sacrificing the money you spent.
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 02:48 PM
Traction Control vs. Stabilization Control vs. Sport Question MurderRider Scion FR-S / Toyota 86 GT86 General Forum 26 08-07-2014 01:56 PM
Why does my BRZ have LESS traction with traction control on??? BRZnut BRZ First-Gen (2012+) — General Topics 19 12-16-2013 04:28 PM
CEL Traction Control ON then OFF HATED1 Issues | Warranty | Recalls / TSB 5 09-24-2012 08:11 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 12:20 PM
