Old 08-21-2015, 02:24 PM   #15
jumbaco
jumbaco's Avatar
Drives: FD
FIC makes a 10mm. Made in Japan too. A little pricey but at the same time, you don't need to buy the additional hubcentric inserts like some other brands so it probably comes out to about the same.
jumbaco is offline   Reply With Quote
Old 08-21-2015, 03:06 PM   #16
Kami Speed
Kami Speed's Avatar
Drives: Scion FR-S
Send a message via AIM to Kami Speed
Also, if going with a 10mm or even a 15-20mm spacer with bolts already installed. You need to make sure that your wheels have "cavaties" on the back. Otherwise your stock studs stick out and will hit.
Kami Speed is offline   Reply With Quote
Sprint Kit + RPF1 17x9+35 To spacer or not to spacer? Khorne Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-03-2014 12:53 PM
smallest OD coil over / spring perch BadBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-27-2014 12:56 PM
What's the smallest oil cap? Hanakuso Engine, Exhaust, Transmission 2 07-08-2013 03:55 PM
25mm conversion spacer with 5mm spacer = safe or unsafe? deedz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-05-2013 11:59 AM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 12:19 PM
