Old 11-22-2014, 08:59 AM   #15
anajri
Drives: GT86
Originally Posted by dabocx View Post
This is with the GTX3076 .63 ar?
yes the one that comes with the standard kit
anajri is offline   Reply With Quote
Old 11-22-2014, 01:47 PM   #16
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Originally Posted by anajri View Post
yES REAL NICE THE ONLY ISSUE Iam having is with the Ac it turns of at a Trafic light when the car stops but once im moving again seems to con on line again
any thoughts on this? I have tried everything
This car does the same thing. Haven't figured it out yet
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 11-22-2014, 04:41 PM   #17
Whatabouteggs
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
Lol, I like how this issue crops up everywhere. The AC in these cars is just terrible unfortunately. As near as I can tell you might as well use a box fan if it's above 90 degrees.
Questions for OP:
What all has been done to the fuel system? I noticed you're on the stock pump
How is the AEM meth kit? What are you running in it and how do you have it set up?
What turbo is this specifically? Or is it the same one on the stock Ptuning kit?
What are you making on 93? Have you done e85? Are you running a tune that controls for octane rating?
Any other supporting mods? (accumulator, oil cooler, failsafe, that kind of thing)
Someone else asked this, but what's the deal with Motec?
My other questions are more about wear (8k redline/boost vs longevity stuff) and probably aren't things you could comment on yet.
Whatabouteggs is offline   Reply With Quote
Old 11-24-2014, 07:25 AM   #18
anajri
Drives: GT86
1) Stock fuel system
only changed port injectors with the 770cc that came with the kit.
2) meth kit has been performing flawlessly. i connected the pump to the windshield water container and use that as the water/meth container. this helps tell me when the water level is low..
3) completely stock Ptunning kit
4) I dont expect the numbers to chance much on 93 oct bacause of the meth kit. My numbers seem on par with what people are running with the 93 +meth kit. But without the meth kit i never really tried. I just make sure i always have water/meth in the tank. NO E85...the only E85 we have here is VPracefuels c85 and it is very expensive.
5) what do you want to know about motec. i just got sick of remote tuning. and having to wait for someone else to have time for me plus got a good deal on it....
6) Aem tru boost boost controller, no oil cooler, I have tried to keep it as simple as possible.
on longevity we will see there is no way of knowing yet but if its well tuned there should be no Issues. but we will see...... I have givven a few freinds a ride and still no issues. ill try and get some pull videos on the street so you can see it in action
Alf
Old 11-24-2014, 09:08 AM   #19
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
@Synack
Old 11-24-2014, 01:01 PM   #20
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
6) no oil cooler
This will be the death of the engine, calling it.
Old 11-24-2014, 01:56 PM   #21
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by Whatabouteggs View Post
Have you done e85?
If you are curious about how this kit performs with E85 this is what we have seen here between my buddy @mkivsoopra and I who both have the same setup:
On ~E80
6 psi = 280 whp
9 psi = 340 whp
15 psi 450 whp, 360 ft lbs
haven't tested beyond that.
On 91 pump:
8-9 psi = 270 - 280 whp (with no benefit seen with upping the boost due to timing needing to be pulled)
The Following 3 Users Say Thank You to sw20kosh For This Useful Post:
mkivsoopra (11-24-2014), Mrc@ptuning (02-10-2015), rb6freak (11-24-2014)
Old 11-24-2014, 01:58 PM   #22
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
On ~E80
6 psi = 280 whp
9 psi = 340 whp
On 91 pump:
Could I buy you some beer in exchange for a ride
GotBRZ1691 is offline   Reply With Quote
Old 11-24-2014, 02:38 PM   #23
bfrank1972
Drives: 2013 FR-S Argento
Hah, all depends on how you drive the thing. For street driving and the occasional fun pull you can probably get by just fine. If you're easy and not launching it the drivetrain will probably survive ok as well. I think that AEM controller/failsafe is a really good idea - tune can be great until something goes out of wack, that's where high boost cars really go south very quickly. Keep us posted
bfrank1972 is offline   Reply With Quote
Old 11-24-2014, 03:59 PM   #24
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
http://www.ft86club.com/forums/showthread.php?t=66342
Theres evidence to suggest otherwise.
Old 11-24-2014, 05:42 PM   #25
Reaper
Reaper's Avatar
Drives: violent
460whp driven hard enough to melt the dust boots out of my brake calipers with over 2000 foot elevation gain and I have no oil temp issues without an oil cooler in the south. I do have an 8 quart oil pan though.
The Following User Says Thank You to Reaper For This Useful Post:
Calum (11-24-2014)
Old 11-24-2014, 08:40 PM   #26
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Well that's why!! Your engine doesn't produce enough heat to heat up that amount of oil.
Old 02-10-2015, 10:19 AM   #27
Mrc@ptuning
Mrc@ptuning's Avatar
Drives: S1000RR
DO NOT attempt to run 500whp (dyno dynamics) on the stock block. The stock connecting rod's will snap at the small end. Speaking from experience Stay at 450whp or below if you're not ready for a built motor.
Mrc@ptuning is offline   Reply With Quote
The Following 6 Users Say Thank You to Mrc@ptuning For This Useful Post:
Dinko (02-10-2015), Joveen (02-15-2019), lucid215 (02-10-2015), mkivsoopra (02-10-2015), rb6freak (02-13-2015), sw20kosh (02-10-2015)
Old 02-10-2015, 01:26 PM   #28
anajri
Drives: GT86
thanks thats where it has stayed.... still running strong.
PTUNING Turbo Kit Owners Topic kanundrum Forced Induction 1238 12-11-2021 09:22 PM
PTUNING: 501WHP 377WTQ 20psi Stock Motor PTUNING Spec-SS GTX3076R Turbo System ptuning Forced Induction 47 06-16-2014 03:52 PM
Revworks turbo 10k update jamesm Forced Induction 88 02-13-2014 11:54 AM
PTUNING FR-S/BRZ Turbo Testing @ VMP 4/21/2013 Events@Ptuning Tracking / Autocross / HPDE / Drifting 12 01-13-2014 10:22 AM
Ptuning turbo kirlt bjun Forced Induction 9 11-16-2013 02:14 PM
