#15 |
Drives: 2018 Golf R
I hate the feel - or lack thereof - from the stock clutch. I removed the damping device and the check valve that was in my CL, and it made a huge difference. Ill be seeing if this car has the same thing.
Parting out HERE
#16 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
Wait until you get back into a car with a normal clutch. When I stepped on the clutch to start my STI I had to double check to make sure I wasn't stepping on the brake pedal.
| The Following User Says Thank You to Draco-REX For This Useful Post: | civicdrivr (06-03-2012) |
#17 |
Corner Junkie
I'll try to remember to see if it's easily found/removed like this. The usual Subaru delay valve is a bit harder to get to.
#18 |
Drives: '13 WRB BRZ
If you guys find it, and mess with it, let me know how it turns out. Haha not saying I want ya to be guinea pigs though
#19 |
Drives: 2013 Scion FR-S, 1993 Lexus SC300
The light clutch was one of my complaints as well. Looked under the hood today. There is only about 15 inches of clutch line in total. About half hardline, half rubber. The connection between the hardline and rubber appeared to just be a standard fitting, vs a delay valve. I don't think we are gonna find any improvement there.
The hardline is mostly arranged in a large loop. Probably to act sort of like a damper. You could probably regain a *tiny* bit of feel with a braided line straight from the master cylinder to the slave. |
| The Following User Says Thank You to FrX For This Useful Post: | MindtheGap (06-03-2012) |
#20 |
Tall guys fit, too.
Drives: BRZ Premium 6MT (SWP)
Evidently I'm in the minority. Although a bit more 'feel' might be nice for some people, strengthening the clutch would just end up aggravating my knee injury. I was already worried that it would be too hard, but the clutch feel was predictable and obvious to me. I haven't even come close to stalling it even without having driven a manual in almost 12 years, and the shifts are always crisp and smooth.
#21 |
Loves the Smell of Track
Drives: '13 86
Is there a pedal return spring?
2020 86 Hakone MT build thread: https://www.ft86club.com/forums/show...31#post3326231
2013 Toyobaru 86/FR-S 6MT, Red, aka Candy O SOLD http://www.ft86club.com/forums/showthread.php?t=7934 |
#22 |
N7 Spectre
Drives: 2017 Toyota 86 (Ablaze - 6MT)
There is, under the steering column; it's in plain view attached to the pedal; I beleive removing this spring & just leaving the pedal to work only against the master cylinder would do the trick
I just didn't want to mess with it yet; one thing I did modify was the clutch grab point by screwing in the master cylinder threads into the clutch pedal bracket. Lowered physical pedal height & now my clutch grab point is super close to the floor without any gear grinds/ hesitation shifting back & forth between 1st and Reverse
GT 6/ Sport PSN: Koji_Online
| The Following User Says Thank You to Koji_Online For This Useful Post: | normancw (06-09-2012) |
#23 |
Corner Junkie
Yeah, the delay valve appears to be built into the master cylinder.
#24 |
Drives: Matte Black STI
I agree, clutch is wussy feeling. It just needs a bit more resistance. Its much lighter than a stock WRX, or STI and even a MINI. We had a clutch manufacture come by last week where we asked him about making a BRZ part. The answer was yes, but it wouldn't happen for a long time. Just not enough customers yet.
I have done this two times in the past. The spring is designed to make the clutch pedal feel very linear and also return it to the stop completely. When I have removed these, the clutch feel changes to stiffer at the top than at the bottom. I ended up re installing this on my WRX because it was weird to drive. Also it was almost impossible to install because it was a huge spring. I have not looked at the BRZ to see if its an easy change or if it has a cam action like the old cars. If it does, then it might be a good way to add some feel to the car. |
| The Following User Says Thank You to PERRIN_Jeff For This Useful Post: | Koji_Online (06-04-2012) |
#25 | |
Drives: Moped
#26 | |
N7 Spectre
I definitely feel left out on this! Saw the thread on shops looking for demo cars & it sucks that all I saw was CA haha. Currently looking hard for any shop around Las Vegas that would like to develop parts =P
#27 |
The clutch feels so light it reminds me of a clutch pedal when you drain the hydraulic fluid completely out. Toyota clutches are notoriously light, but this is just ridiculous. I hope we can come up with a solution just so we can gain a little more feedback from the pedal.
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
#28 |
I do have a small football we can cram under the pedal. Simple, cheap, and adjustable at that!
| Clutch/brake smell | mr2lor | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 05-24-2012 02:45 PM |
| Clutch wear? | Pakjk89 | Engine, Exhaust, Transmission | 102 | 04-12-2012 08:21 PM |
| ATS carbon clutch collaboration model prototype clutch 86 & BRZ | kanundrum | Engine, Exhaust, Transmission | 41 | 02-27-2012 04:48 PM |
| Steering Wheel Feel | ap5512 | BRZ First-Gen (2012+) — General Topics | 8 | 12-08-2011 12:16 PM |
| Feel like a Post Whore. | Siriusly.Andrew | Off-Topic Lounge [WARNING: NO POLITICS] | 60 | 03-14-2010 06:42 PM |
