Old 12-16-2014, 03:59 PM   #15
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by OkieSnuffBox View Post
Seeing all these threads like this is really starting to make me regret purchasing this car.
I specifically bought the car to use as a DD and occasional auto-x and HPDE work.
You see all these negative threads because people tend to complain and moan when things go wrong. People don't come to the forums to say "FYI everyone, my car is running fine!". They come here to say "My engine blew!" and to look for people who have had the same issues.
You have to take it with a grain of salt. At the tracks here I am seeing boosted FA20's surviving hard track use. Just enjoy your car and maintain it well.
Personally I am at 57k miles, 47k of which were boosted and I have been tracking this thing since day 1.
Old 12-16-2014, 04:01 PM   #16
OkieSnuffBox
Drives: '23 BRZ Limited
I'm sure you're right. I know exactly what I'll do to the car to prep for it use.
I got tired of working on my older track rat Miata which is why I picked up a new car with the hopes I could do wheels/tires/brakes/suspension, put 60-70k miles on it, return to stock, and start again before anything big happened.
Old 12-16-2014, 06:22 PM   #17
Ultramaroon
not playing cards
Ultramaroon's Avatar
No way, man. Anytime you stretch its legs it's gonna get cramps. No substitute for extra TLC.
Old 12-17-2014, 09:31 AM   #18
OkieSnuffBox
Hence proper prep. Good syn in all the driveline components, Jackson Racing oil cooler, ducting the stock radiator, extra heat protection for the number 1 coil.
Unlike in the old track car where I think it was used engine I bought off a racer who claimed it was good (yeah bad crank pulley, again). I decided I was tired of it.
Old 12-17-2014, 09:42 AM   #19
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
From our experience building and racing the FA20 engines I would have to chalk this up to an assembly issue. The head gasket is very good and the actual sealing ring for the combustion area is larger than what we get with the STI engines.
Unfortunately OEM is what it is but when we build these engines we do address head gasket issues with better studs and torque specs we found to be ideal. In the past we had tested oem head bolts to be very good until they got extremely hot like what track guys see and street drivers do not.
Element Tuning is offline   Reply With Quote
Old 12-17-2014, 10:16 AM   #20
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
I could not imagine using a head gasket problem to justify selling a twin. The aftermarket already has some nice head gaskets to replace the OEM ones with. Just replace it IF your car has that problem and continue enjoying the car.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 12-17-2014, 12:04 PM   #21
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
I spoke with Element Tuning over the phone about building these engines. They are a lot more time consuming than that EJ series to build. Plus pulling the engine on a new car to replace the headgasket.. It had 29k miles on it. I shouldn't be having to do that to start with. If the bolts and torque specs on assembly are the reason for failure that's fine and I hope there's a solution figured out. I will admit my choice was not just based on that but that was my last thing on the list that made my get rid of it.
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
Old 12-17-2014, 07:34 PM   #22
BlueBoy
Drives: 2013 Blue 6MT FR-S
So I finally have the car back from the dealership after the head gasket replacement. It took so long because two valve shims were on back order for about 2 weeks. I asked for new head bolts to be installed but Toyota said the original bolts were reusable. (I thought torque-to-yield bolts were only good for one application.) I've been driving it lightly for 250 kilometers now and will continue breaking it in for the next 500 to 750 kilometers.
I originally asked about replacing the OEM head gaskets with aftermarket ones. They told me if they did that then my warranty wouldn't cover the issue if it happened again.
I guess the big test will be after running it hard during an upcoming autocross in January at which point I'll see if there's any sweet white smoke being blown or any significant loss of coolant.
My car has 44,500 km on it so I guess I'm good for one more head gasket replacement under warranty (100,000 km) at which point I'll seriously consider using different head bolts and gaskets.
Just to be clear, I've only tracked my car twice and ran maybe 12 autocross events. I've also regularly short changed the engine oil.
BlueBoy is offline   Reply With Quote
Old 12-17-2014, 08:18 PM   #23
Ultramaroon
not playing cards
They aren't TTY. Perfectly normal to reuse them.
Old 12-17-2014, 08:51 PM   #24
nyfries
Drives: 14 FRS Whiteout
Interesting. I have been seeing dissapearing coolant in the overflow resouvir but don't seem to notice white smoke. Also very sproadic. Would there be any significant problem if I ignore it?
nyfries is offline   Reply With Quote
Old 02-19-2015, 05:38 PM   #25
notout86
Drives: GTS 86 auto
GREAT thread. So much sensible and knowledgeable info. contributed.
About the hole at the top of the overflo tank.... ours is not tiny. It lets dirt in which you can see up high if you peer in the bottle. I put a bit of open-cell foam over it as a filter.
To reduce evaporation I put a thick gauge Al foil heat-shield around the bottle. Have an air gap between it and the bottle to allow convection cooling. Similarly you can shield your battery.
GTS86 Auto (Australia)
notout86 is offline   Reply With Quote
Old 02-19-2015, 05:44 PM   #26
notout86
Drives: GTS 86 auto
Which is number 1 coil and how do you protect it please?
Old 10-21-2015, 11:57 PM   #27
Cal3000
Drives: Panda FR-S
At 100k miles, I seem to be having this same issue. After high RPM driving from day to day, I seem to lose 0.5L of coolant every day. I don't lose as much under normal driving. After a hard drive, the overflow tank is overflowing like crazy. It's becoming annoying. No warranty=expensive repair.
I took my car to a Midas and they did a hydrocarbon test for the coolant and didnt find anything.
I don't know what's going on. lol
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 10-22-2015, 12:09 AM   #28
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Have you logged your coolant and oil temps?
jawn is offline   Reply With Quote
Coolant Disappearing civicdrivr Issues | Warranty | Recalls / TSB 313 05-18-2016 09:56 PM
Cloud of white smoke on startup wawro569 Issues | Warranty | Recalls / TSB 25 01-16-2015 12:55 PM
is my head gasket blown? BrianBlueBRZ Other Vehicles & General Automotive Discussions 4 07-22-2014 09:45 PM
Coolant disappearing after track day? ddeflyer Tracking / Autocross / HPDE / Drifting 4 06-30-2014 03:29 AM
White smoke in Engine bay Pinoywhiz Engine, Exhaust, Transmission 7 04-07-2014 06:10 PM
