Coolant disappearing after track day?
So I've had my coolant disappearing after track days (I was getting really freaked out) and thanks to @ReHabJeff I think I figured it out. Basically, if you are lazy (like me) and don't always pop your hood after a session, you pretty much just steam it out of the overflow reservoir (it is VERY hot in the engine bay when you come off track and just park). If you are having issues with vanishing coolant, try always opening the hood after a session, it seems to have worked for me!
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next! |
| The Following User Says Thank You to ddeflyer For This Useful Post: | RehabJeff86 (06-30-2014) |
Drives: 2014 FR-S
It sounds like these things get really hot when you track them. Is there any upgraded radiator/oil cooler? The perrin one looks nice but a bit $$$$. I'm lucky that the nearest tracks to me are a good 3 hours or so away.
Drives: '13 FR-S Raven 6MT
The coolant reservoir has a little hole in the top front-facing side. It's almost under the bumper so it's hard to see. Been noticing mine low as well. Trying to track down some Toyota/Subaru Super Blue coolant on the cheap. Best I've found so far is about $22.
#4 | |
The Stig's German cousin
![]() Another trick I use is to turn my a/c on full blast after running, this turns on the radiator fans to blow air right at the block and suck air through the radiator. |
| The Following 3 Users Say Thank You to renfield90 For This Useful Post: |
#5 | |
| Tags |
| antifreeze, coolant |
| Coolant Disappearing | civicdrivr | Issues | Warranty | Recalls / TSB | 313 | 05-18-2016 10:56 PM |
| FRS uses a lot of coolant? | JLMtm | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 124 | 01-23-2015 07:34 AM |
| e85 Disappearing Act - NY Special | Luckrider | Software Tuning | 66 | 04-03-2014 08:07 PM |
| Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? | mike the snake | Forced Induction | 8 | 04-01-2014 06:56 PM |
| Low Coolant | Tt3Sheppard | Issues | Warranty | Recalls / TSB | 12 | 11-25-2012 01:03 PM |
