Old 06-04-2012, 06:15 PM   #15
RavSpec
Drives: Rx7
nice, thanks for the translate !!!!
RavSpec is offline   Reply With Quote
Old 06-04-2012, 06:46 PM   #16
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
dammmm that BRZ Sti looks fucking siiickkkkkkkk
*KID* is offline   Reply With Quote
Old 06-05-2012, 01:26 PM   #17
Turbowned
Turbowned's Avatar
Originally Posted by yuli8466 View Post
http://www.apa3.jp/html/parts_brake.htm
価格(※) ローター焼入れ有り 420,000円(税込み)
ローター焼入れ無し 378,000円(税込み)
not cheap indeed
420,000 JPY = $5,336USD.... DAT'S A LOTTA MUNIEEEE!!!
Old 06-05-2012, 02:01 PM   #18
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Racecomp Engineering View Post
When you swap sides to fix the bleeder location, the differentially bored pistons are now backwards. So in short, you can't just slap OEM STI brembos on.
- Andrew
Man I swear we've had this conversation 5 or 6 times now...
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 2 Users Say Thank You to Dave-ROR For This Useful Post:
Guff (06-13-2012), merlin2111 (06-05-2012)
Old 06-05-2012, 03:31 PM   #19
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Less money than TRD ver
Old 06-05-2012, 03:40 PM   #20
Someone's still gonna do it though.
Yes but OEM STI Brembos aren't that good. They're fine, but not $5k good.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
lightdir (10-19-2014)
Old 06-05-2012, 03:42 PM   #21
Matt Andrews
Matt Andrews's Avatar
Drives: race cars
I can't find where my previous post is. I have not looked closely at the STi caliper. Is there any chance that they could be drilled and tapped for a bleeder on the appropriate end? Some calipers are molded with the setting there, just not tapped so the caliper can be used on multiple applications. This isn't one of those is it?
11/19/12 - Just back from Redline TimeAttack's demo event. Video and write up in link below.
http://fecompetition.wordpress.com/
https://www.facebook.com/FECompetition
Matt Andrews is offline   Reply With Quote
Old 06-05-2012, 03:43 PM   #22
ichitaka05
Site Moderator
ichitaka05's Avatar
- Andrew
I never stated it was worth it. I just stated, it cost LESS than TRD ver.
Don't assume things now
Old 06-05-2012, 03:47 PM   #23
True true.
I do need to take a closer look at that. We don't have one in the shop at the moment but I can check with someone who probably does have the answer to this.
- Andrew
Matt Andrews (06-05-2012)
Old 06-05-2012, 03:50 PM   #24
ichitaka05
Site Moderator
ichitaka05's Avatar
True true.
btw, you guys are expert in these field. I have a question.
Can an old 4/2 Subaru calipers (WRX) can be used? Also possible to rotate the bleeder up?
Old 06-05-2012, 03:56 PM   #25
Those are a yes because the calipers are not differentially bored. So you can swap sides to keep the bleeder on top and it should just bolt on.
BUT Scooby South just posted that the OEM wheels didn't clear those calipers though on another subaru, which is very surprising.
Still have a lot of work to do before we can consider ourselves true experts but thanks!
- Andrew
ichitaka05 (06-05-2012)
Old 06-05-2012, 04:02 PM   #26
ichitaka05
Site Moderator
ichitaka05's Avatar
- Andrew
Thanks for the info!
You have giving me good info here. I gonna add that to my mod list
OEM stock wheel didn't fit? Like it was too small? Or offset didn't work?
If it's offset, anyone did STi 17's? ('04)
Old 06-05-2012, 04:24 PM   #27
Not entirely sure yet. Maybe Scooby South can chime in if he's around?
- drew
Old 06-05-2012, 05:09 PM   #28
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
Originally Posted by old greg View Post
They were branded as Greddy, but IDK if Greddy made them or just had them made by a supplier. For all I know, they could have actually been made by Brembo anyway.
Hmm, well I saw the Greddy car in person and the "Greddy" script appeared to be applied the same as the "Brembo" script would be in an OEM or aftermarket Brembo application, (decal/paint) certainly not embossed in the caliper. They also did not look perfect, appeared refinished to me but this is not a fact, just an opinion. The cast in mounting appears (but may not be) identical to JDM 01-02 STi caliper, which may or may not be the same as an 04 USDM caliper. I am sure a Subaru expert like Drew would know.
'01 STi caliper with clearly offset mounting
Greddy FR-S caliper with offset mounting as well. Beating a dead horse, but OEM brake hose from... Something. (Maybe FR-S OEM hose) The bottom of the caliper shows some imperfections in the paint, could be a sign of them being refinished.
I do not know if the leading piston is smaller or larger, it may not have been a concern as this car was a show piece. It is possible that the 01-02 STi JDM caliper as I am speculating these calipers are, have the same bore or have been modified? I was hoping you were going to give me something definitive, but this still makes the most sense.
mines13 is offline   Reply With Quote
Brembo BBKs Announced oneday Suspension | Chassis | Brakes -- Sponsored by 949 Racing 82 06-11-2014 10:51 PM
Stock caliper model? skoodge Cosmetic Modification (Interior/Exterior/Lighting) 4 05-31-2012 08:41 PM
Those Brembos, fixed caliper? Or not? [Patent inside!] madfast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 155 12-08-2011 02:06 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
