View Poll Results: What drifting setup do you all run?
Pedal dance and turn all off 16 22.54%
Push the trac off button for 5 seconds 55 77.46%
Voters: 71. You may not vote on this poll
Old 09-22-2014, 03:45 PM   #15
Demandred7
Demandred7's Avatar
Drives: 2018 Camry XSE V6
I think that proper drift settings are dependant on your level of skill. I think of it like a graduation. Start with VSC Sport until you feel it interferes too much, and then graduate to the 5 second Off (my level of skill), then you still have pedal dance and ultimately remove the ABS fuse (Manji level of skill).
Demandred7 is offline   Reply With Quote
Old 09-22-2014, 03:48 PM   #16
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by Manji View Post
As above. It will allow oversteer, but not big oversteer. Your video, the first slide would've engaged something, you just mihght not have felt it. If you looked down at your dash, the naughty light most likely flashed. On your other slides, the angle was minimal so it let you get away with it. Try some runs with your current settings, then with the fuse removed; if you have a good feel for the car you'll notice the difference, it'll carry speed better in high angle situations, it'll feel good, and then you'll realise that with the fuse in place, it is applying the rear brakes with higher angle.
Thanks for your info, but nothing flashed on the car. I was also easily able to get full lock... this video was a clean run but I had plenty others of spinouts with full counter.
The point of my video was not for one to nitpick, rather to show that it is possible to get the car drifting with pedal dance only. I had minimal angle only because I spent many years on a Kaaz 2-way and am only recently getting back into drifting/motorsports, and the Torsen's open-diff characteristics is very annoying.
The only time I have been able to engage ice mode on the car is when I'm overly braking the car and accidentally tripping ice mode.
-alex
Old 09-22-2014, 06:37 PM   #17
Frishkorn
Hi everybody!
Frishkorn's Avatar
Drives: 14 Whiteout FRS 6M. 16 Abyss iA 6A.
Originally Posted by STV3 View Post
Yeah I learned one night messing around in a parking lot that this happens. So I stopped, did the pedal dance, and boom no more cutting out while using the gas and brake pedal simultaneously.
And you don't want to be on the gas while pulling the hand brake BTW. You don't want the trans engaged to the engine at all while pulling the handbrake for that matter.
I figured that was a bad idea. Only use mine to park. I'm not ready for drifting yet. But thanks for the tip in advance.
Frishkorn is offline   Reply With Quote
The Following User Says Thank You to Frishkorn For This Useful Post:
Tcoat (09-22-2014)
Old 09-22-2014, 09:53 PM   #18
Good man!(Yes I really said that) The parking brake is for parking. Although it will certainly work for drifting and loads of people use it, it is not MADE for that purpose. The stock pads and drums in the e/parking brakes are designed for the car to be stationary when used and are very thin. The drum can glaze over quickly if used too much and will soon give you no grip. Now of course you can upgrade the shoes and rotors to parts that can take the beating or even go the hydraulic system route but it will cost ya!
There are better (but more difficult to master) ways to initiate a drift that wont cost you an arm and leg to repair all the time.
I loved watching Tokyo Drift with all the pull the hand break, complete a whole 100 yard drift, release the hand break, scenes!!! There would have been axles, transmissions and engine parts EVERYWHERE!
Ashybone (10-01-2014), Frishkorn (09-23-2014)
Old 09-23-2014, 02:17 AM   #19
subiestyle
subiestyle's Avatar
Drives: 2014 Monogram FR-S White MT
Do you have to push in the clutch while pulling up the hand brake to initiate the drift?
Or can you just let off the gas and pull the handbrake?
subiestyle is offline   Reply With Quote
Old 09-23-2014, 03:27 PM   #20
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
This is the first I've heard about not being able to use the gas pedal and brake pedal at the same time. I've been heel-toeing for several months now and have never noticed the engine cutting out as I blip the throttle.
Perhaps I am misunderstanding? Clarification plzzzzz.
Manic is offline   Reply With Quote
Old 09-24-2014, 07:22 PM   #21
calmtigers
Drives: 2014 Whiteout TRD FR-S 6MT
Always clutch in when handbraking
Could you possibly describe how you would go through a standard handbrake engaged drift without the fuse pull?
Gas, turn, clutch in, handbrake, clutch out gas it through?
