Old 11-15-2014, 09:22 PM   #15
shif7i7down
Erected Member
Drives: frs
That was not the first pull. But it was within the first 15mins of driving and multiple pulls
shif7i7down is offline   Reply With Quote
Old 11-15-2014, 09:28 PM   #16
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
I bet its an OFT tune. Is this a fresh tune or did you record this log hours later ?
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 11-15-2014, 09:58 PM   #17
shif7i7down
Erected Member
Drives: frs
That was the log of when it happened
Old 11-15-2014, 10:19 PM   #18
Bach415
Bach415's Avatar
Drives: Whiteout FRS
When you say flutter, do you mean something like this sound? Cause that's what's coming to my head when you say flutter when you let go of gas. [ame="https://www.youtube.com/watch?v=D3djVW3dSGA"]Nissan Skyline GTR R34 Turbo Sound - YouTube[/ame].
Bach415 is offline   Reply With Quote
Old 11-16-2014, 01:48 AM   #19
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
What your hearing is the fluttering from the headers when building boost. It is because they are slightly unequal and have flex joints on only two of the four runners. Every kit I have installed or heard has the same noise. It is absolutely nothing to worry about, and you can actually mask it very well by wrapping the headers.
The Racers Line is offline   Reply With Quote
Old 11-16-2014, 03:24 AM   #20
shif7i7down
Erected Member
Drives: frs
It's a bit different then that video, I'll have to capture it with a camera so that it'll be easier to explain. And its not happening while decelerating only during wot
Old 11-16-2014, 07:39 AM   #21
raven1231
Still could be what Neal said. You only build boost when accelerating.
Old 11-16-2014, 10:54 AM   #22
shif7i7down
Erected Member
Drives: frs
here's a video of what i'm talking about.. sounds weird
[ame]http://youtu.be/N6_MOTWKRcA[/ame]
Old 11-16-2014, 10:56 AM   #23
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
Are you talking about the horrible noise after you left off the gas? IE at 10 seconds? I couldn't tell if it was wind or the end of the world in your engine bay.
When you get on it, it sounds pretty normal.. the 'flutter' at full boost sounds to me like the the turbo/wastegate maintaining __ psi. It's hard to tell much though. Especially in higher gears where there is more exhaust volume trying to spool the turbo, the wastegate will work a little harder and you can hear the turbo n wastegate fluttering so to speak. I'm betting it doesn't do it in 1st gear or maybe 2nd? Mine makes the noise in 4th-6th.. sometimes in 3rd if I get on it from lower in the RPM range and its colder outside.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 11-16-2014, 11:08 AM   #24
shif7i7down
Erected Member
Drives: frs
it sounds like air is being released while i'm boosting, you can hear it kinda like a hissing/popping noise. it starts at around 6 sec, and it does sound like it's the wind, but it's not.. that's the noise i was talking about.. -_-. Im in the car with the windows down.
you can hear it whining up and then it slows down and speeds up again, sounds kinda like a engine trying to crank O_O..
edit: it's the sound that sounds like static
Old 11-16-2014, 11:24 AM   #25
woode
Boosted Member
woode's Avatar
The sound at :06 is wastegate flutter (IDK technical term, but your wastegate is trying to keep your turbo spooled at a specific amount and, especially in higher gears at higher rpm when there is more exhaust volume fighting it, thats the sound it will make)... normal. It's trying to maintain the ~7psi (whatever spring is in there). Looking at your log, you aren't losing boost that is noticeable. If you had a proper sized MAP sensor scaled then you could tell for certain, but what you are hearing is pretty typical.
I'm sure some other guys can verify.. unless there is another sound that I'm just not hearing.
Just for clarification.. the sound at like :15 is the wind buffeting, right?
Old 11-16-2014, 12:09 PM   #26
shif7i7down
Erected Member
Drives: frs
There's no wind, the window it's closed so I'm not sure that youre referring to. The chattering pulsating sound, which sounds like air is being released it's what i was talking about. It sounds Kinda like tires chirping but it's the coming front the driver side. Of i had to guess it sounds like it's coming from somewhere near the brake booster
Old 11-16-2014, 12:15 PM   #27
Mike&Ike
Drives: Brz
He is talking about the sound you are hearing. I don't understand however why the wastegate is trying to regulate boost pressure while you are off the gas.
[ame="http://www.youtube.com/watch?v=Hs2cMA6jKSU"]Wastegate flutter??? - YouTube[/ame]
Mike&Ike is offline   Reply With Quote
Old 11-16-2014, 01:22 PM   #28
woode
Boosted Member
woode's Avatar
So you're talking about the sound that starts at like :10? After you let off the gas?
Give us an exact timeframe in the video......
FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices FullBlown Forced Induction 588 12-02-2015 02:41 PM
Toyota Trademarks: D4-S Turbo, More turbo, 9 Scion Names Veloist Off-Topic Lounge [WARNING: NO POLITICS] 9 08-27-2014 11:29 PM
Automatic FRS Surge in Manual Mode N1rve Issues | Warranty | Recalls / TSB 5 02-08-2014 12:28 PM
