Old 12-05-2014, 12:44 AM   #15
s2d4
s2d4's Avatar
Originally Posted by Wayno View Post
I sold mine. You really need a custom tune with those blocks, or pull a lot of timing so it doesn't knock which i posted in the block specific thread.
yeah, never knew what the fascination was as it barely did anything well and had way too many negatives.
Old 12-05-2014, 01:34 AM   #16
steve99
  • Those blocks seem to work well on a completly stock car but once you get header and a tune their benifit seems much diminished and if your on e85 as well dont seem worth tue trouble.i think follow @Wayno 's lead and sell them once you get header installed
Old 12-05-2014, 02:16 AM   #17
Perth-86
Perth-86's Avatar
Drives: GT86 (Auto)
Shall follow the lead on that one - I haven't been impressed with them on a stock engine so far, two be honest.
In fact - We did a dyno day the other day.
Mine made 143.5 which was lower than a completely stock auto on the same day which did 144.4
It was pretty embarrassing!!
Perth-86 is offline   Reply With Quote
Old 12-05-2014, 02:22 AM   #18
s2d4
s2d4's Avatar
Peak was not the point of the block in the first place.
The Following User Says Thank You to s2d4 For This Useful Post:
Perth-86 (12-08-2014)
Old 12-05-2014, 05:37 PM   #19
steve99
as s2d4 said those block are ment to shift the peak power lower in the rpm range not rearly increase peak power.
As our 98 fuel is not much good, the power you make on 98 petrol is very dependant on the brand of fuel your using.
unitedP100 fuel was better but has been pulled from sale.
BP ultimate or Shell seems the best 98 but on stock tune you can still get significant knock which drops your IAM and reduces power.
Old 12-08-2014, 04:19 AM   #20
Perth-86
Perth-86's Avatar
Drives: GT86 (Auto)
General conscious then to remove them from this type of set up?
Ive been scoping out for other ZA1JA01I tunes other than the standard Stage 2 UEL tune (which feels good via bum dyno)
The powerblock install cost me two cartons, wonder if I can get them to remove them for 1 :-)
Cheers for the help boys.
Old 12-08-2014, 06:28 AM   #21
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
There's a fix for that...
Fizz is offline   Reply With Quote
Old 12-08-2014, 07:46 AM   #22
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
I'm also having issues here. Plugged in my OFT this evening. All was going well like the video until after it read my stock tune.
Now it just shows this message.
Wise is offline   Reply With Quote
Old 12-08-2014, 07:48 AM   #23
Wise
Circle Work Clerk
After that I plugged the unit into the computer and downloaded the OFT manager latest version 1.15.
I also downloaded the V 2.062 OTS Maps. I can't work out how to put these on the device though. I go into upload data and it keeps telling me that the maps are the wrong size or something.
After this I went back downstairs and plugged the OFT back into the OBD2 port. Now all I'm getting when I select tuning is the message above.
Can anyone help me?
Old 12-08-2014, 07:51 AM   #24
steve99
I am pretty sure that means the oft cannot autogenerate a tune for your rom calid, from the preloaded database.
use oft to read your calid under diagmostics ecu info, download the latest complete tune files from oft site and load it up manually
see oft tips link below
Old 12-08-2014, 07:54 AM   #25
steve99
Can anyone help me?
make sure you unzip the tunes then go to the directory for your calid series like G series , C series and load up the .bin tune file you want. the oft will not let you load tunes that dont match your original calid.
Old 12-08-2014, 08:10 AM   #26
Wise
Circle Work Clerk
Thanks for your help mate.
I've unzipped them using rar. The files inside the C and G Bins appear on my comp as VLC files.
When I try to add them into Modified 1 or Modified 2 or so on. I get the message below.
Old 12-08-2014, 08:19 AM   #27
shif7i7down
Erected Member
Drives: frs
Use the "G" files for your car, should work :/
shif7i7down is offline   Reply With Quote
Old 12-08-2014, 08:23 AM   #28
Wise
Circle Work Clerk
Originally Posted by shif7i7down View Post
Use the "A" files for your car
Still get the "Selected File is Not Compliant" message.
Possibility of Live Tuning brn12345 Software Tuning 17 03-30-2020 05:39 PM
climate control swap possibility Mrqb22 Cosmetic Modification (Interior/Exterior/Lighting) 143 03-15-2019 12:46 AM
Possibility of ripping paint off from debadging? Pandanoid Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 10-23-2014 09:31 AM
Sorta related... Skurj Tracking / Autocross / HPDE / Drifting 2 06-03-2014 10:46 PM
Possibility of Scion Sedan? KidWonder Other Vehicles & General Automotive Discussions 6 12-16-2011 06:53 PM
