Old 08-26-2015, 03:41 PM   #15
wparsons
wparsons's Avatar
Honestly, if you're looking at 20mm or more, you should probably be getting bolt on spacers anyway.
flickr
Old 08-26-2015, 05:16 PM   #16
8R6
8R6's Avatar
Drives: FRS
im not sure if the difference is so minimal that it wont matter, and ive been trying to read as much info as i can find the past week... but from ive read around so far, extended studs with sandwich spacers are "better" than bolt-on spacers.
reasons seem to be because for bolt-on spacers, the wheel bolts on to the new studs on spacer, and the spacer is bolted on the hub with original studs. this creates more "points" where it could fail? but for extended studs (especially arp studs being stronger) with sandwich spacers, there'd be less "points" where it could fail. am i understanding that wrong? or is it just negligible enough to not make a difference?
thanks
8R6 is offline   Reply With Quote
FS: Muteki Closed End Lugs Chrome The Tengu Wheels and Tires 5 10-02-2014 07:48 PM
Closed Project Kick Revo Lug Nuts (closed) ARP Extended Lugs Sportsguy83 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 02-25-2014 10:46 AM
Muteki Closed End Super Tuner Lugs Reflex Wheels and Tires 2 10-03-2013 03:55 AM
Volk, Advan, Gramlights, SSR, Enkei, Project Kics, Muteki - Wheels/Lugs/Spacers No Limit Motorsport Wheels and Tires 25 11-20-2012 04:01 PM