This is first time learning to get sideways in a stick super noob, I know the general concept just not with a stick :/
"I love dinosaurs so much that I’ve based my life on burning as much black melted dinosaur flesh as I can on a daily basis...even the screaming sound of prehistoric reptilians being burnt through any of the classic Japanese four cylinders gives me great joy."
calmtigers is offline   Reply With Quote
Old 09-24-2014, 08:00 PM   #22
Phelzes
Drives: 2013 Whiteout 6MT FRS
Wait, so while holding the button down for 5 sec you cant do a burnout? Do you have to do the pedal dance to be able to do a burnout? Cause a burnout is brake and gas soooo.....?
Phelzes is offline   Reply With Quote
Old 09-26-2014, 02:49 PM   #23
Ddreder
Ddreder's Avatar
Drives: 2013 FR-S, 1990 Miata
This is the most confusing thread I swear.. lol
For one what the heck is pedal dancing? (ive never heard that term before)
Also why would you ever use the brake and gas at the same time while doing anything? These arent FF cars that need left foot braking.. Idk I try and mimic professional drivers and only use my right foot to do either the gas or brake but never at the same time. (except for heel toeing in which I really hate the electronic gas pedal.. It is so inconsistent compared to my miata)
Having been sideways many times with just holding down the button for 5 seconds I havent seen any reason to pull any fuses. Heck the only time my ABS has ever engaged was when I was when I put my foot through the floor because I was about to collide with a deer (which ended up happening..)
Having done a flaming burnout while enraged I know for a fact that 1. 5sec button hold down is all you need and 2. You dont need your brake to do a burnout unless you have an automatic and you are trying to powerbrake.. But I dont recommend ever doing a burnout in an fr-s. It is just to hard on the clutch and throwout bearing. IT is no muscle car
Ddreder is offline   Reply With Quote
Old 09-26-2014, 03:10 PM   #24
STV3
Señor Member
STV3's Avatar
That's because the car is in neutral and this feature doesn't kick in. Try to do a brake stand with just the 5 sec button push and you will see what I am talking about.
STV3 is offline   Reply With Quote
Old 09-26-2014, 03:54 PM   #25
Manic
Is not fast.
Manic's Avatar
That's pretty much the general idea with the handbrake drift. Obviously gotta fit counter steer in there somewhere. Honestly though, this car isn't impossible to drift with just a jab of throttle, especially in the wet. In fact, even an aggressive turn-in can get the wheels starting to break loose. Brake into corner, heel-toe into 3rd or 2nd (depending on how fast you're going and the turn itself), turn a bit more aggressively than usual and get on the gas a bit eariler than usual. Easy peasy you're sideways.
Attend a track day where they're teaching drifting techniques and you should pick it up in no time. Just don't do it on active public streets. Safety first!
The Following User Says Thank You to Manic For This Useful Post:
calmtigers (09-26-2014)
Old 09-26-2014, 04:20 PM   #26
CatDaddysBBQ
Drives: '13 FR-S
I use the 5sec off for street driving (with the occasional tail out fun), and for autoX I do the pedal dance.
CatDaddysBBQ is offline   Reply With Quote
Old 09-28-2014, 11:37 PM   #27
Phelzes
Well if u just drop the clutch your not really doing a burnout your more just doing an aggressive launch. What I mean by gas and brake is that u drop the clutch at say 4k, keep the throttle mashed and catch it with the brake so you can keep spinning the wheels. And yea of course its hard on the car but to have fun (in my pov) you have to be harsh on the car.
The Following User Says Thank You to Phelzes For This Useful Post:
sofargone561 (09-28-2014)
Old 09-28-2014, 11:45 PM   #28
sofargone561
Drives: frs
Im glad i wasnt the first person to ask lol what is the "pedal dance"
answered my own question with a search
heres a video:
[ame="https://www.youtube.com/watch?v=CWXv7UNA7hg"]FRS Pedal dance - YouTube[/ame]
In one of the comments someone says the abs and power steering may be the same fuse in some cars. I am guessing not in the frs/brz based on people pulling these out or am i wrong?
sofargone561 is offline   Reply With Quote
The Following User Says Thank You to sofargone561 For This Useful Post:
Ddreder (09-29-2014)
Help on a proper setup Zechs21 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 01-07-2014 12:20 AM
Proper Intake for 86/BRZ Martin Donnon Engine, Exhaust, Transmission 11 10-17-2013 04:49 AM
Had my car taken away for a proper detailing. Nourdmrolnmt1 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 04-15-2013 11:43 PM
Proper way to Rev Match pinoyplaya Engine, Exhaust, Transmission 46 09-05-2012 01:09 PM
A proper test of the FR-S Vanguard Scion FR-S / Toyota 86 GT86 General Forum 2 03-19-2012 10:58 PM
