#15 |
Same engine design? Like another boxer or another fa20? 23psi on a gtx28 on pump gas!!?? Wow that turbo is going to be blowing nothing but hot air over 18-19psi. If I was going twin scroll I would've done a gtx3071 at a minimum, that's why u go twin scroll is so u can use a larger turbo but not lose spool. Having a lower compression engine allows for more air from a larger turbo. I think that the little 28 just doesn't have the lungs to feed the demands of a built lower compression fa20. Mine hit 360whp on 91 pump at 16psi
#16 |
Drives: Subaru BRZ
#17 |
If you factor in 17% drivetrain loss you're at 430ish whp so that's not bad considering.
#18 | |
Drives: Subaru BRZ
I am not sure whether the supposed drivetrain loss is 10, 15, 17 or 20 percent. |
#19 |
So u only made 350 crank !!???? How is that even possible?
#20 |
Drives: tata nano
can you post the dyno sheets?
#21 |
in orbe terrum non visi
Drives: violent
Sounds like @Synack s car
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#22 |
Drives: Subaru BRZ
I do not have dyno sheets right now. Tuning is still work in process and I got only preliminary results so far. But I will post follow-up info asap.
#23 |
Boosted Member
Drives: 2013 SWP BRZ Limited
Something is not right, I'm making 303whp at 10.5psi with a ebcs, 2.5 exhaust. gt3076 front mount/FMIC el headers. stock internals, injectors and fuel pimp. I am AT as well
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12 |
#24 |
Drives: violent
He's lower compression. That requires more airflow from an already undersized turbo (when twin scroll)
#25 |
Boosted
Drives: Sideways
Yep lowered compression needs more boost to make the same power. Now with lowered compression it's going to be a lot safer, a little more lag, and have higher potential (if you want it).
#26 |
Drives: Subaru BRZ
Update: My tuner found the missing power. Now the car makes approx. 410bhp and 500nm torque. More or less flat torque curve starting from 3300 rpm.
BUT: The OEM AT transmission cannot handle so much torque. Does anyone know about an upgrade? I understand that SSP is developing something? Thanks. |
#27 |
What was the problem?
#28 |
Drives: Subaru BRZ
I believe the diameter of one of the pipes was too small -> resulting in back pressure and high intake temps.
| Feeler: Twinscroll Turboed Battleship Grey Rocket Bunny FR-S | deedz | Cars for Sale/Trade | 44 | 06-03-2016 09:31 PM |
| ACT 6 Pug Problems, anyone have it like me? | kombatlion | Engine, Exhaust, Transmission | 12 | 08-06-2014 11:30 AM |
| Transmission problems, oil leaks and detonation problems.. | turboviper | Issues | Warranty | Recalls / TSB | 4 | 06-18-2014 04:01 PM |
| Turbo Problems | VisionRx7 | Forced Induction | 27 | 04-07-2014 10:05 AM |
| Turbo Problems please help | whitefrs | Forced Induction | 126 | 05-02-2013 07:29 PM |
