| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 |
46k in 2013 and no oil consumption. Always at the full mark.
#16 |
Drives: MDX, Camry
Same here. 2013 with 47k. Doesn't burn oil at all.
Sent from my Pixel 3 XL using Tapatalk |
#17 |
Drives: MDX, Camry
#18 |
My car doesn't but oil, but getting an accurate reading from the dipstick is a PITA compared to my other cars.
| The Following User Says Thank You to funwheeldrive For This Useful Post: | Opie (10-25-2019) |
#19 |
I find it no different than any other car I have ever had. I have always scored the dipstick horizontally with a piece of sandpaper though so maybe all my other cars sucked and I just didn't know.
| The Following User Says Thank You to Tcoat For This Useful Post: | funwheeldrive (10-01-2019) |
#20 |
#21 |
It really works well.
#22 |
Drives: 2017 Series.yellow BRZ
My MINI used half a quart after driving the twisties for half a day. My BRZ has used none at all.
#23 |
Drives: 2015 BRZ WRB
50k miles & no oil consumption & I'm not nice to it....
#24 |
Drives: 2017 Subaru BRZ Limited
I don't have any oil consumption after 30k on the odo, and I track it regularly and otherwise beat the piss out of it.
#25 |
Drives: Supra, Viper, Z06, GT350 and GX460
Zero oil consumption issues with FA20s.
IG: @vipraz 94 Supra Turbo // 15 Viper GT // 16 Corvette Z06 // 18 Shelby GT350 // 19 BRZ LTD // 18 GX460 Premium // 13 Vrod Muscle
#26 |
The Fail Boat
Drives: CWP S.B.
I always overfill my car by half a quart since i got oil cooler.......O.o......
So it's always quite a bit higher then the 2nd dot... I think it's causing a bit of oil leak from having too much oil thou? @Tcoat |
#27 | |
Adding a cooler does not change where the full mark should be. Unless somehow you cooler is mounted high and drains back into the sump. |
| The Following User Says Thank You to Grady For This Useful Post: | norcalpb (10-26-2019) |
#28 |
You should always check your oil when hot. When your oil is hot the thermostat will be open on your sandwich plate which means everything is filled with oil.
| Just hit 1000 Miles | vinh359 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 02-16-2014 05:48 PM |
| Almost at 1000 miles. Oil change when? | TheGuyWithTheFireStorm | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 13 | 08-08-2013 12:31 PM |
| 1000+ miles | jarviz | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 31 | 02-02-2013 12:23 AM |
| Coming up on 1000 miles... | jm1681 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 08-30-2012 02:09 PM |
| 1000 miles | jarviz | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-29-2012 02:42 PM |
