Old 12-01-2014, 10:52 AM   #15
STV3
Señor Member
STV3's Avatar
A 225/45/17 Mich PSS will be fine for that size wheel. They run very wide. The tread with on that tire is 8.2" wide.
http://www.tirerack.com/tires/tires....omCompare1=yes
^Click on specs^
STV3 is offline   Reply With Quote
Old 12-01-2014, 10:52 AM   #16
STV3
Señor Member
STV3's Avatar
A 225/45/17 Mich PSS will be fine in that size wheel. They run very wide. The tread with on that tire 8.2".
Old 12-01-2014, 07:21 PM   #17
dtrop
Drives: Wrb 2014 limited brZ
according to that, 225/45 can accommodate up to a 8.5" wheel. Does that mean after 8.5 it starts stretching?
dtrop is offline   Reply With Quote
Old 12-02-2014, 07:43 AM   #18
troek
troek's Avatar
Drives: 2012 Toyota 86
unless you want the look of a fatter tire, i would suggest the 225/45. its cheaper and will have more than enough grip. i run a 205 rs3 on a 16x7" and have more grip than most would imagine. some guys stateside have put down some smoking fast times on 225s.
Old 12-02-2014, 09:41 AM   #19
dtrop
I want a tire size that doesn't stretch, that is most important.
Old 12-02-2014, 09:56 AM   #20
STV3
Señor Member
STV3's Avatar
Well the PSS in a 225 on an 8.25" wide wheel will sit square and wont have any stretch at all. On a 8.5" wheel it might have a tiny bit of stretch but it wouldn't be very noticeable.
Old 12-02-2014, 03:15 PM   #21
RobertPaulson
Hisnamewasrobertpaulson
RobertPaulson's Avatar
Drives: 2017 Golf R
I run a 245/40 MPSS on a 17x9 wheel and its only slightly stretched, on a 8.25 i'd try to find a 235 but you could run a 225 wide tire. You won't be able to find a tire that gets you better MPG than the stock primacies because they're Low rolling resistance tires. they're already engineered to give you better MPG than most tires. I used to average over 30mpg on the primacy, i'm down to around 27-28 on the wider super sports.
This is your life and it's ending one minute at a time.
RobertPaulson is offline   Reply With Quote
Old 12-02-2014, 04:31 PM   #22
STV3
Señor Member
STV3's Avatar
Well if you look it up, a 245/40/17 PSS is only a 8.5" wide tire. Thats why you have a slight stretch.
The 225/45/17 is 8.2" wide and will have no stretch on a 8.25" wide wheel.
He could go 235, but that will be more money and probably more tire than he needs.
Old 12-03-2014, 09:39 AM   #23
dtrop
I appreciate all the responses, they have been very helpful and it seems like 225/45 will be okay.
Are mss overkill for daily driving? I would like to think I drive aggressively during spring/summer /fall but I won't be tracking the car.
Old 12-03-2014, 09:51 AM   #24
STV3
Señor Member
STV3's Avatar
Not at all. I have had them on my other car for quite a few years now (which I daily drove before I bought my FRS) and they are quiet, comfortable, supply a lot of grip, and the tread wear has been great for me.
I will be getting them for my new set of wheels for my FRS next year too in that same size.
Old 12-03-2014, 05:36 PM   #25
RobertPaulson
Drives: 2017 Golf R
absolutely not, you want that amazing dry and wet grip for daily use and while they're good enough for the track, they aren't a track tire
The Following User Says Thank You to RobertPaulson For This Useful Post:
STV3 (12-03-2014)
Tire size advice Lost Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 11-28-2016 06:42 PM
tire advice kosoku Tracking / Autocross / HPDE / Drifting 24 12-17-2013 11:51 AM
Need daily driver tire advice bear89103 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-26-2013 01:15 PM
Wheel/Tire Advice mrjester Tracking / Autocross / HPDE / Drifting 1 05-18-2013 11:48 PM
Starting out wheel/tire advice? rainmonkey Tracking / Autocross / HPDE / Drifting 19 05-02-2013 01:44 PM
